Brain block on search customization
Write BAQ to only return the (perhaps multiple table) fields you desire.
Make sure you move all the 'like' available columns in your BAQ to the BAQ Search 'like' column section on the BAQ Search tab of the BAQ designer tool. (Also make sure you mark the BAQ as Shared and possibly Global if multi company.)
In your New PO Suggestion app, hit the search binoculars and you should see it as an available BAQ search. (If you don't, you didn't include the necessary key table.fields for the app.)
Hit the Named Search button and create a new named search using this BAQ. On the Options Tab, make it the defualt search (and your call as to wether or not to make it autoexecute & how many records to return).
Rob Brown
--- On Tue, 10/14/08, Carey S <rotary1@...> wrote:
> From: Carey S <rotary1@...>
> Subject: RE: [Vantage] Brain block on search customization
> To: vantage@yahoogroups.com
> Date: Tuesday, October 14, 2008, 2:55 PM
> Thanks Jeff, but maybe I am missing something here.
> I should have been more specific.
> I am referring to the grid that is populated in the New
> Purchase Order Suggestion Search window when I press the
> binoculars on the POSE screen. That is not handled through
> personalization, right?
> Carey
> To: vantage@yahoogroups.comFrom:
> jeff.stockard@...: Tue, 14 Oct 2008 14:45:31
> -0400Subject: RE: [Vantage] Brain block on search
> customization
> Open the Change PO Suggestion screen. Click on Tools -
> Personalization -----Original Message-----From:
> vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On
> Behalf OfCarey SSent: Tuesday, October 14, 2008 2:36 PMTo:
> vantage@yahoogroups.comSubject: [Vantage] Brain block on
> search customizationI do not know why I am having a block on
> this.I want to be able to show additional fields in the grid
> that are presentedin the Change PO suggestions screen.What
> do I need to do
> here?Carey__________________________________________________________See
> how Windows Mobile brings your life together-at home, work,
> or on
> thego.http://clk.atdmt.com/MRT/go/msnnkwxp1020093182mrt/direct/01/%5bNon-text
> portions of this message have been
> removed]------------------------------------Useful links for
> the Yahoo!Groups Vantage Board are: ( Note: You must
> havealready linked your email address to a yahoo id to
> enable access. )(1) To access the Files Section of our
> Yahoo!Group for Report Builder andCrystal Reports and other
> 'goodies', please
> goto:http://groups.yahoo.com/group/vantage/files/. (2) To
> search through old msg's
> goto:http://groups.yahoo.com/group/vantage/messages(3) To
> view links to Vendors that provide Vantage services
> goto:http://groups.yahoo.com/group/vantage/linksYahoo!
> Groups Links
> _________________________________________________________________
> Want to do more with Windows Live? Learn “10 hidden
> secrets” from Jamie.
> http://windowslive.com/connect/post/jamiethomson.spaces.live.com-Blog-cns!550F681DAD532637!5295.entry?ocid=TXT_TAGLM_WL_domore_092008
> Useful links for the Yahoo!Groups Vantage Board are: (
> Note: You must have already linked your email address to a
> yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for
> Report Builder and Crystal Reports and other
> 'goodies', please goto:
> (3) To view links to Vendors that provide Vantage services
> goto: http://groups.yahoo.com/group/vantage/linksYahoo!
> Groups Links
Hi Group,
I'm having a problem printing barcodes from Vantage. We are thinking
about using the Sales Order Pick List but when I print it from Vantage
I see an asterisk the order number and another asterisk. When I open
the report in Crystal and print it from there I get the barcode. I
tried printing it on a different printer and on another computer with
the same results. Anyone know what the problem is?
Regards,
Linda
You need to install the DWBAR39 font into the C:/Windows/FONT
directory each client PC that will print crystal reports. This is the
font that creates the barcode. This font is probably already
installed on the computer that you are creating Crystal Reports on and
that is why they show on that machine but not on the others.
This font can be found on the DVD's that you have for the install of
Vantage or can be obtained from the help desk (or I can send it to you
offline if you need me to). If there is anything else let me know!
Robert Nupp
robert.nupp@...
Laclede Chain Manufacturing Co.
St. Louis, MO
Thank you. I do have the font installed on my computer. It works fine
when I print the report from Crystal, but not when I run the report in
Vantage.
Regards,
Linda
Ensure the font is installed on the server that is printing the report, i.e. your live or test server. It appears you have the font installed on your Crystal Reports development machine but not on the server.
----- Original Message -----
Sent: Tuesday, October 07, 2008 7:15 AM
Subject: [Vantage] Re: Barcodes working in Crystal but not in Vantage 8.03.403D
Vantage.
Regards,
Linda
I had similar troubles but only with some clients. I had to delete
and reinstall the font for it to work. You might try the same on your
server and clients depending on where the issues are.
Chris
--- In vantage@yahoogroups.com, "lindalowney" <llowney@...> wrote:
> Hi Group,
> Regards,
> Linda
Yes, exactly.
Each client workstation must have the DWBar39.TTF file installed locally
in C:\Windows\Fonts
"Installing" is simply dragging and dropping the TTF file into that
folder.
Then, reboot.
The TTF (true type font) is stored in
\\vantage-server\epicor\mfgsys803\client
Of saab_barracuda
Sent: Wednesday, October 08, 2008 2:07 PM
8.03.403D
I had similar troubles but only with some clients. I had to delete and
Chris
> Hi Group,
> Regards,
> Linda
Hi Chris,
Thank you. I will ask our IT guy to give this a try.
Regards,
Linda
Hi Vic,
There are no font files in this directory on our Vantage server, but the
DWBAR39.ttf file is located in c:\windows\fonts on our Vantage server.
Do I need to copy it from the windows directory to the client directory?
Regards,
Linda
<http://groups.yahoo.com/group/vantage/message/69547;_ylc=X3oDMTJwdmFuMm
FwBF9TAzk3MzU5NzE1BGdycElkAzIwMzY5BGdycHNwSWQDMTcwNTAwNzE4MQRtc2dJZAM2OT
U0NwRzZWMDZG1zZwRzbGsDdm1zZwRzdGltZQMxMjIzNTU3Mzc0>
Posted by: "Vic Drecchio" vic.drecchio@...
<mailto:vic.drecchio@...?Subject=%20Re%3A%20Barcodes%20working%20
in%20Crystal%20but%20not%20in%20Vantage%208%2E03%2E403D> vicdrecchio
<http://profiles.yahoo.com/vicdrecchio>
Wed Oct 8, 2008 12:38 pm (PDT)
Yes, exactly.
in C:\Windows\Fonts
folder.
Then, reboot.
<file:///\\vantage-server\epicor\mfgsys803\client>
Absolutely. And then reboot for good measure. Put that TTF file in a
convenient network location for you to copy it down to other clients
later.
Of Linda Lowney
Sent: Tuesday, October 14, 2008 11:44 AM
8.03.403D
Hi Vic,
Regards,
Linda
Yes, exactly.
in C:\Windows\Fonts
folder.
Then, reboot.
I think you just need to copy the .ttf file to the client's local drive.
go to the client, open the network folder where the dwbar39.ttf file is.
open the client's c:\windows\fonts folder
drag the .ttf file from server to client, it will install automatically.
Sent: Tuesday, October 14, 2008 10:44:13 AM
Hi Vic,
Regards,
Linda
<http://groups. yahoo.com/ group/vantage/ message/69547; _ylc=X3oDMTJwdmF uMm
FwBF9TAzk3MzU5NzE1B GdycElkAzIwMzY5B GdycHNwSWQDMTcwN TAwNzE4MQRtc2dJZ AM2OT
U0NwRzZWMDZG1zZwRzb GsDdm1zZwRzdGltZ QMxMjIzNTU3Mzc0>
Posted by: "Vic Drecchio" vic.drecchio@ timco.aero
<mailto:vic.drecchio@ timco.aero?Subject=%20Re% 3A%20Barcodes% 20working% 20
in%20Crystal% 20but%20not% 20in%20Vantage% 208%2E03% 2E403D> vicdrecchio
<http://profiles. yahoo.com/ vicdrecchio>
Yes, exactly.
in C:\Windows\Fonts
folder.
Then, reboot.
\\vantage-server\ epicor\mfgsys803 \client
<file:///\\vantage-server\ epicor\mfgsys803 \client>
I do not know why I am having a block on this.
I want to be able to show additional fields in the grid that are presented in the Change PO suggestions screen.
What do I need to do here?
Carey
See how Windows Mobile brings your life together�at home, work, or on the go.
Open the Change PO Suggestion screen. Click on Tools - Personalization
Carey S
Subject: [Vantage] Brain block on search customization
Carey
See how Windows Mobile brings your life together-at home, work, or on the
go.
I am referring to the grid that is populated in the New Purchase Order Suggestion Search window when I press the binoculars on the POSE screen. That is not handled through personalization, right?
Carey
To: vantage@yahoogroups.comFrom: jeff.stockard@...: Tue, 14 Oct 2008 14:45:31 -0400Subject: RE: [Vantage] Brain block on search customization
Open the Change PO Suggestion screen. Click on Tools - Personalization -----Original Message-----From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf OfCarey SSent: Tuesday, October 14, 2008 2:36 PMTo: vantage@yahoogroups.comSubject: [Vantage] Brain block on search customizationI do not know why I am having a block on this.I want to be able to show additional fields in the grid that are presentedin the Change PO suggestions screen.What do I need to do here?Carey__________________________________________________________See how Windows Mobile brings your life together-at home, work, or on thego.http://clk.atdmt.com/MRT/go/msnnkwxp1020093182mrt/direct/01/%5bNon-text portions of this message have been removed]------------------------------------Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must havealready linked your email address to a yahoo id to enable access. )(1) To access the Files Section of our Yahoo!Group for Report Builder andCrystal Reports and other 'goodies', please goto:http://groups.yahoo.com/group/vantage/files/. (2) To search through old msg's goto:http://groups.yahoo.com/group/vantage/messages(3) To view links to Vendors that provide Vantage services goto:http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
Want to do more with Windows Live? Learn �10 hidden secrets� from Jamie.
