BPM - Variables
I think you are right. Customizations can be like that too.
Linda
Of bw2868bond
Sent: Friday, November 27, 2009 9:15 AM
Subject: [Vantage] Re: BPM - Variables
Post
Turkey
Sleepiness
Disorder
I have been frustrated several times with BPMs not working as they
should - I end up deleting them and re creating to get them to work.
I think changes to a BPM do not get reflected properly in the server .p
or .r code and remenants of prior versions remain to screw up the works
"Linda Lowney" <llowney@...> wrote:
> It's so quiet around here I'm having email withdrawal.
> I finally got this working, but it was just more Vantage weirdness. I
> got frustrated trying to get the quote number to display so I thought
I
> would try a different field from the ttQuoteHed table and the message
> displayed correctly, then I tried another field and lo and behold that
> one displayed too, then I tried the quote number again and whooohooo
> it's working. I picked all these fields from the drop down list in the
> informational message drop down, so it wasn't a typo, just Vantage
being
> Vantage.
> Linda
Behalf
> Of Linda Lowney
> Sent: Thursday, November 26, 2009 8:10 AM
> Subject: RE: [Vantage] BPM - Variables
> Thanks, but I used "A" the first time then you said to try "Added"
lol.
> Linda
> Behalf
> Of advantage@... <mailto:advantage%40wcoil.com>
> Sent: Wednesday, November 25, 2009 5:19 PM
> Subject: Re: [Vantage] BPM - Variables
> "A"
> Sent from my Verizon Wireless BlackBerry
> -----Original Message-----
> From: "Linda Lowney" <llowney@...
> <mailto:llowney%40pridesigns.com>
> <mailto:llowney%40pridesigns.com> >
> Date: Wed, 25 Nov 2009 17:12:18
> To: <vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> <mailto:vantage%40yahoogroups.com> >
> Thanks, but the QuoteHed.RowMod field of the added row is equal to the
> "Added" value gives me an (7243) (7211) error.
> Ok, I've had enough Vantage torture for today, I think I'll go home
and
> sulk now.
> Linda
> Behalf
> Sent: Wednesday, November 25, 2009 4:57 PM
> Because you have changed is equal to A. Try added
> Date: Wed, 25 Nov 2009 16:11:39
> Thank you. I wonder why it works for you and not for me. What am I
> doing wrong? I added a new quote and the message displayed was: The
> quote number is
> Here is the detail of the BPM I created:
> Pre-Processing Detail Screen:
> Name: test2 pre-processing RFQ memo
> Enabled: checked
> Prevent Endless Loops: checked
> Reenter Max: 100
> Conditions: the QuoteHed.RowMod field of the changed row is equal to
> the "A" value
> Actions: enable dependent post process directives
> Post-Processing Detail Screen:
> Name: test2 post-processing RFQ Memo
> Enabled: checked
> Reenter Max: 100
> Conditions: this directive has been enabled from the test2
> pre-processing RFQ memo directive
> Actions: show informational message based on the tmpQuoteNum template
> Design Information Message Template Screen:
> Message: The quote number is <qryQuoteNum/>
> Design Simple Query Screen:
> Table: ttQuoteHed
> Filter: Added records
> Fields: QuoteNum
> I've also tried it with no condition and get the same result.
> Regards,
> Linda
> Behalf
> Of advantage
> Sent: Wednesday, November 25, 2009 3:40 PM
> Uh, I just created it...I'll put the BPM out on the group site???
> Pre processing
> Conditon
> the QuoteHed.RowMod field of the added row is equal to the "A"
> expression
> Action
> and enable dependent post process directives
> Post processing
> Condition
> this directive has been enabled from the QuoteNumber directive
> Action
> show informational message based on the QuoteNum template
> and it showed the Quote Number 1104 after I hit save!
> Behalf Of
> Linda Lowney
> Sent: Wednesday, November 25, 2009 3:30 PM
> Thanks, but I've tried that and the quote number does not display. I
> need the quote number to perform some other actions but it was not
> working so I tried the informational message only to see if it would
> display the quote number, but it would not.
> Linda
> From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> [mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com]
On
> Behalf
> Of advantage
> Sent: Wednesday, November 25, 2009 3:25 PM
> To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> Yes, indeed, create your pre-process condition on the Quote.Update;
then
> the
> action is enable post-process directive...
> Then in post process there is a condition that says go get that
> pre-process
> directive; then your post-process action would be send the
informational
> message
> Behalf Of
> Linda Lowney
> Sent: Wednesday, November 25, 2009 2:47 PM
> Subject: [Vantage] BPM - Variables
> Hi Group,
> Is it possible to create a variable in pre-process and then use it in
> post-process? I am trying to create a Quote.Update post-process
> directive, but the quote number does not seem to be available. I tried
> a post-process with no conditions and the only action was to show an
> informational message based on the template where I picked the
QuoteNum
> field from the ttQuoteHed table, but no quote number showed up when
the
> message displayed.
> Regards,
> Linda Lowney
> Software Specialist
> Pride Signs
> 255 Pinebush Road
> Cambridge, ON N1T 1B9
> P 519 622 4040 ext. 258
> F 519 622 4031
> www.pridesigns.com <http://www.pridesig <http://www.pridesig
> <http://www.pridesigns.com> ns.com>
> ns.com>
Hi Group,
informational message based on the template where I picked the QuoteNum
field from the ttQuoteHed table, but no quote number showed up when the
message displayed.
Regards,
Linda Lowney
Software Specialist
Pride Signs
255 Pinebush Road
F 519 622 4031
www.pridesigns.com <http://www.pridesigns.com>
How about chucking it into an unused UD field in the preprocess for use
in the post?
Rob Bucek
Manufacturing Engineer
PH: (715) 284-5376 ext 3111
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Of Linda Lowney
Sent: Wednesday, November 25, 2009 1:47 PM
Hi Group,
message displayed.
Regards,
Linda Lowney
Software Specialist
Pride Signs
255 Pinebush Road
F 519 622 4031
Hi Rob,
Thanks for your reply, but we have used up all the extra fields in quote
entry, except for a few date fields. Even if I did use one the the
ttQuoteHed fields what good would it do if I can't access the ttQuoteHed
table in post-process? If I could use the ttQuoteHed table then I
wouldn't have a problem, lol.
Linda
Of Rob Bucek
Sent: Wednesday, November 25, 2009 2:53 PM
in the post?
Rob Bucek
FAX: (715)284-4084
Behalf
Of Linda Lowney
Hi Group,
message displayed.
Regards,
Linda Lowney
Software Specialist
Pride Signs
255 Pinebush Road
F 519 622 4031
Yes, indeed, create your pre-process condition on the Quote.Update; then the
Then in post process there is a condition that says go get that pre-process
directive; then your post-process action would be send the informational
message
Linda Lowney
Hi Group,
message displayed.
Regards,
Linda Lowney
Software Specialist
Pride Signs
255 Pinebush Road
F 519 622 4031
www.pridesigns.com <http://www.pridesig <http://www.pridesigns.com> ns.com>
Linda
Of advantage
the
pre-process
message
Behalf Of
Linda Lowney
Hi Group,
message displayed.
Regards,
Linda Lowney
Software Specialist
Pride Signs
255 Pinebush Road
F 519 622 4031
ns.com>
Sometimes the parameters from the form are available..have you looked at
those? It may give you the quotenum...
Rob Bucek
FAX: (715)284-4084
Of Linda Lowney
Sent: Wednesday, November 25, 2009 2:30 PM
Linda
Behalf
Of advantage
the
pre-process
message
Behalf Of
Linda Lowney
Hi Group,
message displayed.
Regards,
Linda Lowney
Software Specialist
Pride Signs
255 Pinebush Road
F 519 622 4031
ns.com>
Pre processing
Conditon
the QuoteHed.RowMod field of the added row is equal to the "A" expression
Action
Post processing
Condition
Action
Linda Lowney
Linda
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf
Of advantage
the
pre-process
message
Behalf Of
Linda Lowney
Hi Group,
message displayed.
Regards,
Linda Lowney
Software Specialist
Pride Signs
255 Pinebush Road
F 519 622 4031
ns.com>
quote number is
Enabled: checked
Reenter Max: 100
the "A" value
Enabled: checked
Reenter Max: 100
Table: ttQuoteHed
Fields: QuoteNum
Regards,
Linda
Of advantage
Pre processing
Conditon
expression
Action
Post processing
Condition
Action
Behalf Of
Linda Lowney
Linda
Behalf
Of advantage
the
pre-process
message
Behalf Of
Linda Lowney
Hi Group,
message displayed.
Regards,
Linda Lowney
Software Specialist
Pride Signs
255 Pinebush Road
F 519 622 4031
ns.com>
Hi Rob,
Thanks. Are you talking about the parameters that show up at the top of
the screen when you hit the Advanced button? If so, the quote number
does not show up there in the Quote.Update method. It does list all the
tt tables though. I've tried using the advanced button and
{lib/PublishInfoMsg.i &InfoMsg= "ttQuoteHed.QuoteNum"}. and get nothing.
Regards,
Linda
Of Rob Bucek
Sent: Wednesday, November 25, 2009 3:36 PM
Rob Bucek
FAX: (715)284-4084
Behalf
Of Linda Lowney
Linda
Behalf
Of advantage
the
pre-process
message
Behalf Of
Linda Lowney
Hi Group,
message displayed.
Regards,
Linda Lowney
Software Specialist
Pride Signs
255 Pinebush Road
F 519 622 4031
ns.com>
To: <vantage@yahoogroups.com>
quote number is
Enabled: checked
Reenter Max: 100
the "A" value
Enabled: checked
Reenter Max: 100
Table: ttQuoteHed
Fields: QuoteNum
Regards,
Linda
Of advantage
Pre processing
Conditon
expression
Action
Post processing
Condition
Action
Behalf Of
Linda Lowney
Linda
Behalf
Of advantage
the
pre-process
message
Behalf Of
Linda Lowney
Hi Group,
message displayed.
Regards,
Linda Lowney
Software Specialist
Pride Signs
255 Pinebush Road
F 519 622 4031
ns.com>
Ok, I've had enough Vantage torture for today, I think I'll go home and
sulk now.
Linda
Of advantage@...
To: <vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> >
quote number is
Enabled: checked
Reenter Max: 100
the "A" value
Enabled: checked
Reenter Max: 100
Table: ttQuoteHed
Fields: QuoteNum
Regards,
Linda
Behalf
Of advantage
Pre processing
Conditon
expression
Action
Post processing
Condition
Action
Behalf Of
Linda Lowney
Linda
Behalf
Of advantage
the
pre-process
message
Behalf Of
Linda Lowney
Hi Group,
message displayed.
Regards,
Linda Lowney
Software Specialist
Pride Signs
255 Pinebush Road
F 519 622 4031
ns.com>
"A"
sulk now.
Linda
Of advantage@...
quote number is
Enabled: checked
Reenter Max: 100
the "A" value
Enabled: checked
Reenter Max: 100
Table: ttQuoteHed
Fields: QuoteNum
Regards,
Linda
Behalf
Of advantage
Pre processing
Conditon
expression
Action
Post processing
Condition
Action
Behalf Of
Linda Lowney
Linda
Behalf
Of advantage
the
pre-process
message
Behalf Of
Linda Lowney
Hi Group,
message displayed.
Regards,
Linda Lowney
Software Specialist
Pride Signs
255 Pinebush Road
F 519 622 4031
ns.com>
Have some tryptophan and it will all be a distant memory..
Rob Bucek
FAX: (715)284-4084
Of Linda Lowney
Sent: Wednesday, November 25, 2009 4:12 PM
sulk now.
Linda
Behalf
quote number is
Enabled: checked
Reenter Max: 100
the "A" value
Enabled: checked
Reenter Max: 100
Table: ttQuoteHed
Fields: QuoteNum
Regards,
Linda
Behalf
Of advantage
Pre processing
Conditon
expression
Action
Post processing
Condition
Action
Behalf Of
Linda Lowney
Linda
Behalf
Of advantage
the
pre-process
message
Behalf Of
Linda Lowney
Hi Group,
message displayed.
Regards,
Linda Lowney
Software Specialist
Pride Signs
255 Pinebush Road
F 519 622 4031
ns.com>
Thanks, but I used "A" the first time then you said to try "Added" lol.
Linda
Of advantage@...
"A"
sulk now.
Linda
Behalf
quote number is
Enabled: checked
Reenter Max: 100
the "A" value
Enabled: checked
Reenter Max: 100
Table: ttQuoteHed
Fields: QuoteNum
Regards,
Linda
Behalf
Of advantage
Pre processing
Conditon
expression
Action
Post processing
Condition
Action
Behalf Of
Linda Lowney
Linda
Behalf
Of advantage
the
pre-process
message
Behalf Of
Linda Lowney
Hi Group,
message displayed.
Regards,
Linda Lowney
Software Specialist
Pride Signs
255 Pinebush Road
F 519 622 4031
ns.com>
got frustrated trying to get the quote number to display so I thought I
informational message drop down, so it wasn't a typo, just Vantage being
Vantage.
Linda
Of Linda Lowney
Linda
Behalf
"A"
sulk now.
Linda
Behalf
quote number is
Enabled: checked
Reenter Max: 100
the "A" value
Enabled: checked
Reenter Max: 100
Table: ttQuoteHed
Fields: QuoteNum
Regards,
Linda
Behalf
Of advantage
Pre processing
Conditon
expression
Action
Post processing
Condition
Action
Behalf Of
Linda Lowney
Linda
Behalf
Of advantage
the
pre-process
message
Behalf Of
Linda Lowney
Hi Group,
message displayed.
Regards,
Linda Lowney
Software Specialist
Pride Signs
255 Pinebush Road
F 519 622 4031
ns.com>
Post
Turkey
Sleepiness
Disorder
I have been frustrated several times with BPMs not working as they should - I end up deleting them and re creating to get them to work.
I think changes to a BPM do not get reflected properly in the server .p or .r code and remenants of prior versions remain to screw up the works
> Vantage.
> Linda
> Of Linda Lowney
> Linda
> Behalf
> "A"
> sulk now.
> Linda
> Behalf
> quote number is
> Enabled: checked
> Reenter Max: 100
> the "A" value
> Enabled: checked
> Reenter Max: 100
> Table: ttQuoteHed
> Fields: QuoteNum
> Regards,
> Linda
> Behalf
> Of advantage
> Pre processing
> Conditon
> expression
> Action
> Post processing
> Condition
> Action
> Behalf Of
> Linda Lowney
> Linda
> Behalf
> Of advantage
> the
> pre-process
> message
> Behalf Of
> Linda Lowney
> Hi Group,
> message displayed.
> Regards,
> Linda Lowney
> Software Specialist
> Pride Signs
> 255 Pinebush Road
> F 519 622 4031
> ns.com>
