Anybody got any suggestions??
I get the right value for the frozenQty showing in a Message box, but it doesn't work when trying to assign it to the CountedQty. The other one works without no problems, so i can't figure out what im missing here..
Private Sub edvtagView_EpiViewNotification(ByVal view As EpiDataView, ByVal args As EpiNotifyArgs)
try
If (args.NotifyType = EpiTransaction.NotifyType.Initialize) Then
If (args.Row > -1) Then
Dim frozenQty As Decimal = edvtagView.dataView(edvtagView.Row)("FrozenQOH")
messagebox.show(frozenQty)
view.dataView(args.Row)("CountedQty") = frozenQty
view.dataView(args.Row)("CountedBy") = "user"
view.dataView(args.Row)("CountedDate") = DateTime.Today
view.dataView(args.Row)("TagReturned") = False
End If
End If
Catch Ex as Exception
ExceptionBox.Show(Ex)
End Try
End Sub
try
End If
End If
End Try
End Sub
--- In vantage@yahoogroups.com, "lisassar" <lisa.saren@...> wrote:
> Hi and thanks for your replies!
> Seems the BPM way is probabaly not the best way then.. not very familiar with customization coding though.
> Tried using the form event wizard, viewnotification, but can't get the frozen quantity populating correct (right now only giving errors, but compiling OK). Do I need to use a adapter or something to get the value? Seems to get the right value when I show it in a messagebox..
> Code snippet:
> view.dataView(args.Row)("CountedBy") = "Test"
> End If
> End If
> End Sub
> --- In vantage@yahoogroups.com, John Driggers <waffqle@> wrote:
> > Are you stuck using BPM for this?
> > While this is a pain as a BPM it's pretty trivial as customization to the
> > screen.
> > You just need to attach to the dataview notification and populate your
> > fields when it fires.
> > On Wed, Jun 12, 2013 at 11:38 AM, brenda mohr <brenda@> wrote:
> > > You could set a BPMData field to the where clause and then pull a
> > > substring and then use it from there... Little Rube Goldbergish, but if
> > > that's all you have....
> > > Brenda
> > > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf
> > > Of lisassar
> > > Sent: Wednesday, June 12, 2013 5:25 AM
> > > To: vantage@yahoogroups.com
> > > Subject: [Vantage] Re: BPM using WhereClause parameters?
> > > Anybody?
> > > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>,
> > > "lisassar" <lisa.saren@<mailto:lisa.saren@>> wrote:
> > > > Hi,
> > > > I'm trying to create a BPM in the Count Tag Entry (CCTag), after a user
> > > has choose a tagnum, I want to populate the Counted Qty and some other
> > > fields with values. I can't figure out how to get only the choosen TagNum
> > > to get assigned with the right values. Can't find any temp-tables to use
> > > and the only place I find the TagNum value is in the whereclause
> > > parameters, could I use that in someway in my code?
> > > > The method I'm using is the CountTag.GetList (pre-processing), since
> > > that is the only one used when choosing a tagnum.
> > > > Tried just usiing CCTag.Tagnum = TagNum, but that doesn't work. Any
> > > ideas?
> > > > for each CCTag where CCTag.Company = CUR-COMP no-lock no-error.
> > > > if available ccTag then do:
> > > > cctag.CountedQty = CCTag.FrozenQOH.
> > > > CCTag.CountedBy = ttCallContextClient.CurrentUserId.
> > > > CCTag.CountedDate = TODAY.
> > > > CCTag.TagReturned = Yes.
> > > > end.
> > > > end.
> > > > Kind regards,
> > > > Lisa
