I tried to do it on the preprocessing but the UI was throwing the
"modified by other user" message right away.
I moved it to a postprocessing directive and now it doesn't throw the
message until the next update is triggered.
My code is directly updating OrderDtl because the update on the UI is
taking place on OrderHed and it appears that the BPM's dataset does not
contain rows in ttOrderDtl unless there are changed rows.
Of Kevin Simon
Sent: Monday, May 09, 2011 6:04 PM
Subject: RE: [Vantage] BPM: Updating OrderDtl requires refresh in Order
Entry
Joe,
I assume by "does not always contain the rows for OrderDtl and
OrderRel",
you mean that the "tt" rows are not there. Since you're updating the
"ttOrderDtl", could you have code in the preprocessing that does this:
For each ttOrderDtl where ttOrderDtl.RowMod = "U" and (Whatever
conditions
you specify):
For each OrderRel where OrderRel.company = ... (get the orderrel for
the orderdtl, note that this is not ttOrderRel)
(process your updates to each OrderRel)
End.
(process your updates to ttOrderDtl)
End.
I wonder if that would work. Since it's preprocessing, after the base
updates OrderDtl from the ttOrderDtl changes you made, I believe it will
send back the updated OrderRel as part of the dataset it returns.
I'm not positive this will work, but it seems like it should. It's worth
testing.
Kevin
Behalf Of
Joe Rojas
Sent: Monday, May 09, 2011 11:21 AM
Entry
Thanks Jose.
The problem with doing it in the pre-processing is that the Sales Order
dataset does not always contain the rows for OrderDtl and OrderRel.
I think in one of Epicor's attempts to speed up Order Entry they
conditionally send the line information.
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
jrojas@... <mailto:jrojas%40matsinc.com>
<mailto:jrojas%40matsinc.com> | www.matsinc.com Ask us
about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not
the
named addressee you should not disseminate, distribute or copy this
e-mail.
Please notify the sender immediately by e-mail if you have received this
e-mail by mistake. Please note that any views or opinions presented in
this
email are solely those of the author and do not necessarily represent
those
of the company.
jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
Behalf
Of Jose Gomez
Sent: Monday, May 09, 2011 11:06 AM
Subject: Re: [Vantage] BPM: Updating OrderDtl requires refresh in Order
Entry
If you are doing this in post processing you'll get this problem. Do it
in pre-processing.
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@... <mailto:jose%40josecgomez.com>
http://www.josecgomez.com
<http://www.linkedin.com/in/josecgomez>
<http://www.facebook.com/josegomez>
<http://www.google.com/profiles/jose.gomez>
<http://www.twitter.com/joc85>
On Mon, May 9, 2011 at 10:50 AM, Joe Rojas <jrojas@...
Of Kevin Simon
Entry
Joe,
OrderRel",
conditions
you specify):
End.
End.
testing.
Kevin
Behalf Of
Joe Rojas
Entry
Thanks Jose.
the
e-mail.
this
those
of the company.
Behalf
Of Jose Gomez
Entry
in pre-processing.
*Jose C Gomez*
*Software Engineer*
>refresh?
> Hello,
> I have a BPM that sets the value on every line of a Sales Order if a
> value changes on the order header.
> The BPM works correctly but each time it triggers, it requires the
> user to refresh the sales order in Order Entry or else they will get
> the "Record modified by other user" error if they make another change
> to the order.
> I understand why this happens but I was wondering if anyone found a
> way to handle it or is it just a matter of training users to hit
> beautiful matting and flooringthis e-mail.
> Please notify the sender immediately by e-mail if you have received[Non-text portions of this message have been removed]
