BPM: to verify Supplier has an email address attached from PO
I am out of ideas then.
Jordan
[Bully Dog Logo]<http://www.bullydog.com>
Jordan Klassen | Information Technology
TEL: 940-783-9914 ext: 1828
Confidentiality Notice: The information contained in this electronic message is privileged and confidential information intended only for the use of the individual entity or entities named as recipient or recipients. If the reader is not the intended recipient, you are hereby notified that any dissemination, distribution or copy of this communication is strictly prohibited. If you have received this communication in error, please notify the sender immediately by electronic mail and permanently delete this message from your computer system. Thank you.
Disclaimer added by CodeTwo Exchange Rules 2010
www.codetwo.com<http://www.codetwo.com/?sts=1048>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Miguel Santillan
Sent: Thursday, May 02, 2013 11:22 AM
Subject: [Vantage] RE: BPM: to verify Supplier has an email address attached from PO
I did that now as well and when I change the Contact Name, the email does not update until I hit SAVE. The BPM seems very simple, but it is still not triggering when it should.
How would I update the email address at the change of the Contact name?
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Jordan Klassen
Sent: Wednesday, May 01, 2013 4:07 PM
I ran it through a test environment and I had to add the field to the PO Entry area so that it was visible, by default mine does not display the contact email anywhere. It would only work on new PO's or on existing PO's that had been changed.
Jordan
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Miguel Santillan
Sent: Wednesday, May 01, 2013 11:05 AM
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
I tried that and to me it seems that the ttPOHeader.VendorCntEmailAddress does not update.
If Tammy has an email.
Ray has an email
Malissa does not have an email
Eric does have an email.
When I can switch contacts and I choose Malissa, it wont do anything. Then I switch to Eric and it will. Then I go back to Malissa and it will pop up. Then I go to Ray and it will pop up as well.
Just seems like the table is not updating quick enough.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Jordan Klassen
Sent: Wednesday, May 01, 2013 8:13 AM
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
What we do for making sure that a field is filled in using a BPM is do a pre processing BPM on the "Update" method. We select "the specfied field of the changed row is equal to the specified expression"
The "specified field" is the field we want to make sure has data in it, the "specified expression" is set to "" . Then you can throw your error code against that.
Jordan
Jordan Klassen
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Miguel Santillan
Sent: Wednesday, May 01, 2013 7:31 AM
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
Bump to see if anyone can help.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] on behalf of Miguel Santillan [msantillan@...<mailto:msantillan%40ccicms.com><mailto:msantillan%40ccicms.com><mailto:msantillan%40ccicms.com><mailto:msantillan%40ccicms.com>]
Sent: Monday, April 29, 2013 3:04 PM
Subject: [Vantage] BPM: to verify Supplier has an email address attached from PO
Can someone help out.
At the time of the PO, I am trying to check if there is an email associated to the Contact.
I have tried PO.Update Pre and Post as well as PO.ChangePrcConNum Pre and Post.
Seems like I am always one email behind.
for each ttPOHeader no-lock where ttPOHeader.RowMod = 'A' Or ttPOHeader.RowMod = 'U' , each VendCnt no-lock where (ttPOHeader.Company = VendCnt.Company and ttPOHeader.VendorNum = VendCnt.VendorNum and ttPOHeader.PrcConNum = VendCnt.ConNum ) and VendCnt.EmailAddress = ' '
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/><http://groups.yahoo.com/group/vantage/files/><http://groups.yahoo.com/group/vantage/files/><http://groups.yahoo.com/group/vantage/files/>
From: vantage@yahoogroups.com [vantage@yahoogroups.com] on behalf of Miguel Santillan [msantillan@...]
What results are you seeing ? It does not give you a 'false' if there is nothing in the email field?
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Wednesday, May 1, 2013 9:31 AM
Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.%c2%a0
Jordan
Jordan Klassen
Ray has an email
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jordan Klassen
Jordan
Jordan Klassen
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Miguel Santillan
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] on behalf of Miguel Santillan [msantillan@...<mailto:msantillan%40ccicms.com>]
Jordan
Ray has an email
Jordan
Jordan Klassen
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] on behalf of Miguel Santillan [msantillan@...<mailto:msantillan%40ccicms.com><mailto:msantillan%40ccicms.com>]
Jordan
Ray has an email
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Jordan Klassen
Jordan
Jordan Klassen
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Miguel Santillan
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] on behalf of Miguel Santillan [msantillan@...<mailto:msantillan%40ccicms.com><mailto:msantillan%40ccicms.com><mailto:msantillan%40ccicms.com>]
