BPM to sum ExtUnit costs on Requisiton Entry
hey all…im trying to recreate something ive done in the past but this seems to be a little more complicated. im trying to create a bpm that will sum up the EXT-unitcost form fields from the Requisition Entry screen. i really cant believe this isnt a standard field. I was able to get the Ext-Unit price to show up per line so i can sum up the bottom table but i want this to exist within a field as shown by my second picture.
i was able to do something similar on the part entry screen where a bpm will sum two separate fields into a third. but now that im using the form fields (i believe that’s what the list at the bottom of requisition entry is called) i think its more complicated than i had hoped. I successfully created a custom field id like to use. I created this UD field in both ReqDetail and ReqHead just in case i can only use one and i wasnt sure which one i needed.
When i tried to create BPM i tried both method and data directives but when i try and create the expression i want, it yells at me about SUM not existing in the current context. I have pretty much zero experience in C# let alone any language so please bear with me.
here is the kinetic post i mentioned, no answers on there either. ( Adding an ExtCost total on Requisition Entry)
get the bpm cookbook from EpicWeb. Page 69 has an example of what you want to do.
thanks for this ill check it out now!
