So, I have a request from the users to be able to enter a single bin number and ship everything that has a LEFT(LotNum,6) == OrderNum.
I traced the data and I’m trying to loop through each item in the bin and add the line to the shipment.
The first line adds fine, but any subsequent ones fail with and Object Ref error.
It seems to error out on the shipBO.GetNewOrdrShipDtl method.
I’ve tried so many variations, I can’t remember them all.
Anyone know why this might be erroring on this line?
Trace with adding 2 lines:
TraceData32220.txt (442.5 KB)
Code:
var tt = ttShipHead.FirstOrDefault();
callContextBpmData.Character03 = "";
if( tt != null )
string bin = Convert.ToString(callContextBpmData.Character01);
string oNum = Convert.ToString(tt.OTSOrderNum);
string pNum = "";
string whse = "";
int ioNum = Convert.ToInt32(tt.OTSOrderNum);
int ioLine = 0;
int ioRel = 0;
int packNum = Convert.ToInt32(tt.PackNum);
int shipCustNum = 0;
decimal qty = Decimal.Zero;
shipCustNum = (
from oh in Db.OrderHed.With(LockHint.NoLock)
where oh.Company == Session.CompanyID &&
oh.OrderNum == ioNum
select oh.ShipToCustNum).DefaultIfEmpty(0).FirstOrDefault();
var binList = (
from pb in Db.PartBin.With(LockHint.NoLock)
where pb.Company == Session.CompanyID &&
pb.LotNum.Substring(0,6) == oNum
select new {pb}).ToList();
if( binList.Count > 0 )
foreach(var daBin in binList)
whse = daBin.pb.WarehouseCode;
pNum = daBin.pb.PartNum;
qty = daBin.pb.OnhandQty;
if( daBin.pb.LotNum.Length >= 10 )
ioLine = Int32.Parse(daBin.pb.LotNum.ToString().Substring(7,1));
ioRel = Int32.Parse(daBin.pb.LotNum.ToString().Substring(9,1));
if( ioLine != 0 && ioRel != 0 )
try
using(var shipBO = Ice.Assemblies.ServiceRenderer.GetService<Erp.Contracts.CustShipSvcContract>(Db) )
CustShipTableset shTS = new CustShipTableset();
callContextBpmData.Character03 += (shTS.ShipDtl.Count).ToString() + " " + "Before GetByID" + Environment.NewLine;
shTS = shipBO.GetByID(packNum);
callContextBpmData.Character03 += (shTS.ShipDtl.Count).ToString() + " " + "Before GetNewOrdrShipDtl" + Environment.NewLine;
// Params: CustShip Dataset, Pack Number, Order Number
if( shTS.ShipDtl.Count == 0 )
shipBO.GetNewOrdrShipDtl(ref shTS, packNum, 0);
else
shipBO.GetNewOrdrShipDtl(ref shTS, packNum, ioNum); //<<<<< Object Ref Error
if( shTS.ShipDtl.Count == 1 )
shTS.ShipDtl[0].RowMod = "A";
else
shTS.ShipDtl[shTS.ShipDtl.Count - 1].RowMod = "A";
// Params: Order Number, Credit Message, CustShip Dataset
string creditMessage = "";
callContextBpmData.Character03 += (shTS.ShipDtl.Count).ToString() + " " + "Before GetOrderInfo" + Environment.NewLine;
shipBO.GetOrderInfo(ioNum, out creditMessage, ref shTS);
// Params: Order Number, Pack Num, Dataset
//shTS.ShipHead[0].RowMod = "U";
//shipBO.GetManifestInfo(ioNum, packNum, ref shTS);
// Params: Order, CustNum, shipToList
string shipToList = "";
callContextBpmData.Character03 += (shTS.ShipDtl.Count).ToString() + " " + "Before 1st ShipToList" + Environment.NewLine;
shipBO.BuildShipToList(ioNum, shipCustNum, out shipToList);
// Params: Part, Order, Line, MsgText, SubAvail, MsgType, origPart
string partParam = "";
string vMsgText = "";
string vMsgType = "";
string origPart = "";
bool vSubAvail = false;
callContextBpmData.Character03 += (shTS.ShipDtl.Count).ToString() + " " + "Before CheckPrePartInfo" + Environment.NewLine;
shipBO.CheckPrePartInfo(ref partParam, ioNum, ioLine, out vMsgText, out vSubAvail, out vMsgType, out origPart);
callContextBpmData.Character03 += (shTS.ShipDtl.Count).ToString() + " " + "Before GetOrderLineINfo" + Environment.NewLine;
// Params: Dataset, Pack Line, Order Line, Part Num
shipBO.GetOrderLineInfo(ref shTS, 0, ioLine, pNum);
if( shTS.ShipDtl.Count > 1 )
// Params: PackNum, OrderNum, Line, Rel, askUser
bool askUser = false;
callContextBpmData.Character03 += (shTS.ShipDtl.Count).ToString() + " " + "Before AskForShipToChange" + Environment.NewLine;
shipBO.AskForShipToChange(packNum, ioNum, ioLine, ioRel, ref askUser);
callContextBpmData.Character03 += (shTS.ShipDtl.Count).ToString() + " " + "Before GetOrderRelInfo" + Environment.NewLine;
// Params: Dataset, Pack Line, Order Rel Num, AllowNewShipTo
shipBO.GetOrderRelInfo(ref shTS, 0, ioRel, true);
callContextBpmData.Character03 += (shTS.ShipDtl.Count).ToString() + " " + "Before 2nd ShipToList" + Environment.NewLine;
// Params: Dataset, Pack Line?, belongToAnotherPC, pcOutMessage
string pcOutMessage = "";
int lineNum = 0;
bool belongToAnotherPC = false;
callContextBpmData.Character03 += (shTS.ShipDtl.Count).ToString() + " " + "Before CheckPCBinOutLoc" + Environment.NewLine;
shipBO.CheckPCBinOutLocation(ref shTS, out lineNum, out belongToAnotherPC, out pcOutMessage);
using( var lotBO = Ice.Assemblies.ServiceRenderer.GetService<Erp.Contracts.LotSelectUpdateSvcContract>(Db) )
LotSelectUpdateTableset lotTS = new LotSelectUpdateTableset();
callContextBpmData.Character03 += (shTS.ShipDtl.Count).ToString() + " " + "Before LotGetByID" + Environment.NewLine;
lotTS = lotBO.GetByID(shTS.ShipDtl[0].PartNum, shTS.ShipDtl[0].LotNum);
else
lotTS = lotBO.GetByID(shTS.ShipDtl[shTS.ShipDtl.Count - 1].PartNum, shTS.ShipDtl[shTS.ShipDtl.Count - 1].LotNum);
callContextBpmData.Character03 += (shTS.ShipDtl.Count).ToString() + " " + "Before LotUpdate" + Environment.NewLine;
lotBO.Update(ref lotTS);
/* <parameters>
<parameter name="ds" type="Erp.BO.CustShipDataSet">
<CustShipDataSet xmlns="http://www.epicor.com/Ice/300/BO/CustShip/CustShip" />
</parameter>
<parameter name="doValidateCreditHold" type="System.Boolean"><![CDATA[False]]></parameter>
<parameter name="doCheckShipDtl" type="System.Boolean"><![CDATA[True]]></parameter>
<parameter name="doLotValidation" type="System.Boolean"><![CDATA[True]]></parameter>
<parameter name="doCheckOrderComplete" type="System.Boolean"><![CDATA[False]]></parameter>
<parameter name="doPostUpdate" type="System.Boolean"><![CDATA[False]]></parameter>
<parameter name="doCheckCompliance" type="System.Boolean"><![CDATA[False]]></parameter>
<parameter name="ipShippedFlagChanged" type="System.Boolean"><![CDATA[False]]></parameter>
<parameter name="ipPackNum" type="System.Int32"><![CDATA[99255]]></parameter>
<parameter name="ipBTCustNum" type="System.Int32"><![CDATA[0]]></parameter>
<parameter name="opReleaseMessage" type="System.String"><![CDATA[]]></parameter>
<parameter name="opCompleteMessage" type="System.String"><![CDATA[]]></parameter>
<parameter name="opShippingMessage" type="System.String"><![CDATA[]]></parameter>
<parameter name="opLotMessage" type="System.String"><![CDATA[]]></parameter>
<parameter name="opInventoryMessage" type="System.String"><![CDATA[]]></parameter>
<parameter name="opLockQtyMessage" type="System.String"><![CDATA[]]></parameter>
<parameter name="opAllocationMessage" type="System.String"><![CDATA[]]></parameter>
<parameter name="opPartListNeedsAttr" type="System.String"><![CDATA[]]></parameter>
<parameter name="opLotListNeedsAttr" type="System.String"><![CDATA[]]></parameter>
<parameter name="shipCreditMsg" type="System.String"><![CDATA[]]></parameter>
<parameter name="cError" type="System.Boolean"><![CDATA[False]]></parameter>
<parameter name="compError" type="System.Boolean"><![CDATA[False]]></parameter>
<parameter name="msg" type="System.String"><![CDATA[]]></parameter>
<parameter name="opPostUpdMessage" type="System.String"><![CDATA[]]></parameter>
<parameter name="updateComplete" type="System.Boolean"><![CDATA[False]]></parameter>
<parameter name="checkComplianceError" type="System.Boolean"><![CDATA[False]]></parameter>
<parameter name="changeStatusError" type="System.Boolean"><![CDATA[False]]></parameter>
<parameter name="checkShipDtlAgain" type="System.Boolean"><![CDATA[False]]></parameter>
</parameters>
string a = "";
string b = "";
string c = "";
string d = "";
string e = "";
string f = "";
string g = "";
string h = "";
string i = "";
string j = "";
string k = "";
string l = "";
bool aB = false;
bool bB = false;
bool cB = false;
bool dB = false;
bool eB = false;
bool fB = false;
callContextBpmData.Character03 += (shTS.ShipDtl.Count).ToString() + " " + "Before UpdateMaster" + Environment.NewLine;
shipBO.UpdateMaster(ref shTS,
false,
false,
false,
false,
false,
false,
false,
packNum,
0,
out a,
out b,
out c,
out d,
out e,
out f,
out g,
out h,
out i,
out j,
out aB,
out bB,
out k,
out l,
out cB,
out dB,
out eB,
out fB);
//var ds1 = shipBO.GetByID(packNum);
//this.dsHolder.Attach(ds1);
// Params: Order, Pack, pcWarningMsg
string pcWarningMsg = "";
callContextBpmData.Character03 += (shTS.ShipDtl.Count).ToString() + " " + "Before POGEtNEw" + Environment.NewLine;
shipBO.POGetNew(ioNum, packNum, out pcWarningMsg);
// Params: Pack, PCID, Order, PackMode, cWarning
string cWarning = "";
string packMode = "PACK";
callContextBpmData.Character03 += (shTS.ShipDtl.Count).ToString() + " " + "Before POGetDtl" + Environment.NewLine;
shipBO.POGetDtlList(packNum, "", 0, packMode, out cWarning);
callContextBpmData.Character03 += "--------------------------------------------------------" + Environment.NewLine;
catch(Exception e)
callContextBpmData.Character03 += e.Message.ToString() + Environment.NewLine;
//this.PublishInfoMessage(,Ice.Common.BusinessObjectMessageType.Information, Ice.Bpm.InfoMessageDisplayMode.Individual,"","");
Debugging Flags:
0 Before GetByID
0 Before GetNewOrdrShipDtl
1 Before GetOrderInfo
1 Before 1st ShipToList
1 Before CheckPrePartInfo
1 Before GetOrderLineINfo
1 Before GetOrderRelInfo
1 Before 2nd ShipToList
1 Before CheckPCBinOutLoc
1 Before LotGetByID
1 Before LotUpdate
1 Before UpdateMaster
1 Before POGEtNEw
1 Before POGetDtl
0 Before GetByID
1 Before GetNewOrdrShipDtl
Order: 556443 Pack: 99255
Object reference not set to an instance of an object.
0 Before GetByID
