BPM To Send Email When AP Invoice Posted
Hello group,
I’m trying to create a BPM to send an email when a user posts an AP Invoice, but I can’t figure out which method to use. I’ve tried LogAPInv.Update and APInvoice.Update, along with a few others.
All I really need to know is what method is triggered when a user presses the Submit button. Any help is much appreciated. Thanks for your time!
You can’t trigger a BPM off a System Task at least not easily. One thing you could do is do a Data Directive off the POSTED Flag on the AP Invoice Table. (though I am not 100% sure they fire DD’s… but its worth a shot)
Thank you Jose! That was the answer. I was trying to do it through the Method Directive, didn’t even think of the Data side of it. I created the BPM using the Data Directive and LogAPInv table, had it check for the Posted field to be true, then fire off an email. It worked perfectly. Thanks again!
Like Jose said, it’s not always straightforward when triggering off of a sys task but it can be done (and be useful)
