BPM to populate PORel Promise Date
Hi Mike,
Â
I guess then I am misunderstanding what you are looking for. When a new PO line is created, the release for that line is not generated until the PO is saved. So if the BPM is attached to the POupdate method, it will populate the promise date when the PO is saved.
Â
Maurice
Sent: Thursday, February 2, 2012 4:28 PM
Subject: RE: [Vantage] RE: BPM to populate PORel Promise Date
Â
Maurice,
This approached worked better, but still we have to open the release tab and refresh in order to populate the promise date. I was hoping for it to be populated as soon as we enter a PO Line Due Date, which in it’s turn populates the PO Release Due Date, and we don’t have to refresh.
Mike Tonoyan / Natel EMS
mtonoyan@...
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Maurice Swede
Sent: Thursday, February 02, 2012 12:31 PM
Subject: Re: [Vantage] RE: BPM to populate PORel Promise Date
Mike,
You can also accomplish this by using a post process method directive. Under the "Conditions" check the promise date field to determine if it is empty. Then under the "Actions" select the "synchronously execute ABL code...record nothing" option, click on the word "code" and enter the following ABL code:
for each ttPORel where ttPORel.PromiseDt = ?,
each PORel where PORel.PONum = ttPORel.PONum and PORel.POLine = ttPORel.POLine and PORel.PORelNum = ttPORel.PORelNum:
Assign PORel.PromiseDt = ttPORel.DueDate.
Assign ttPORel.PromiseDt = ttPORel.DueDate.
end.
To explain the code:
The "for each ttPORel..." line is doing the same check as the condition you set up so could be eliminated. If you do eliminate it, you need to put a "for" before the "each PORel..." line.
The "each PORel where...." line is going out and finding the just created record in the database.
The "Assign..." lines are setting the promise date fields to the due date. For the screen to display the promise date the temp table field needs to be populated as well.
The "end." obviously ends the program.
We are currently running 9.04.507A and the above process worked, so I hape this helps.
Maurice
From: Mike Tonoyan <mtonoyan@... <mailto:mtonoyan%40natelems.com> >
Sent: Thursday, February 2, 2012 2:02 PM
Greg,
Thanks, we are on 9.04.507, most likely that's the reason. I added a
method directive also, still the same, it populates when the due date is
changed.
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On Behalf
Of Greg Payne
Sent: Thursday, February 02, 2012 10:42 AM
Mine is in transaction and works on 905.605.
based on the documentation that is the data directive to use. The table
name should be colored and not black if the editor recognizes it. I have
seen where the table is not recognized, but when I typed it again it
was.
Greg
from business.process.management.pdf
There are two types of data directives:
* In-Transaction: Affects data while it is being saved to the database.
This directive type can only process one
row at a time; it cannot process multiple dirty rows.
* Standard: Does not affect data in the database. This directive type
executes after a data transaction saves
to the database. It can process multiple dirty rows modified in the
database. This directive type runs after base
methods and method directives.
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
Behalf Of Mike Tonoyan
Sent: Thursday, February 02, 2012 12:20 PM
To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
As I mentioned before it didn't work on "In-Transactions" tab. No, I
didn't create a Method Directive. Should it be a Post-Processing method
directive?
mtonoyan@... <mailto:mtonoyan%40natelems.com> <mailto:mtonoyan%40natelems.com>
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>]
On Behalf
Of Greg Payne
Sent: Thursday, February 02, 2012 5:22 AM
In transaction is where it goes. Yes, it should set the value whenever
due date has a date and promise is not set.
Should happen on po entry and on generate po. Did you put on a method
directive of Update?
Greg
On
Sent: Wednesday, February 01, 2012 6:58 PM
Never mind the previous e-mail, I shouldn't have selected the
"In-Transaction" Data Directive.
After that everything went fine, the directive is enabled but the only
time it populates the "Promise Date" when the "Due Date" is changed. Was
it supposed to populate when a new record was added too?
On Behalf
Of Mike Tonoyan
Sent: Wednesday, February 01, 2012 3:27 PM
Greg,
I am new at this, so please bear with me.
1. Created a "In-Transaction" Data Directive for PORel table
2. Clicked on "Conditions... " and selected "number of rows in the
designed query is not less than 1" user text.
3. Clicked on "designed" and entered the query name "Empty promise
date Query"
4. Copied and pasted "for each ttPORel where ttPORel.PromiseDt = ?
and ttPORel.DueDate <> ?"
5. When tried to save I received the following message "Unable to
find any table in the query"
What am I doing wrong?
On
Behalf
Of Greg Payne
Sent: Friday, January 27, 2012 10:44 AM
Subject: [Vantage] RE: BPM to populate PORel Promise Date
I actually wrote that same routine today for our purchasing dept.
This is how I approached it.
Greg
Data Directive:
Condition
number of rows in the 'Empty Promise date' query is not less than 1
Empty promise date Query
for each ttPORel where ttPORel.PromiseDt = ? and ttPORel.DueDate <> ?
Action:
synchronously execute ABL for each ttPORel where ttPORel.PromiseDt ...
record nothing
ABL Code:
no-lock.
If available ttPORel then do:
Assign ttPOrel.PromiseDt = ttPORel.DueDate.
End.
End.
Sent: Friday, January 27, 2012 12:40 PM
Subject: [Vantage] BPM to populate PORel Promise Date
I am wondering if anyone knows how to create a BPM for populating the PO
Release Promise Date when the PO Release Due Date is populated for the
first time. The promise date then should not change automatically when
the due date is changed.
_,___
__________________________________________________________
Notice: This email transmission may contain confidential information and
is intended only for the person(s) named. Any use, copying or disclosure
to/by any other person(s) is strictly prohibited. By accepting this
information, recipients confirm that they understand and will comply
with all applicable ITAR and EAR requirements.
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments,
is privileged and confidential. It is intended only for the exclusive
use of the addressee. If the reader of this message is not the intended
recipient, or the employee or agent responsible for delivering it to the
intended recipient, you are hereby notified that any dissemination,
distribution or copying of this communication is strictly prohibited. If
you have received this communication in error, please notify us at (727)
578-6258 and immediately delete the communication.
"This (document/presentation) may contain technical data as defined in
the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10.
Export of this material is restricted by the Arms Export Control Act (22
U.S.C. 2751 et seq.) and may not be exported to foreign persons without
prior approval form the U.S. Department of State."
Notice: This email transmission may contain confidential information and is intended only for the person(s) named. Any use, copying or disclosure to/by any other person(s) is strictly prohibited. By accepting this information, recipients confirm that they understand and will comply with all applicable ITAR and EAR requirements.
mtonoyan@...
_,___
______________________________________________________________________
I have one that sets the promise date when a new line is added
PO.Update method
Pre Process:
Condition = number of rows in the 'New PODetail Line' query is not less than 1
query = for each ttpodetail where ttpodetail.RowMod = 'A'
Action = enable dependent post process directives
Post Process:
Condition = enabled from the directive you created above
Action = synchronously execute 4GL for each ttporel. ... record nothing
4GL = for each ttporel.
assign ttporel.PromiseDt = ttporel.DueDate.
find first porel where porel.Company = ttporel.Company and porel.PONum = ttporel.PONum and porel.POLine = ttporel.POLine and porel.PORelNum = ttporel.PORelNum.
if available porel then do:
run lib\UpdateTableBuffer(input BUFFER porel:HANDLE, 'PromiseDt',ttporel.DueDate).
end.
end.
> mtonoyan@...
> _,___
If you do this code in a post-processing, don't you end up with the user
getting a "Row has been modified" error when back in the UI? Obviously, you
can't do this in a PRE, as the PORel record doesn't exist yet when the user
is adding the PODetail.
I'd recommend almost the same code below, but put it in a data directive on
PORel instead of a method directive. That way it will capture it when the
row is being added, without the problems that come with a post-processing
directive.
Kevin Simon
bw2868bond
Sent: Friday, January 27, 2012 1:04 PM
Subject: [Vantage] Re: BPM to populate PORel Promise Date
PO.Update method
Pre Process:
1
Post Process:
ttporel.PORelNum.
end.
end.
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Mike
> mtonoyan@...
> _,___
We are on 8.03.405a so no data directives for us :(
If you look at the Post Process Action you will see I update the ttPORel going back to the client *and* the PORel table on the db so we don't get the row has been modified error
> directive.
> Kevin Simon
> bw2868bond
> PO.Update method
> Pre Process:
> 1
> Post Process:
> ttporel.PORelNum.
> end.
> end.
> > mtonoyan@
> > _,___
Greg
Data Directive:
Condition
Action:
synchronously execute ABL for each ttPORel where ttPORel.PromiseDt ... record nothing
ABL Code:
for each ttPORel where ttPORel.PromiseDt = ? and ttPORel.DueDate <> ? no-lock.
End.
End.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Mike Tonoyan
mtonoyan@...<mailto:mtonoyan%40natelems.com>
_,___
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at (727) 578-6258 and immediately delete the communication.
Does this work? I'm pretty sure I've tried that in the past, and it didn't
matter that the fields from PORel and ttPORel match. I assumed that the
logic looked at some type of internal time stamp or other identifier on the
record to determine whether you're dealing with the latest row.
As an aside, if I had an order up on my screen. Meanwhile, someone else
pulled up the same order, changed a field and saved, then changed it back
and saved. I'd get a "Row has been modified" on my screen, even though the
data's the same.
bw2868bond
Sent: Friday, January 27, 2012 1:36 PM
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Kevin
you
user
on
> directive.
> Kevin Simon
Behalf Of
> bw2868bond
> PO.Update method
> Pre Process:
than
> 1
> Post Process:
> ttporel.PORelNum.
> end.
> end.
> > mtonoyan@
> > _,___
We do not experience issues - it only fires on the addition of a new PO Line and acts on the release that is automagically created by the progress db trigger....
heaven forbid if another buyer has to touch someone else's PO....
> data's the same.
> bw2868bond
> you
> user
> on
> > directive.
> > Kevin Simon
> Behalf Of
> > bw2868bond
> > PO.Update method
> > Pre Process:
> than
> > 1
> > Post Process:
> > ttporel.PORelNum.
> > end.
> > end.
> > > mtonoyan@
> > > _,___
Sorry, I hadn't had the chance to try any of the suggestions today.
Hopefully on Monday or Tuesday next week. I'll let the group know.
Thank you all.
mtonoyan@...
Of Kevin Simon
Sent: Friday, January 27, 2012 12:02 PM
Subject: RE: [Vantage] Re: BPM to populate PORel Promise Date
didn't
the
back
the
data's the same.
Behalf Of
bw2868bond
the
user
Obviously,
you
user
directive
on
the
post-processing
> directive.
> Kevin Simon
Behalf Of
> bw2868bond
> PO.Update method
> Pre Process:
less
than
> 1
> Post Process:
nothing
> ttporel.PORelNum.
> end.
> end.
the PO
the
when
> > mtonoyan@
> > _,___
and
disclosure
with
Greg,
date Query"
mtonoyan@...
Of Greg Payne
Greg
Data Directive:
Condition
Action:
record nothing
ABL Code:
no-lock.
End.
End.
_,___
mtonoyan@...
Of Mike Tonoyan
Greg,
date Query"
Behalf
Of Greg Payne
Greg
Data Directive:
Condition
Action:
record nothing
ABL Code:
no-lock.
End.
End.
_,___
In transaction is where it goes. Yes, it should set the value whenever due date has a date and promise is not set.
Should happen on po entry and on generate po. Did you put on a method directive of Update?
Greg
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
Of Mike Tonoyan
Greg,
date Query"
mtonoyan@...<mailto:mtonoyan%40natelems.com> <mailto:mtonoyan%40natelems.com>
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
Behalf
Of Greg Payne
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
Greg
Data Directive:
Condition
Action:
record nothing
ABL Code:
no-lock.
End.
End.
_,___
directive?
mtonoyan@...
Of Greg Payne
Greg
On Behalf
Of Mike Tonoyan
Greg,
date Query"
On
Behalf
Of Greg Payne
Greg
Data Directive:
Condition
Action:
record nothing
ABL Code:
no-lock.
End.
End.
_,___
based on the documentation that is the data directive to use. The table name should be colored and not black if the editor recognizes it. I have seen where the table is not recognized, but when I typed it again it was.
Greg
* In-Transaction: Affects data while it is being saved to the database. This directive type can only process one
* Standard: Does not affect data in the database. This directive type executes after a data transaction saves
to the database. It can process multiple dirty rows modified in the database. This directive type runs after base
directive?
Of Greg Payne
Greg
On Behalf
Of Mike Tonoyan
Greg,
date Query"
On
Behalf
Of Greg Payne
Greg
Data Directive:
Condition
Action:
record nothing
ABL Code:
no-lock.
End.
End.
_,___
Greg,
changed.
mtonoyan@...
Of Greg Payne
was.
Greg
directive?
On Behalf
Of Greg Payne
Greg
On
On Behalf
Of Mike Tonoyan
Greg,
date Query"
On
Behalf
Of Greg Payne
Greg
Data Directive:
Condition
Action:
record nothing
ABL Code:
no-lock.
End.
End.
_,___
Try the pre and post method from bwalker to see if it will work for you. I did it on 905 and got the refresh message, but the data was populated on the add.
An Epicor programmer that I was working with this week, just added a message after the post processing to tell the user to refresh. :)
Good Luck
Greg
Sent: Thursday, February 02, 2012 2:03 PM
Greg,
changed.
Of Greg Payne
was.
Greg
directive?
On Behalf
Of Greg Payne
Greg
On
On Behalf
Of Mike Tonoyan
Greg,
date Query"
On
Behalf
Of Greg Payne
Greg
Data Directive:
Condition
Action:
record nothing
ABL Code:
no-lock.
End.
End.
_,___
Mike,
Â
Â
end.
Â
Â
Â
Â
Â
Â
Maurice
Â
Â
Greg,
changed.
mtonoyan@...
Of Greg Payne
was.
Greg
directive?
On Behalf
Of Greg Payne
Greg
On
On Behalf
Of Mike Tonoyan
Greg,
date Query"
On
Behalf
Of Greg Payne
Greg
Data Directive:
Condition
Action:
record nothing
ABL Code:
no-lock.
End.
End.
_,___
Maurice,
mtonoyan@...
Mike,
end.
Maurice
Greg,
changed.
Of Greg Payne
was.
Greg
directive?
On Behalf
Of Greg Payne
Greg
On
On Behalf
Of Mike Tonoyan
Greg,
date Query"
On
Behalf
Of Greg Payne
Greg
Data Directive:
Condition
Action:
record nothing
ABL Code:
no-lock.
End.
End.
_,___
