I am using a uBAQ/Dashboard to update a UD table. This UD table is part of a different BAQ that shows us what orders/lines need to be shipped without the backordered products. Anyway, I need an output file with the order numbers so I can have a DMT delete it out of the UD table after every use. With that being said, will a BPM put a file in a folder? I know we can go to an email, but IW ant something that is about more hands off. So instead of emailing, straight to a folder location.
See the last code on this post… using writeLib example
Why is DMT required as an extra step? You can delete UD records from BPM itself or just mark any checkbox in the UD table and avoid those records in the process, So you can keep history for audit also.
