That is not a valid statement
Chris,
This is what I have:
ttInvcDtl_xRow.UDField(“RCTrkQty_c”);
//ttInvcDtl_xRow.UDField(“AveragePerRCTrk_c”);
ttInvcDtl_xRow.UDField<decimal>("RCTrkQty_c") = OrderDtl_Row.UDField<decimal>("RCTrkTtlQty_c");
//ttInvcDtl_xRow.UDField(“AveragePerRCTrk_c”) = OrderDtl_row.UDField(“AvgPrice_c”);
My error is now: Left-hand side of an assignment must be a variable, property or indexer.
I am ready to throw in the towel and just let the end users manually update.
This is not a valid statement, It doesnt do anything. Comment it out
I don’t now why but that is not what it says on my screen it is:
ttInvcDtl_xRow.UDField(“RCTrkQty_c”) not ttInvcDtl_xRow.UDField(“RCTrkQty_c”);
In any case, I have commented it out and still getting the same error:
The left-hand side of an assignment must be a variable, property or indexer
I assume formatting on the forum is taking your brackets away - but the issue is that you have to assign something to that
ttInvcDtl_xRow.UDField<decimal>(“RCTrkQty_c”) = 1;
//or
In short, comment out that line that isnt doing anything:
ttInvcDtl_xRow.UDField<decimal>("RCTrkQty_c") ; <-- scrap this!
Chris,
I removed the lines. Please see the code below. Still has the error about the left-hand side
Erp.Tables.OrderDtl OrderDtl;
var ttInvcDtl_results = (from ttInvcDtl_Row in ttInvcDtl
where (ttInvcDtl_Row.RowMod == “U”) select ttInvcDtl_Row);
foreach (var ttInvcDtl_xRow in ttInvcDtl_results)
var Company = ttInvcDtl_xRow.Company;
var OrderNum = ttInvcDtl_xRow.OrderNum;
var OrderLine = ttInvcDtl_xRow.OrderLine;
var OrderDtl_Row = (from ttOrderDtl_Row in Db.OrderDtl
where (ttOrderDtl_Row.Company == Company) select ttOrderDtl_Row).FirstOrDefault();
I have the line exactly the way you have in the comments above. Up to that point it works.
You seem to be struggling with the C#, might I suggest using the BPM widgets to set those fields. The issue is, even if you get this compiling, writing the wrong thing in C# can hinder your performance or worse corrupt your data.
Check out the Fill Table By Query Widget - I think @timshuwy has a few good examples on the forum here
Chris,
I did the widgets first. I had a message then Fill Table by Query widget and a final message. It fired off the message as expected and never executed the BPM. I abandoned it because I just couldn’t get it to work. I saw this post and got with a programmer here at work to assist with the code as I am not as proficient as I’d like to be. I did see that 10.2 has a UD Column Map Maintenance Module bit there is no template for OrderDtl to InvcDtl that I can see. This is used evidently to map UD fields from one table to another.
I will keep at it and if I find a solution, I’ll certainly post on here.
Yes but only certain tables that have a direct relationship.
@Chris_Conn, I went back and used your code and updated the last line and it kicked out the same error as I’m getting: The left-hand side of an assignment must be a variable, property or indexer
Maybe I just have something set up wrong. I will try again with the fill by query. I appreciate your help.
Charles
I was able to resolve this issue. I had some code that was not correct. I appreciate everyone’s help.
@Charles.Dingas how did you reference your UD fields at the end of your code? I’m having the same issues that you faced.
Here is the code I used. I did have to get some help on it as I am not a programmer…
foreach(var ttInvcDtl_iterator in (from ttInvcDtl_Row in ttInvcDtl
where string.Equals(ttInvcDtl_Row.RowMod, IceRow.ROWSTATE_ADDED, StringComparison.OrdinalIgnoreCase) || string.Equals(ttInvcDtl_Row.RowMod, IceRow.ROWSTATE_UPDATED, StringComparison.OrdinalIgnoreCase)
select ttInvcDtl_Row))
var ttInvcDtlRow = ttInvcDtl_iterator;
//this.PublishInfoMessage("FoundpodetailDtl", Ice.Common.BusinessObjectMessageType.Information, Ice.Bpm.InfoMessageDisplayMode.Individual, "", "");
foreach (var OrderDtl_iterator in (from OrderDtl_Row in Db.OrderDtl
where string.Compare(OrderDtl_Row.Company, ttInvcDtlRow.Company, true) == 0 &&
OrderDtl_Row.OrderNum == ttInvcDtlRow.OrderNum &&
OrderDtl_Row.OrderLine == ttInvcDtlRow.OrderLine
select OrderDtl_Row))
if (OrderDtl_iterator != null)
if(OrderDtl_iterator.AvgPrice_c != null && OrderDtl_iterator.TotalQtyUnits_c != null)
//this.PublishInfoMessage("FoundOrderDtl", Ice.Common.BusinessObjectMessageType.Information, Ice.Bpm.InfoMessageDisplayMode.Individual, "", "");
OrderDtl = OrderDtl_iterator;
ttInvcDtlRow["AvgPerPer_c"] = OrderDtl.AvgPrice_c;
ttInvcDtlRow["SKTotalQty_c"] = OrderDtl.TotalQtyUnits_c;
Charles
Anytime. Let me know if it works. It is just a matter of making sure you choose the correct tables.
