BPM SC Flow Blank Title 83245
Yah my test system is already 8.03 and figured out the web service bit the
hard way :-(
I REALLY don't want to upgrade the prod.
We are waiting for 409 on vantage and when I do that I'll upgrade SC at the
same time.
~Charlie
_____
Rob Bucek
Sent: Friday, October 02, 2009 4:26 PM
Subject: RE: [Vantage] BPM SC Flow
If and when you do be sure you don't create a new web service for your
IIS...use the old one...
Rob Bucek
Manufacturing Engineer
PH: (715) 284-5376 ext 3111
FAX: (715)284-4084
<http://www.dsmfg. <http://www.dsmfg.com/> com/>
(Click the logo to view our site) <http://www.dsmfg. <http://www.dsmfg.com/>
com/>
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf
Of Charlie Wilson
Sent: Friday, October 02, 2009 2:31 PM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
I'm running 8.02.xxxx I bet I get told to upgrade. First.
~Charlie
_____
<mailto:vantage%40yahoogroups.com> ] On
Behalf Of
Michelle de la Vega
Sent: Friday, October 02, 2009 2:52 PM
SC v 8.03.3992
I reviewed my call logs and saw that we have slightly different
scenarios,
however, they are eerily similar. That being said, I would call the help
desk and talk to Jesse Thorn. You can even remind him of my case, call#
1560969ESC.
Good luck,
Michelle de la Vega
Business Applications Manager
Cold Jet, LLC
455 Wards Corner Road
Loveland, Ohio 45140
USA
+1 513-716-6400 (office)
+1 513-382-3281 (mobile)
+1 513-831-1209 (fax)
www.coldjet.com<http://www.coldjet. <http://www.coldjet.
<http://www.coldjet.com> com> com>
[cid:image001.jpg@ <mailto:image001.jpg%4001CA436F.ED3784F0>
01CA436F.ED3784F0]
Behalf Of Charlie Wilson
Sent: Friday, October 02, 2009 12:58 PM
407
What SC version are you on?
~Charlie
_____
.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups
.com<mailto:vantage%40yahoogroups.com>]
On Behalf Of
Michelle de la Vega
Sent: Friday, October 02, 2009 12:52 PM
What version are you on? I had the same exact problem and had to get a
one
off fix...but I believe it is fixed in .407 and higher.
Michelle de la Vega
Cold Jet, LLC
USA
<http://www.coldjet. <http://www.coldjet.com> com> com> com>
[cid:image001.jpg@ <mailto:image001.jpg%4001CA435F.30CBD7E0>
01CA435F.30CBD7E0]
Sent: Thursday, October 01, 2009 9:15 AM
I moved a BPM / sc from my test server to my production server and when
ever
it runs I get app server log errors.
[09/09/30@09:35:43.105-0400] P-004184 T-004696 1 AS -- (Procedure:
'Post4_A1_Update bo/CorrectiveAction.p' Line:3992) Error loading WSDL
document http://LEXERP02/
<http://LEXERP02/
<http://LEXERP02/
<http://LEXERP02/BPMIntegrationService/WrflService.asmx?wsdl>
BPMIntegrationService/WrflService.asmx?wsdl :
Cannot resolve URI:
'http://LEXERP02/
<http://LEXERP02/
<http://LEXERP02/
BPMIntegrationService/WrflService.asmx?wsdl' status code:
101960416 (11748)
[09/09/30@09:35:43.121-0400] P-004184 T-004696 1 AS -- (Procedure:
'Post4_A1_Update bo/CorrectiveAction.p' Line:3995) SERVER is not
connected.
(5451)
'Post4_A1_Update bo/CorrectiveAction.p' Line:3995) Invalid or
inappropriate
server handle specified for RUN WorkflowWebSrvSoap ... ON SERVER
statement.
(5453)
I have tested that URL and it loads correctly. Like how you test a
webservice.
~Charlie
_____
On Behalf Of
Charlie Wilson
Sent: Thursday, October 01, 2009 9:01 AM
I worked with Ahmed at Epicor who taught me a process that is probably
doing
exactly what you just described but in a different manor, more than one
way
to skin a cat (sorry cat lovers). I documented it and posted it in the
tutorials folder on the files section. I'll try your method next and see
how
that goes for me sounds much simpler than what I did.
~Charlie
_____
Behalf Of
Brian Johnson
Sent: Thursday, October 01, 2009 8:56 AM
Subject: Re: [Vantage] BPM SC Flow
Charlie,
In your BPM, click on the "advanced" button, then "Create programming
interface" and export the schema for service connect.
Import those schemas into service connect and then use the "Request" one
as the input schema to your conversion.
Brian Johnson -- Epi-Center <http://epi-ctr. <http://epi-ctr.
<http://epi-ctr. <http://epi-ctr. <http://epi-ctr. <http://epi-ctr.com> com>
com> com> com>
com>
Systems Consulting/Development Manager | direct: 413-531-2859
Charlie Wilson wrote:
> Does anyone have a SC Flow they are firing from a BPM that works that
> I can
> use as a model for one I'm build.
> I can't seem to get mine going because the first conversion isn't
really
> converting. No matter what I do it wont convert the data even though I
> know
> it's there.
> ~Charlie
Does anyone have a SC Flow they are firing from a BPM that works that I can
I can't seem to get mine going because the first conversion isn't really
converting. No matter what I do it wont convert the data even though I know
it's there.
~Charlie
Charlie,
Brian Johnson -- Epi-Center <http://epi-ctr.com>
> I can
> know
> it's there.
> ~Charlie
I worked with Ahmed at Epicor who taught me a process that is probably doing
exactly what you just described but in a different manor, more than one way
tutorials folder on the files section. I'll try your method next and see how
~Charlie
_____
Brian Johnson
Charlie,
Brian Johnson -- Epi-Center <http://epi-ctr. <http://epi-ctr.com> com>
> I can
> know
> it's there.
> ~Charlie
I moved a BPM / sc from my test server to my production server and when ever
document http://LEXERP02/BPMIntegrationService/WrflService.asmx?wsdl :
Cannot resolve URI:
'http://LEXERP02/BPMIntegrationService/WrflService.asmx?wsdl' status code:
101960416 (11748)
'Post4_A1_Update bo/CorrectiveAction.p' Line:3995) SERVER is not connected.
(5451)
'Post4_A1_Update bo/CorrectiveAction.p' Line:3995) Invalid or inappropriate
server handle specified for RUN WorkflowWebSrvSoap ... ON SERVER statement.
(5453)
webservice.
~Charlie
_____
Charlie Wilson
~Charlie
_____
Behalf Of
Brian Johnson
Charlie,
<http://epi-ctr.com> com> com>
> I can
> know
> it's there.
> ~Charlie
What version are you on? I had the same exact problem and had to get a one off fix...but I believe it is fixed in .407 and higher.
Michelle de la Vega
Cold Jet, LLC
USA
www.coldjet.com<http://www.coldjet.com>
[cid:image001.jpg@01CA435F.30CBD7E0]
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Charlie Wilson
Cannot resolve URI:
101960416 (11748)
(5451)
(5453)
webservice.
~Charlie
_____
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
Charlie Wilson
~Charlie
_____
Behalf Of
Brian Johnson
Charlie,
> I can
> know
> it's there.
> ~Charlie
407
~Charlie
_____
Michelle de la Vega
Michelle de la Vega
Cold Jet, LLC
USA
www.coldjet.com<http://www.coldjet. <http://www.coldjet.com> com>
01CA435F.30CBD7E0]
Cannot resolve URI:
'http://LEXERP02/
101960416 (11748)
(5451)
(5453)
webservice.
~Charlie
_____
<mailto:vantage%40yahoogroups.com> .com<mailto:vantage%40yahoogroups.com>]
On Behalf Of
Charlie Wilson
~Charlie
_____
Behalf Of
Brian Johnson
Charlie,
<http://epi-ctr. <http://epi-ctr.com> com> com> com>
> I can
> know
> it's there.
> ~Charlie
SC v 8.03.3992
I reviewed my call logs and saw that we have slightly different scenarios, however, they are eerily similar. That being said, I would call the help desk and talk to Jesse Thorn. You can even remind him of my case, call# 1560969ESC.
Good luck,
Michelle de la Vega
Cold Jet, LLC
USA
[cid:image001.jpg@...3784F0]
407
~Charlie
_____
Michelle de la Vega
Michelle de la Vega
Cold Jet, LLC
USA
01CA435F.30CBD7E0]
Cannot resolve URI:
'http://LEXERP02/
101960416 (11748)
(5451)
(5453)
webservice.
~Charlie
_____
On Behalf Of
Charlie Wilson
~Charlie
_____
Behalf Of
Brian Johnson
Charlie,
> I can
> know
> it's there.
> ~Charlie
~Charlie
_____
Michelle de la Vega
SC v 8.03.3992
1560969ESC.
Good luck,
Michelle de la Vega
Cold Jet, LLC
USA
01CA436F.ED3784F0]
407
~Charlie
_____
On Behalf Of
Michelle de la Vega
Michelle de la Vega
Cold Jet, LLC
USA
01CA435F.30CBD7E0]
<http://LEXERP02/
Cannot resolve URI:
'http://LEXERP02/
<http://LEXERP02/
101960416 (11748)
(5451)
(5453)
webservice.
~Charlie
_____
On Behalf Of
Charlie Wilson
~Charlie
_____
Behalf Of
Brian Johnson
Charlie,
<http://epi-ctr. <http://epi-ctr. <http://epi-ctr.com> com> com> com> com>
> I can
> know
> it's there.
> ~Charlie
Rob Bucek
FAX: (715)284-4084
(Click the logo to view our site) <http://www.dsmfg.com/>
Of Charlie Wilson
~Charlie
_____
Behalf Of
Michelle de la Vega
SC v 8.03.3992
scenarios,
1560969ESC.
Good luck,
Michelle de la Vega
Cold Jet, LLC
USA
01CA436F.ED3784F0]
407
~Charlie
_____
On Behalf Of
Michelle de la Vega
one
Michelle de la Vega
Cold Jet, LLC
USA
01CA435F.30CBD7E0]
ever
<http://LEXERP02/
Cannot resolve URI:
'http://LEXERP02/
<http://LEXERP02/
101960416 (11748)
connected.
(5451)
inappropriate
statement.
(5453)
webservice.
~Charlie
_____
On Behalf Of
Charlie Wilson
doing
way
how
~Charlie
_____
Behalf Of
Brian Johnson
Charlie,
com>
> I can
really
> know
> it's there.
> ~Charlie
