BPM / SC Flow Blank Title 83130
That's what I meant, perhaps I could have worded it better.
Rob Bucek
Manufacturing Engineer
PH: (715) 284-5376 ext 3111
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Of Ahmed
Sent: Monday, September 28, 2009 5:10 PM
Subject: Re: [Vantage] Re: BPM / SC Flow
Rob,
its not related to the BO/method at all. It's BPM and service connect
schema mismatch.
Ahmed
From: Rob Bucek <rbucek@... <mailto:rbucek%40dsmfg.com> >
To: vantage@yahoogroups..com <mailto:vantage%40yahoogroups..com>
Sent: Monday, September 28, 2009 2:55:37 PM
Subject: RE: [Vantage] Re: BPM / SC Flow
Ahmed,
Very cool, do you think this was more related to this specific
BO/Method, or do you think that more often than not there will be
discrepancies between the schemas output by the BPM and the schemas
associated with the web services on the work flow side....
Rob Bucek
FAX: (715)284-4084
<http://www.dsmfg com/>
(Click the logo to view our site) <http://www.dsmfg com/>
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On
Behalf
Of Ahmed
Sent: Monday, September 28, 2009 4:41 PM
To: vantage@yahoogroups .com
Hi Rob,
The solution was quite simple, therere was a mismatch in the input
schema and what was actually being ouput by the BPM directive. Which
resulted in no date being mapped.
Ahmed
____________ _________ _________ __
From: Rob Bucek <rbucek@dsmfg. com <mailto:rbucek% 40dsmfg.com> >
To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
Sent: Monday, September 28, 2009 2:25:43 PM
Did he feel that was working as designed.... or. .the solution he showed
you was a work around to something he didn't understand.. ..just
curious.. I think I already have a pretty good mental picture to the
solution suggested...
Rob Bucek
FAX: (715)284-4084
From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On
Behalf
Of Charlie Wilson
Sent: Monday, September 28, 2009 3:53 PM
Ahmed showed me how to get it to work with having to export out to a
file
and then having a second flow pic it back up. I'll have a write up ready
tomorrow.
~Charlie
_____
From: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
[mailto:vantage@ yahoogroups .com <mailto:vantage% 40yahoogroups. com> ]
On
Behalf Of
Rob Bucek
Sent: Monday, September 28, 2009 4:47 PM
Charlie,
That SC flow I sent you has a poster in it that is saving the xml. The
subsequent input channel wouldn't be any different from any other input
file setup you would have made for another work flow.
Rob Bucek
FAX: (715)284-4084
<http://www.dsmfg <http://www.dsmfg com/> com/>
(Click the logo to view our site) <http://www.dsmfg <
com/>
From: vantage@yahoogroups <mailto:vantage% 40yahoogroups. com> .com
[mailto:vantage@ yahoogroups <mailto:vantage% 40yahoogroups. com> .com]
On
Behalf
Of Charlie Wilson
Sent: Monday, September 28, 2009 3:16 PM
To: vantage@yahoogroups <mailto:vantage% 40yahoogroups. com> .com
Can you send me some screen shots of how you set that poster and
subsequent
output channel up?
cwilson@foamdesign. <mailto:cwilson% 40foamdesign. com> com
~Charlie
_____
<mailto:vantage% 40yahoogroups. com> ] On
Behalf Of
Michelle de la Vega
Sent: Monday, September 28, 2009 12:52 PM
I do have several BPM's calling SC Workflows. The initial workflow is a
poster that throws a CSV file to a specific folder, then I have SC
monitor
that folder and use that initial CSV file to process the SC Workflow.
Also,
make sure that your BPM is calling the SC Workflow synchronously.
If you want screen shot's email me off line and I'll get them to you.
Michelle de la Vega
Business Applications Manager
Cold Jet, LLC
455 Wards Corner Road
Loveland, Ohio 45140
USA
+1 513-716-6400 (office)
+1 513-382-3281 (mobile)
+1 513-831-1209 (fax)
www.coldjet. com<http://www.coldjet <http://www.coldjet
<http://www.coldjet com> com> com>
[cid:image001. jpg@ <mailto:image001. jpg%4001CA403A. . 7824F810>
01CA403A.7824F810]
On
Behalf Of alfe_ksimon
Sent: Monday, September 28, 2009 11:58 AM
Subject: [Vantage] Re: BPM / SC Flow
Charlie,
I'm not using BPM's yet (we're still using the super-procedures - the
precursor to BPM's). The method I use to get these to kick off a service
connect workflow is simply write the data out to a csv file, and have
the
service connect monitor that folder. I would assume you'd be able to do
the
same in a BPM, as I understand the BPM is nothing more than the
superprocedures with a nice front-end on it.
Kevin
--- In vantage@yahoogroups <mailto:vantage% 40yahoogroups. com>
.com<mailto: vantage%40yahoog roups.com> , "Charlie Wilson"
<foamdesigncsw@ ...>
wrote:
> In either the BPM or SC webex we discussed firing SC flows from a BPM
but
I
> can't figure out which one that was in. Does some one remember where
that
> is?
> ~Charlie
In either the BPM or SC webex we discussed firing SC flows from a BPM but I
can't figure out which one that was in. Does some one remember where that
is?
~Charlie
I had that in the BPM webex Charlie..if you need help just let me know.
Rob Bucek
FAX: (715)284-4084
Of Charlie Wilson
Sent: Wednesday, September 23, 2009 10:56 AM
Subject: [Vantage] BPM / SC Flow
but I
that
is?
~Charlie
Charlie,
I'm not using BPM's yet (we're still using the super-procedures - the precursor to BPM's). The method I use to get these to kick off a service connect workflow is simply write the data out to a csv file, and have the service connect monitor that folder. I would assume you'd be able to do the same in a BPM, as I understand the BPM is nothing more than the superprocedures with a nice front-end on it.
Kevin
> is?
> ~Charlie
I do have several BPM's calling SC Workflows. The initial workflow is a poster that throws a CSV file to a specific folder, then I have SC monitor that folder and use that initial CSV file to process the SC Workflow. Also, make sure that your BPM is calling the SC Workflow synchronously.
Michelle de la Vega
Cold Jet, LLC
USA
www.coldjet.com<http://www.coldjet.com>
[cid:image001.jpg@01CA403A.7824F810]
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of alfe_ksimon
Charlie,
Kevin
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Charlie Wilson" <foamdesigncsw@...> wrote:
> is?
> ~Charlie
That is what I'm going to have to do if I cant get this to work. The BPMs
have a method of calling the flow directly.
I'm getting the flow to fire and am seeing the correct dataset but can't get
the conversion to change from one to another for some reason.
~Charlie
_____
alfe_ksimon
Charlie,
Kevin
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, "Charlie
I
> is?
> ~Charlie
Hi Everyone,
In need of some help if possible. I'm trying to create a button that will
open the Price Breaks form (just like the button in Quote
Entry/MfgDetails/QuoteDetails/Materials at the bottom.
Instead of opening a menu item or an Epicor.mfg.ui. object it's looks like
it's trying to open something called "App.QuoteEntry.MtlPriceBreakForm"
(captured while in developer mode and click on the button).
Can anyone point me in the right direction of how to create the same
functionality but in a different spot? I figured out the supplier price
breaks and purchase advisor buttons but can't seem to figure out how to do
the Price Breaks button.
Any help is greatly appreciated.
Sean
Can you send me some screen shots of how you set that poster and subsequent
output channel up?
cwilson@...
~Charlie
_____
Michelle de la Vega
Michelle de la Vega
Cold Jet, LLC
USA
www.coldjet.com<http://www.coldjet <http://www.coldjet.com> com>
[cid:image001.jpg@ <mailto:image001.jpg%4001CA403A.7824F810>
01CA403A.7824F810]
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Charlie,
Kevin
I
> is?
> ~Charlie
Charlie,
Rob Bucek
FAX: (715)284-4084
Of Charlie Wilson
subsequent
output channel up?
cwilson@... <mailto:cwilson%40foamdesign.com>
~Charlie
_____
Behalf Of
Michelle de la Vega
monitor
Also,
Michelle de la Vega
Cold Jet, LLC
USA
01CA403A.7824F810]
Charlie,
the
the
Kevin
<foamdesigncsw@...>
but
I
that
> is?
> ~Charlie
After a call with epicor I figured out how to not have to use an export
import setup I'll be writing this one up and posting it to the group. Look
for this tomorrow.
~Charlie
_____
Charlie Wilson
Sent: Monday, September 28, 2009 4:16 PM
output channel up?
cwilson@foamdesign. <mailto:cwilson%40foamdesign.com> com
~Charlie
_____
Behalf Of
Michelle de la Vega
Michelle de la Vega
Cold Jet, LLC
USA
<http://www.coldjet.com> com> com>
01CA403A.7824F810]
Charlie,
Kevin
I
> is?
> ~Charlie
Ahmed showed me how to get it to work with having to export out to a file
tomorrow.
~Charlie
_____
Rob Bucek
Charlie,
Rob Bucek
FAX: (715)284-4084
<http://www.dsmfg <http://www.dsmfg.com/> com/>
(Click the logo to view our site) <http://www.dsmfg <http://www.dsmfg.com/>
com/>
Behalf
Of Charlie Wilson
subsequent
output channel up?
~Charlie
_____
Behalf Of
Michelle de la Vega
monitor
Also,
Michelle de la Vega
Cold Jet, LLC
USA
01CA403A.7824F810]
Charlie,
the
the
Kevin
<foamdesigncsw@...>
but
I
that
> is?
> ~Charlie
Did he feel that was working as designed...or..the solution he showed
you was a work around to something he didn't understand....just
Rob Bucek
FAX: (715)284-4084
Of Charlie Wilson
file
tomorrow.
~Charlie
_____
Behalf Of
Rob Bucek
Charlie,
Rob Bucek
FAX: (715)284-4084
com/>
Behalf
Of Charlie Wilson
subsequent
output channel up?
~Charlie
_____
Behalf Of
Michelle de la Vega
monitor
Also,
Michelle de la Vega
Cold Jet, LLC
USA
01CA403A.7824F810]
Charlie,
the
the
Kevin
<foamdesigncsw@...>
but
I
that
> is?
> ~Charlie
Hi Rob,
The solution was quite simple, therere was a mismatch in the input schema and what was actually being ouput by the BPM directive. Which resulted in no date being mapped.
Ahmed
Â
Did he feel that was working as designed....or. .the solution he showed
Rob Bucek
FAX: (715)284-4084
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of Charlie Wilson
file
tomorrow.
~Charlie
_____
[mailto:vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com> ] On
Behalf Of
Rob Bucek
Charlie,
Rob Bucek
FAX: (715)284-4084
com/>
[mailto:vantage@ yahoogroups <mailto:vantage% 40yahoogroups. com> .com] On
Behalf
Of Charlie Wilson
subsequent
output channel up?
~Charlie
_____
Behalf Of
Michelle de la Vega
monitor
Also,
Michelle de la Vega
Cold Jet, LLC
USA
[cid:image001. jpg@ <mailto:image001. jpg%4001CA403A.. 7824F810>
01CA403A.7824F810]
Charlie,
the
the
Kevin
but
I
that
> is?
> ~Charlie
Ahmed,
Rob Bucek
FAX: (715)284-4084
Of Ahmed
Hi Rob,
Ahmed
Rob Bucek
FAX: (715)284-4084
Behalf
Of Charlie Wilson
file
tomorrow.
~Charlie
_____
On
Behalf Of
Rob Bucek
Charlie,
Rob Bucek
FAX: (715)284-4084
com/>
On
Behalf
Of Charlie Wilson
subsequent
output channel up?
~Charlie
_____
Behalf Of
Michelle de la Vega
monitor
Also,
Michelle de la Vega
Cold Jet, LLC
USA
01CA403A.7824F810]
On
Charlie,
the
the
Kevin
but
I
that
> is?
> ~Charlie
Rob,
its not related to the BO/method at all. It's BPM and service connect schema mismatch.
Ahmed
Â
Â
Ahmed,
Rob Bucek
FAX: (715)284-4084
Of Ahmed
Hi Rob,
Ahmed
Rob Bucek
FAX: (715)284-4084
Behalf
Of Charlie Wilson
file
tomorrow.
~Charlie
_____
On
Behalf Of
Rob Bucek
Charlie,
Rob Bucek
FAX: (715)284-4084
com/>
On
Behalf
Of Charlie Wilson
subsequent
output channel up?
~Charlie
_____
Behalf Of
Michelle de la Vega
monitor
Also,
Michelle de la Vega
Cold Jet, LLC
USA
01CA403A.7824F810]
On
Charlie,
the
the
Kevin
but
I
that
> is?
> ~Charlie
I Uploaded a file it's in the tutorials folder.
~Charlie
_____
Ahmed
Sent: Monday, September 28, 2009 6:10 PM
Rob,
schema mismatch.
Ahmed
From: Rob Bucek <rbucek@dsmfg. <mailto:rbucek%40dsmfg.com> com>
To: vantage@yahoogroups <mailto:vantage%40yahoogroups..com> ..com
Ahmed,
Rob Bucek
FAX: (715)284-4084
Of Ahmed
Hi Rob,
Ahmed
Rob Bucek
FAX: (715)284-4084
Behalf
Of Charlie Wilson
file
tomorrow.
~Charlie
_____
On
Behalf Of
Rob Bucek
Charlie,
Rob Bucek
FAX: (715)284-4084
com/>
On
Behalf
Of Charlie Wilson
subsequent
output channel up?
~Charlie
_____
Behalf Of
Michelle de la Vega
monitor
Also,
Michelle de la Vega
Cold Jet, LLC
USA
01CA403A.7824F810]
On
Charlie,
the
the
Kevin
but
I
that
> is?
> ~Charlie
