BPM Question - Date Comparison
Sorry no clue on that one you will have to let some one else field that
question.
Take that rowmod = a out maybe cuz obviously you aren't adding one.
~Charlie
_____
melissa hietala
Sent: Monday, March 09, 2009 4:36 PM
Subject: Re: [Vantage] BPM Question - Date Comparison
Charlie,
Thanks for the response. This was my original plan of action as well,
however I am running into a problem with this. I am putting the following
code in the query:
for each ttJobHead where (ttJobHead.RowMod = 'U' or ttJobhead.RowMod = 'A')
each JobHead where JobHead.JobNum = ttjobhead.JobNum and
jobhead.ReqDueDate < ttjobhead.reqduedate no-lock
But when I go into Job Entry, change the reqduedate, and attempt to save the
record I get an error message that states:
"The field ttJobHead.AnalysisCdDescription does not have a valid data type."
This message does not come up if the BPM is disabled, so for some reason the
BPM is triggering this response. It appears to be choosing the first field
(chronological order) in the JobHead table and triggering this error
message.
Any thoughts on why this would be????
Thanks again,
Dustin Biniek
UMC, Inc.
DustinB@ultramc. <mailto:DustinB%40ultramc.com> com
From: Charlie Wilson <foamdesigncsw@ <mailto:foamdesigncsw%40yahoo.com>
yahoo.com>
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Sent: Monday, March 9, 2009 2:57:29 PM
Subject: RE: [Vantage] BPM Question - Date Comparison
for each ttJobHead
where (ttJobHead.RowMod = 'U' or ttJobhead..RowMod = 'A')
each JobHead
jobhead.date < ttjobhead.date
put this in for your query on a "number of rows in the 'query' is more than
0
you will have to adjust accordingly but hopefully this gets you on the right
path.
Basically this compares the old entry to the new entry. and returns rows
that qualify and if one quals the results will be more than 0 rows so it
will kick off your email.
Good luck
~Charlie
_____
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of
melissa hietala
Sent: Monday, March 09, 2009 3:48 PM
To: vantage@yahoogroups .com
Subject: [Vantage] BPM Question - Date Comparison
I currently have a BPM setup that sends an email out when the
"JobHead....ReqDueDa t e" changes. I now have a request to modify this BPM
so
that the email is only sent when the RequiredByDate moves forward in time.
For instance, if the ReqByDate was originally 5/1/2009 and has been pulled
forward to 4/1/2009, an email would be sent. But if the ReqByDate was
originally 4/1/2009 and has been pushed back to 5/1/2009, an email would NOT
be sent. Anyone been able to do something like this?
Dustin Biniek
UMC, Inc.
DustinB@ultramc. <mailto:DustinB% 40ultramc. com> com
No virus found in this incoming message.
Checked by AVG - www.avg.com
Version: 8.0.237 / Virus Database: 270.11.9/1991 - Release Date: 03/09/09
07:14:00
07:14:00
I currently have a BPM setup that sends an email out when the "JobHead..ReqDueDate" changes. I now have a request to modify this BPM so that the email is only sent when the RequiredByDate moves forward in time. For instance, if the ReqByDate was originally 5/1/2009 and has been pulled forward to 4/1/2009, an email would be sent. But if the ReqByDate was originally 4/1/2009 and has been pushed back to 5/1/2009, an email would NOT be sent.  Any ideas on how I can accomplish this?
Â
Dustin Biniek
UMC, Inc.
DustinB@...
Â
Dustin Biniek
UMC, Inc.
DustinB@...
Hi Dustin,
If you were using a BAM instead of a BPM, I *think* you could use:
"if oldJobHead.ReqDueDate < JobHead.ReqDueDate"
Prefixing "old" to any field holds the data before any change was
made.
I'm not sure if you can use this in a BPM though.
Might be of some help.
Nigel.
> Thanks
> Â
> Dustin Biniek
> UMC, Inc.
> DustinB@...
Thanks for the response Nigel. Unfortunately I wasn't able to get this to work. Are there any other ideas on how I can get this scenario to work? Any thoughts would be greatly appreciated!
Â
Dustin Biniek
UMC, Inc.
DustinB@...
Sent: Tuesday, February 10, 2009 11:39:56 AM
Subject: [Vantage] Re: BPM Question - Date Comparison
Hi Dustin,
"if oldJobHead.ReqDueDa te < JobHead.ReqDueDate"
made.
Nigel.
"JobHead..ReqDueDat e" changes. I now have a request to modify this
> Thanks
> Â
> Dustin Biniek
> UMC, Inc.
> DustinB@...
The only other thing I can think of would be to try and put a BPM in
place that actions on the loading of a Job, maybe using
JobEntry.GetByID. You could copy the ReqDueDate into a UD date field.
Then put another BPM in place on the Update BO that compares these
two dates and send your email based on the results.
Nigel.
> Thanks,
> Â
> Dustin Biniek
> UMC, Inc.
> DustinB@...
> From: Nigel Kerley <nigel.kerley@...>
> Hi Dustin,
> made.
> Nigel.
> --- In vantage@yahoogroups .com, melissa hietala <kevmel822@ ..>
this
sent.  Any ideas
> > Thanks
> > Â
> > Dustin Biniek
> > UMC, Inc.
> > DustinB@
I currently have a BPM setup that sends an email out when the "JobHead...ReqDueDat e" changes. I now have a request to modify this BPM so that the email is only sent when the RequiredByDate moves forward in time. For instance, if the ReqByDate was originally 5/1/2009 and has been pulled forward to 4/1/2009, an email would be sent. But if the ReqByDate was originally 4/1/2009 and has been pushed back to 5/1/2009, an email would NOT be sent.  Anyone been able to do something like this?
Dustin Biniek
UMC, Inc.
DustinB@...
for each ttJobHead
each JobHead
0
path.
Good luck
~Charlie
_____
melissa hietala
Dustin Biniek
UMC, Inc.
07:14:00
Charlie,
Thanks for the response. This was my original plan of action as well, however I am running into a problem with this. I am putting the following code in the query:
for each ttJobHead where (ttJobHead.RowMod = 'U' or ttJobhead.RowMod = 'A') ,
But when I go into Job Entry, change the reqduedate, and attempt to save the record I get an error message that states:
Â
This message does not come up if the BPM is disabled, so for some reason the BPM is triggering this response. It appears to be choosing the first field (chronological order) in the JobHead table and triggering this error message.
Â
Â
Thanks again,
Â
Dustin Biniek
UMC, Inc.
DustinB@...
for each ttJobHead
each JobHead
0
path.
Good luck
~Charlie
_____
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of
melissa hietala
"JobHead....ReqDueDa t e" changes. I now have a request to modify this BPM so
Dustin Biniek
UMC, Inc.
07:14:00
