Users want the date01 to update to Today() if checkbox01 = 0, then set checkbox01 to 1.
JobEntry has a lot of BPMs, but none sound like "PrintTraveler"
Am i looking in wrong BO?
Thanks for any help.
----- Original Message -----
Sent: Friday, October 24, 2008 3:39 PM
Subject: [Vantage] BPM question
I want to update jobhead.date01 with current date and set checkbox01 to 1 when someone tries to print a traveler from job entry.
That's a good point.
I was thinking because jobhead stores the field travelerlastprinted and travelerreadytoprint that the event was trappable somehow.
Any idea what object I'd look at to capture that?
I could also use a trigger on the database (We have SQL Server)
If I did that, is writing to data## or checkbox## fields safe in this manner?
Thanks for any advice,
Tony
Sent: Friday, October 24, 2008 3:54:53 PM
Subject: Re: [Vantage] BPM question
I don't believe you can capture an actions process using BPM. Those processes are not a part of the Job Business Object.
To: vantage@yahoogroups .com
don't see anything in the UI customization events about printing or
menus...all of the event hooks mentioned seem like they're ones inside
the window, not the window itself. I'd ask the tools guys at support if
there's a way to capture this event...you should be able to write your
own handler if you know what the event is called. I just didn't see
anything that stuck out at me in ObjectExplorer.
-bws
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix /
Picometrix
bspolarich@... ~ 734-864-5618 ~
www.advancedphotonix.com
Of Tony Hughes
Sent: Friday, October 24, 2008 5:25 PM
Charles,
manner?
I have a BPM pre-processing directive on the Part table that checks the Unit of Measure against a user defined table for validity. This works very well except that when I make changes to one of the related Part tables, e.g. Part Plant table, it triggers the BPM and the exception message is given as if the UOM is invalid. The directive uses a simply query to check validity. I assume there is something I am missing here since it appears updating one of the related Part tables signals an update to the Part Table without the "ttPart" data being available.
This is my query:
for each ttPart where (ttPart.RowMod = 'U' or ttPart.RowMod = 'A') , each UD04 where UD04.Company = ttPart.Company and UD04.Key1 = ttPart.IUM no-lock
Has anyone else run across this and if so how did you resolve the problem?
I have cleaned up the UOM fields in anticipation of converting to Epicor 9 and I would like to keep them clean.
Charles Carden
IT Manager
Manitex, Inc.
Georgetown, Texas
tab you are bumping the partservice.update method which is in turn firing
your BPM.
Turn on tracing and check out the data set. Your BPM is probably working and
telling you that what ever UOM is in the part is not valid.
~Charlie
_____
Charles Carden
Sent: Monday, September 28, 2009 9:49 AM
Version 8.03.408b.
This is my query:
Charles Carden
IT Manager
Manitex, Inc.
Georgetown, Texas
You are correct that multiple tables trigger the Part.Update method(13
tables in Epicor 9).
You will need a "For each tt?????" for every table you want the UOM
Validation to run.
Hope this helps,
Thank you,
Dale E. Schuerman
Senior Consultant
Epicor Certified Consulting Partner
RAM Software Systems, Inc.
Richardson,TX
972-669-0763 x233 (voice)
972-669-9603 (fax)
mailto:dale.schuerman@...
<BLOCKED::blocked::mailto:dale.schuerman@...> (email)
http://www.ramsys.com <BLOCKED::blocked::http://www.ramsys.com/>
(website)
Of Charles Carden
Sent: Monday, September 28, 2009 8:49 AM
Version 8.03.408b.
This is my query:
no-lock
problem?
Charles Carden
IT Manager
Manitex, Inc.
Georgetown, Texas
Attention:
This email message is privileged and confidential. If you are not the
intended recipient please delete the message and notify the sender.
Any views or opinions presented are solely those of the author.
This email message has been scanned for Viruses and Content and cleared
by MailMarshal SMTP
For more information go to http://www.ramsys.com
Charles Carden
IT Manager
Manitex, Inc.
Georgetown, Texas
Sent: Monday, September 28, 2009 9:20 AM
Subject: RE: [Vantage] BPM question
Charles,
Validation to run.
Hope this helps,
Thank you,
Dale E. Schuerman
Senior Consultant
Richardson,TX
972-669-9603 (fax)
(website)
Of Charles Carden
Version 8.03.408b.
This is my query:
no-lock
problem?
Charles Carden
IT Manager
Manitex, Inc.
Georgetown, Texas
Attention:
by MailMarshal SMTP
here's what i tried and none worked. any suggestions?
run lib\updatetablebuffer.p(input BUFFER QuoteHed:HANDLE, 'CheckOff1','False').
run lib\updatetablebuffer.p(input BUFFER QuoteHed:HANDLE, 'CheckOff1',False).
run lib\updatetablebuffer.p(input BUFFER QuoteHed:HANDLE, 'CheckOff1','0').
run lib\updatetablebuffer.p(input BUFFER QuoteHed:HANDLE, 'CheckOff1',0).
transaction set? (i.e. this bpm is not called from the quoteform)
assuming you are working from the quote form.. your line would be
Assign ttquotehed.CheckOff1 = False.
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-0590
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Of rec0rder
Sent: Tuesday, January 25, 2011 1:31 PM
I am trying to set a field to 0. I attempted the following line of BPM
code and its inserting the data as NULL, the SQL data shows that it
should be either a 0 or 1 since the DATATYPE is TINYINT.
'CheckOff1',False).
'CheckOff1','0').
'CheckOff1',0).
I am trying to create a BPM that will force users to select a Customer ID from a drop down list, rather than typing in their own text.
The drop down list is a UD field (Part.ShortChar06) which is populated with the Customer ID from a BAQ.
In my BPM I wanted my condition to read "the ttPart.ShortChar06 field of the changed row is not equal to (a value from the drop down list) then the action would display an error message. I am not sure how to accomplish the "not equal to a value from the drop down list"
Any suggestions? Please and thanks in advance.
Carol
Jose C Gomez
T: 904.469.1524 mobile
On Wed, Jan 14, 2015 at 10:24 AM, cmpelows@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p></p><p><span></span></p><p>I am trying to create a BPM that will force users to select a Customer ID from a drop down list, rather than typing in their own text.</p><p>The drop down list is a UD field (Part.ShortChar06) which is populated with the Customer ID from a BAQ.</p><p>In my BPM I wanted my condition to read "the ttPart.ShortChar06 field of the changed row is not equal to (a value from the drop down list) then the action would display an error message. I am not sure how to accomplish the "not equal to a value from the drop down list"</p><p>Any suggestions? Please and thanks in advance.</p><p>Carol</p><p></p> </div> <div style="color:#fff;min-height:0;"></div>
You have to hard code it. I think the property is DropDownStyle google it it’s part of the base MS Control I believe.
Joshua Giese
CIO
Direct: 920.593.8299
IT Dept: 920.437.6400 Ext. 337
Site ID: 27450-E905702A-SQL64
Wisconsin Converting, Inc.
Sent: Wednesday, January 14, 2015 11:10 AM
Thanks Jose for your response. I am using the BAQ combo, but am not seeing anything that would restrict typing text in the properties.
I use a post processing bpm on CustShip.GetMainfest Info to transfer Order information. You could transfer the check box there or possibly throw an error.
Greg
Sent: Wednesday, August 24, 2016 3:31 PM
To: yahoogroups
I am creating BPM to Stop Shipment if a checkbox is not checked. The problem is the check box is on the OrderHed. When I got to create the BPM ttOrderHed is not an option. Is there a way to add this tt?
I already have the checkbox displayed on ShipEntry using a Foreign key view.
I am thinking I may have to populate a checkbox on ShipHed from Order....
Any thoughts??
Thanks Kim
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6240 and immediately delete the communication.
On the Order Entry Summary there is a HOLD checkbox.
Note: If the Allow Shipments for Orders on Hold check box has been cleared for this company in the Company Configuration - Modules - Materials - Shipping/Receiving sheet, this prevents processing of shipments for sales orders that have been placed on hold. This affects shipment programs such as Customer Shipment Entry throughout the Epicor application. Sales order holds must first be removed in order to process shipments.
Miguel A. Santillan
Compass Manufacturing Systems
Sent: Wednesday, August 24, 2016 12:31 PM
To: yahoogroups <vantage@yahoogroups.com>
Any thoughts??
Thanks Kim
Disclaimer
The information contained in this communication from the sender is confidential. It is intended solely for use by the recipient and others authorized to receive it. If you are not the recipient, you are hereby notified that any disclosure, copying, distribution or taking action in relation of the contents of this information is strictly prohibited and may be unlawful.
