Dave,
If I am not mistaken, you will need to access the temp tables and link
them to the Quote tables...
for instance...
Find QuoteDtl Where (QuoteDtl.Company = ttOrderDtl.Company) and
(QuoteDtl.QuoteNum = ttOrderDtl.QuoteNum) and
(QuoteDtl.QuoteLine = ttOrderDtl.QuoteLine) no-lock.
Then you can access the related table.
Good luck,
Aaron Hoyt
Vantage Plastics
for instance...
Good luck,
Aaron Hoyt
Vantage Plastics
ofcwiz wrote:
>[Non-text portions of this message have been removed]
> We are entering data into the User Available field called "Number01"
> when we create a Quote. When in the Quote, we go to
> "Actions-Quote-Create Sales Order" to generate a SO from the Quote.
> I have created a BPM that uses the "SalesOrder.CreateOrderFromQuote"
> Pre-Processing Method Directive to pick up the Value from the
> "Number01" in the Quote and pass it to the "Number01" in the just
> created SO.
> The problem is that the 4GL code I want to execute in this Method
> Directive does not allow me to enter any code referencing the Quote.
> Anyone able to assist with this?
> Dave
