I will try this method. Thanks.
---In vantage@yahoogroups.com, <jlisser@...> wrote:I believe I handled this with a BAM in v8. The BAM was set up on the PORel table as a forward to the procedure. So if you put code into a .p file - test for PORel.PrimomiseDt = ? (null) and find first PoRel.DueDate using the company, ponum, poline and porel like you did in your code. It uses the same lib update too. I don't have the exact code anymore but that should get you close. You might have to bring the PORel table into the buffer at the beginning too.
Once I went to E9 I switched it over to a data directive though. Much easier.
---In vantage@yahoogroups.com, <juy@...> wrote:Thanks Greg. I forgot to mention that we are still in V8 so no DD for us but will be upgrading next year so I'll keep save this on my notes.
---In vantage@yahoogroups.com, <vantage@yahoogroups.com> wrote:
I have a DD that does this in 905.702
Greg
condition
number of rows in the 'Empty Promise date' query is not less than 1
Query
for each ttPORel where ttPORel.PromiseDt = ? and ttPORel.DueDate <> ?
Action
ABL:
for each ttPORel where ttPORel.PromiseDt = ? and ttPORel.DueDate <> ? no-lock.
If available ttPORel then do:
Assign ttPOrel.PromiseDt = ttPORel.DueDate.
End.
End.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of juy@...
Sent: Friday, November 01, 2013 4:25 PM
Subject: [Vantage] BPM - PORel Promise Date update from PORel Due Date
I am trying to create a BPM to automatically update the PORel Promise Date equal to the PORel Due Date on new POs. If the new PO was created either from the Generate PO Suggestions screen or from Purchase Order Entry, the Promise Date does not get updated unless the buyer actually change the Due Date under the Release tab. Here's what I have:
First I had this:
for each ttPODetail where ttPODetail.RowMod = 'A' no-lock.
find first ttPORel where
ttPORel.Company = ttPODetail.Company and
ttPORel.PONum = ttPODetail.PONum and
ttPORel.POLine = ttPODetail.POLine no-lock.
if available ttPORel then do:
assign ttPORel.PromiseDt = ttPODetail.CalcDueDate.
end.
end.
Then I had this:
for each ttPOHeader where ttPOHeader.RowMod = 'A' or ttPOHea der.RowMod = 'U' no-lock,
ttPODetail.Company = ttPOHeader.Company and
ttPODetail.PONum = ttPOHeader.PONum,
each ttPORel where
ttPODetail.Company = ttPORel.Company and
ttPODetail.PONum = ttPORel.PONum and
ttPODetail.POLine = ttPORel.POLine and
ttPORel.DueDate <> ttPORel.PromiseDt no-lock.
end.
The two BPMs above are on PO.Update
Then I have this on the POSugg.Update:
for each ttSugPODtl where ttSugPODtl.RowMod = 'A' no-lock.
find first PORel where
PORel.Company = ttSugPODtl.Company and
PORel.PONum = ttSugPODtl.PONum and
PORel.POLine = ttSugPODtl.POLine no-lock.
if available PORel then do:
RUN LIB\UpdateTableBuffer. p(input buffer PORel:HANDLE,'PromiseDt',ttSugPODtl.DueDate).
end.
No matter what I use, unless you actually change the Due Date on the Release tab, the promise date does not get updated. it seems that the PORel table does not have any connection to either the POHeader or the PODetail tables. Or maybe I am just doing this wrong.
Please help. Thank you.
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
