BPM Passing Varaible Value from Pre-Processing to Post-Processin
Can I ask for more details:
1. What do you mean by overide the base?
2. How should I call the super procedure? (in the 4GL code window or
using "forward to procedure" option within 4GL?)
or maybe you have some working example that is passing some variable so
I can look at it?
I am also pasting below unanswered question from my previus post:
In conditions menu (BPM) there is an option:
"the specific field of the changed row is equal to the specific value"
We can change "the changed row" to the one the following:
the added row
the updated row
the deleted row
the changed row
an unchanged row
some row
all rows
What is the difference between - "the updated row" and "the changed
row"?
Grzegorz Szczepański
Dnia Fri, 29 Aug 2008 22:23:35 +0100
"Stephen Edginton" <stephene@...> napisał(a):
> Use a pre processor directive to enable the post process and export
> in the post process.
> If you need to pass a variable etc, you can override the base
> Then call the super procedure if required.
> Behalf Of phoenix Sent: 29 August 2008 20:25
> To: vantage@yahoogroups.com
> Subject: Re: [Vantage] BPM Passing Varaible Value from Pre-Processing
> to Post-Processing
> Mark,
> CustID is know in both, pre and post process. But I don't need CustID,
> I need CustNum (you can change CustID, but you can't change CustNum
> which is unique index for customer).
> But you put very good question. In matter of fact, I don't need to do
> anything special in Pre-Processing, but until today I wasn't aware
> that I can aquire customer data in post processing. I can do this by
> searching in post processing rows where rowmod = "". Am I right?
> the added row
> the updated row
> the deleted row
> the changed row
> an unchanged row
> some row
> all rows
> row"?
> The whole scenario that I am trying to realize is:
> There is a 'set' of fields that I want to track; i.e. CustNum,
> Address1, Address2, Character01, etc. then
> IF New customer is added I want to export this set to file,
> and IF any of the fields within this set will be changed then I want
> to export to file the whole set again. If there will be a change in
> other fields which are not in the tracked set, then no action is
> required.
> Dnia Fri, 29 Aug 2008 08:02:02 -0400
> "Mark Wonsil" <mark_wonsil@... <mailto:mark_wonsil%40yahoo.com>
> > napisał(a):
> > Hi Grzegorz,
> > While passing a variable from the pre-process to the post-process is
> > an interesting problem in itself, what is the business problem that
> > you're trying to solve? What exactly are you trying to do with the
> > Customer record? Why can't all of your processing occur in the
> > Post-Process when you have the custnum? What are you doing in the
> > Pre-Process that won't be available in the Post-Process? Are they
> > really tied together?
> > BTW, Isn't CustID known at both in the Pre-Process and Post-Process?
> > Mark W.
> > > -----Original Message-----
> > > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > > <mailto:vantage%40yahoogroups.com> ] On Behalf Of phoenix Sent:
> > > Friday, August 29, 2008 5:26 AM To: robertb_versa@...
> > > <mailto:robertb_versa%40yahoo.com> ; vantage@yahoogroups.com
> > > <mailto:vantage%40yahoogroups.com> Subject: Re: [Vantage] BPM
> > > Passing Varaible Value from Pre-Processing to Post-Processing
> > > Robert,
> > > you wrote that if I "...brought all the needed assemblies into
> > > your application(s) and added UD07 as an FKV or Subtable...". Why
> > > should I do this? if I am just want to use UD07 as place for
> > > temporary variable, so I will be using it only in 4GL/BPM. That's
> > > why I wrote that UD07 is just another table like customer and
> > > other tables.
> > > INSERT statement is a combination of few other statements...
> > > according to 4GL reference:
> > > "INSERT statement
> > > Creates a new database record, displays the initial values for the
> > > fields in the record, prompts
> > > for values of those fields, and assigns those values to the
> > > record. The INSERT statement is a combination of the following
> > > statements: CREATE Creates an empty record buffer.
> > > DISPLAY Moves the record from the record buffer into the screen
> > > buffer and displays the contents of the buffer on the screen.
> > > PROMPT-FOR Accepts input from the user, and puts that input into
> > > the screen buffer.
> > > ASSIGN Moves data from the screen buffer into the record buffer."
> > > My first try was to use INSERT but vantage gives me error message,
> > > then I replaced INSERT with CREATE and ASSIGN, but still the same
> > > error.
> > > Have you ever tried to insert a new row in UD or any other table
> > > in 4GL within vantage? if so then you can show me your piece of
> > > code.
> > > Grzegorz Szczepanski
> > > Dnia Thu, 28 Aug 2008 09:06:21 -0700 (PDT)
> > > Robert Brown <robertb_versa@...
> > > <mailto:robertb_versa%40yahoo.com> > napisał(a):
> > > > I'm not sure what you mean by "just another table in Vantage as
> > > > Customer"... It is just another table (but doesn't have anything
> > > > inherently to do with Customer).
> > > > I agree that the CREATE & ASSIGN statements looks OK - but the
> > > > error message indicates otherwise.
> > > > If you replace CREATE with INSERT, does it help?
> > > > ...Maybe I'm comletely misinterpreting the error message... Is
> > > > it possible you are working on a db that has UD07 set
> > > > explicitly to read only?
> > > > Rob
> > > > --- On Thu, 8/28/08, phoenix <phoenix_@...
> > > > <mailto:phoenix_%40wp.pl> <mailto:phoenix_%40wp.pl> >
> > > wrote:
> > > > > From: phoenix <phoenix_@... <mailto:phoenix_%40wp.pl>
> > > > > <mailto:phoenix_%40wp.pl> > Subject: Re: [Vantage] BPM
> > > > > Date: Thursday, August 28, 2008, 11:15 AM
> > > > > Isn't it the UD07 just another table in Vantage as
> > > > > Customer?
> > > > > Isn't CREATE UD07 creating just one row in UD07?
> > > > > Dnia Thu, 28 Aug 2008 07:39:00 -0700 (PDT)
> > > > > > If you've brought all the needed assemblies into
> > > > > your application(s)
> > > > > > and added UD07 as an FKV or Subtable, why would you
> > > > > attempt to add it
> > > > > > again from within a BPM?
> > > > > > Your statements are trying to establish permanent
> > > > > relationships
> > > > > > within the db schema and the error message is
> > > > > correctly telling you
> > > > > > that you are not licensed to do so.
> > > > > > You want to read data from UD07 - not CREATE a
> > > > > permanent db level
> > > > > > schema change.
> > > > > > Rob
> > > > > from
> > > > > > > Pre-Processing to Post-Processing To:
> > > > > > > Cc: "Robert Brown"
> > > > > <robertb_versa@... <mailto:robertb_versa%40yahoo.com>
> > > > > > > Date: Thursday, August 28, 2008, 4:31 AM
> > > > > > > Robert,
> > > > > > > I was trying to do the 'worst case', as
> > > > > you
> > > > > > > adivced. Unfortunatelly I
> > > > > > > wasn't able to do this this way. When trying
> > > > > to use
> > > > > > > CREATE statement
> > > > > > > like below
> > > > > > > CREATE UD07.
> > > > > > > ASSIGN
> > > > > > > UD07.Key1 = ttCustomer.CustID.
> > > > > > > the following errors apears:
> > > > > > > The following application error was encountered:
> > > > > > > You may not compile programs that update the
> > > > > database in
> > > > > > > this version
> > > > > > > (490) **
> > > > > > > So still no way to pass value between
> > > > > pre-processing and
> > > > > > > post-processing. And I don't know even if
> > > > > above
> > > > > > > restriction is because
> > > > > > > of Vantage or because of limited Progress
> > > > > license.
> > > > > > > (I can use some of the already existing record
> > > > > and write
> > > > > > > data to UD
> > > > > > > Fields, but it makes the whole resolution very
> > > > > > > 'ugly').
> > > > > > > Grzegorz Szczepañski
> > > > > > > Dnia Mon, 25 Aug 2008 07:39:11 -0700 (PDT)
> > > > > napisaĹ(a):
> > > > > > > > Worst case: Save your variable value to an
> > > > > appropriate
> > > > > > > table ud field
> > > > > > > > in your preprocess and read it in your post
> > > > > process.
> > > > > > > > --- On Sun, 8/24/08, phoenix
> > > > > > > > Subject: [Vantage] BPM Passing Varaible
> > > > > Value from
> > > > > > > Pre-Processing to
> > > > > > > > Post-Processing To: vantage@yahoogroups.com
> > > > > > > > Date: Sunday, August 24, 2008, 6:23 PM
> > > > > > > > Is in any way to pass a Variable Value from
> > > > > > > Pre-Processing to
> > > > > > > > Post-Processing in BPM using 4GL?
> > > > > > > > I need to write to file a CustNum, but when
> > > > > new
> > > > > > > customer is created
> > > > > > > > in Pre-Processing (and Base-Processing too)
> > > > > CustNum =
> > > > > > > 0.
> > > > > > > > It is <> 0 when progress writes data
> > > > > to
> > > > > > > database. Which is in
> > > > > > > > Post-Processing.
> > > > > > > > Therefore I need to find a CustNum (in
> > > > > > > Post-Processing) having a
> > > > > > > > CustID (from Pre-Processing or
> > > > > Base-Processing) . This
> > > > > > > is the reason
> > > > > > > > why I need to pass a CustID from
> > > > > Pre-Processing to
> > > > > > > Post-Processing.
> > > > > > > > I was trying to use DEFINE NEW SHARED GLOBAL
> > > > > VARIABLE,
> > > > > > > but it doesn't
> > > > > > > > work for me bacause Vantage is complain that
> > > > > I
> > > > > > > can't use such type of
> > > > > > > > variable inside a nest procedure.
> > > > > > > > [Non-text portions of this message have been
> > > > > removed]
> > > > > > > > Useful links for the Yahoo!Groups Vantage
> > > > > Board are: (
> > > > > > > Note: You
> > > > > > > > must have already linked your email address
> > > > > to a yahoo
> > > > > > > id to enable
> > > > > > > > access. ) (1) To access the Files Section of
> > > > > our
> > > > > > > Yahoo!Group for
> > > > > > > > Report Builder and Crystal Reports and other
> > > > > > > 'goodies', please goto:
> > > > > http://groups.yahoo.com/group/vantage/files/.
> > > > > <http://groups.yahoo.com/group/vantage/files/>
> > > <http://groups.yahoo.com/group/vantage/files/.
> > > <http://groups.yahoo.com/group/vantage/files/> > (2) To
> > > > > > > search through
> > > > > > > > old msg's goto:
> > > > > > > http://groups.yahoo.com/group/vantage/messages
> > > <http://groups.yahoo.com/group/vantage/messages>
> > > > > (3) To
> > > > > > > > view links to Vendors that provide Vantage
> > > > > services
> > > > > > > goto:
> > > > > http://groups.yahoo.com/group/vantage/linksYahoo
> > > <http://groups.yahoo.com/group/vantage/linksYahoo> !
> > > > > > > Groups Links
> > > > > > > > vantage-unsubscribe@yahoogroups.com
> > > > > > > > <mailto:vantage-unsubscribe%40yahoogroups.com>
> > > > > > > > <mailto:vantage-
Is in any way to pass a Variable Value from Pre-Processing to
I need to write to file a CustNum, but when new customer is created
in Pre-Processing (and Base-Processing too) CustNum = 0.
It is <> 0 when progress writes data to database. Which is in
Post-Processing.
Therefore I need to find a CustNum (in Post-Processing) having a CustID
(from Pre-Processing or Base-Processing). This is the reason why I need
to pass a CustID from Pre-Processing to Post-Processing.
I was trying to use DEFINE NEW SHARED GLOBAL VARIABLE, but it doesn't
work for me bacause Vantage is complain that I can't use such type of
Worst case: Save your variable value to an appropriate table ud field in your preprocess and read it in your post process.
--- On Sun, 8/24/08, phoenix <phoenix_@...> wrote:
Subject: [Vantage] BPM Passing Varaible Value from Pre-Processing to Post-Processing
Post-Processing.
(from Pre-Processing or Base-Processing) . This is the reason why I need
Grzegorz Szczepa�ski
Thanks Robert...
anyone else have some other ideas?
> From: phoenix <phoenix_@...>
> Post-Processing.
> CustID (from Pre-Processing or Base-Processing) . This is the reason
> why I need to pass a CustID from Pre-Processing to Post-Processing.
> must have already linked your email address to a yahoo id to enable
> access. ) (1) To access the Files Section of our Yahoo!Group for
> Report Builder and Crystal Reports and other 'goodies', please goto:
> http://groups.yahoo.com/group/vantage/files/. (2) To search through
> old msg's goto: http://groups.yahoo.com/group/vantage/messages (3) To
> view links to Vendors that provide Vantage services goto:
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
Robert,
I was trying to do the 'worst case', as you adivced. Unfortunatelly I
wasn't able to do this this way. When trying to use CREATE statement
like below
CREATE UD07.
ASSIGN
You may not compile programs that update the database in this version
(490) **
So still no way to pass value between pre-processing and
post-processing. And I don't know even if above restriction is because
of Vantage or because of limited Progress license.
(I can use some of the already existing record and write data to UD
Fields, but it makes the whole resolution very 'ugly').
> Post-Processing.
Robert,
should I do this? if I am just want to use UD07 as place for temporary
variable, so I will be using it only in 4GL/BPM. That's why I wrote
that UD07 is just another table like customer and other tables.
INSERT statement is a combination of few other statements... according
to 4GL reference:
"INSERT statement
for values of those fields, and assigns those values to the record.
The INSERT statement is a combination of the following statements:
the screen buffer.
My first try was to use INSERT but vantage gives me error message, then
I replaced INSERT with CREATE and ASSIGN, but still the same error.
Have you ever tried to insert a new row in UD or any other table in
4GL within vantage? if so then you can show me your piece of code.
> I agree that the CREATE & ASSIGN statements looks OK - but the error
> ...Maybe I'm comletely misinterpreting the error message... Is it
> possible you are working on a db that has UD07 set explicitly to read
> only?
> Rob
> > Pre-Processing to Post-Processing To: robertb_versa@...
> > Customer?
> > your application(s)
> > attempt to add it
> > relationships
> > permanent db level
> > > schema change.
> > > Rob
> > from
> > > > Cc: "Robert Brown"
> > <robertb_versa@...>
> > > > Robert,
> > you
> > to use
> > > > CREATE statement
> > > > like below
> > > > CREATE UD07.
> > > > ASSIGN
> > database in
> > > > this version
> > > > (490) **
> > pre-processing and
> > above
> > license.
> > and write
> > > > data to UD
> > > > 'ugly').
> > napisaĹ(a):
> > appropriate
> > > > table ud field
> > process.
> > <phoenix_@...>
> > Value from
> > > > Pre-Processing to
> > > > Pre-Processing to
> > new
> > > > customer is created
> > CustNum =
> > > > 0.
> > to
> > > > > Post-Processing.
> > > > is the reason
> > Pre-Processing to
> > > > Post-Processing.
> > VARIABLE,
> > > > but it doesn't
> > I
> > removed]
> > Board are: (
> > > > Note: You
> > to a yahoo
> > > > id to enable
> > our
> > > > Yahoo!Group for
> > > > search through
> > > > > old msg's goto:
> > (3) To
> > services
> > > > goto:
> > > > Groups Links
Hi Grzegorz,
While passing a variable from the pre-process to the post-process is an interesting problem in itself, what is the business problem that you're trying to solve? What exactly are you trying to do with the Customer record? Why can't all of your processing occur in the Post-Process when you have the custnum? What are you doing in the Pre-Process that won't be available in the Post-Process? Are they really tied together?
Mark W.
> Of phoenix
> Sent: Friday, August 29, 2008 5:26 AM
> To: robertb_versa@...; vantage@yahoogroups.com
> Subject: Re: [Vantage] BPM Passing Varaible Value from Pre-Processing to
> Post-Processing
> Robert,
> to 4GL reference:
> "INSERT statement
> the screen buffer.
> Robert Brown <robertb_versa@... <mailto:robertb_versa%40yahoo.com> >
> > only?
> > Rob
> > --- On Thu, 8/28/08, phoenix <phoenix_@... <mailto:phoenix_%40wp.pl> >
> wrote:
> > > From: phoenix <phoenix_@... <mailto:phoenix_%40wp.pl> >
> > > Customer?
> > > your application(s)
> > > attempt to add it
> > > relationships
> > > permanent db level
> > > > schema change.
> > > > Rob
> > > from
> > > > > Cc: "Robert Brown"
> > > > > Robert,
> > > you
> > > to use
> > > > > CREATE statement
> > > > > like below
> > > > > CREATE UD07.
> > > > > ASSIGN
> > > database in
> > > > > this version
> > > > > (490) **
> > > pre-processing and
> > > above
> > > license.
> > > and write
> > > > > data to UD
> > > > > 'ugly').
> > > napisaĹ(a):
> > > appropriate
> > > > > table ud field
> > > process.
> > > Value from
> > > > > Pre-Processing to
> > > > > Pre-Processing to
> > > new
> > > > > customer is created
> > > CustNum =
> > > > > 0.
> > > to
> > > > > > Post-Processing.
> > > > > is the reason
> > > Pre-Processing to
> > > > > Post-Processing.
> > > VARIABLE,
> > > > > but it doesn't
> > > I
> > > removed]
> > > Board are: (
> > > > > Note: You
> > > to a yahoo
> > > > > id to enable
> > > our
> > > > > Yahoo!Group for
> <http://groups.yahoo.com/group/vantage/files/.> (2) To
> > > > > search through
> > > > > > old msg's goto:
> > > (3) To
> > > services
> > > > > goto:
> > > > > Groups Links
> > > > > > vantage-unsubscribe@yahoogroups.com <mailto:vantage-
Mark,
anything special in Pre-Processing, but until today I wasn't aware that
the added row
the updated row
the deleted row
the changed row
an unchanged row
some row
all rows
row"?
There is a 'set' of fields that I want to track; i.e. CustNum, Address1,
and IF any of the fields within this set will be changed then I want to
export to file the whole set again. If there will be a change in other
fields which are not in the tracked set, then no action is required.
"Mark Wonsil" <mark_wonsil@...> napisał(a):
> Hi Grzegorz,
> Mark W.
> > Behalf Of phoenix
> > Robert,
> > why I wrote that UD07 is just another table like customer and other
> > tables.
> > "INSERT statement
> > the screen buffer.
> > error.
> > > read only?
> > > Rob
> > > > Customer?
> > > > your application(s)
> > > > attempt to add it
> > > > relationships
> > > > permanent db level
> > > > > schema change.
> > > > > Rob
> > > > from
> > > > > > Cc: "Robert Brown"
> > > > > > Robert,
> > > > you
> > > > to use
> > > > > > CREATE statement
> > > > > > like below
> > > > > > CREATE UD07.
> > > > > > ASSIGN
> > > > database in
> > > > > > this version
> > > > > > (490) **
> > > > pre-processing and
> > > > above
> > > > license.
> > > > and write
> > > > > > data to UD
> > > > > > 'ugly').
> > > > napisaĹ(a):
> > > > appropriate
> > > > > > table ud field
> > > > process.
> > > > Value from
> > > > > > Pre-Processing to
> > > > > > Pre-Processing to
> > > > new
> > > > > > customer is created
> > > > CustNum =
> > > > > > 0.
> > > > to
> > > > > > > Post-Processing.
> > > > > > is the reason
> > > > Pre-Processing to
> > > > > > Post-Processing.
> > > > VARIABLE,
> > > > > > but it doesn't
> > > > I
> > > > removed]
> > > > Board are: (
> > > > > > Note: You
> > > > to a yahoo
> > > > > > id to enable
> > > > our
> > > > > > Yahoo!Group for
> > > > > > search through
> > > > > > > old msg's goto:
> > > > (3) To
> > > > services
> > > > > > goto:
> > > > > > Groups Links
Use a pre processor directive to enable the post process and export in the post process.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of phoenix
Subject: Re: [Vantage] BPM Passing Varaible Value from Pre-Processing to Post-Processing
Mark,
the added row
the updated row
the deleted row
the changed row
an unchanged row
some row
all rows
row"?
"Mark Wonsil" <mark_wonsil@... <mailto:mark_wonsil%40yahoo.com> > napisał(a):
> Hi Grzegorz,
> Mark W.
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> > Behalf Of phoenix
> > To: robertb_versa@... <mailto:robertb_versa%40yahoo.com> ; vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > Robert,
> > tables.
> > "INSERT statement
> > the screen buffer.
> > error.
> > > read only?
> > > Rob
> > wrote:
> > > > From: phoenix <phoenix_@... <mailto:phoenix_%40wp.pl> <mailto:phoenix_%40wp.pl> >
> > > > Pre-Processing to Post-Processing To: robertb_versa@... <mailto:robertb_versa%40yahoo.com>
> > > > Customer?
> > > > your application(s)
> > > > attempt to add it
> > > > relationships
> > > > permanent db level
> > > > > schema change.
> > > > > Rob
> > > > from
> > > > vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> > > > > > Cc: "Robert Brown"
> > > > <robertb_versa@... <mailto:robertb_versa%40yahoo.com> <mailto:robertb_versa%40yahoo.com> >
> > > > > > Robert,
> > > > you
> > > > to use
> > > > > > CREATE statement
> > > > > > like below
> > > > > > CREATE UD07.
> > > > > > ASSIGN
> > > > database in
> > > > > > this version
> > > > > > (490) **
> > > > pre-processing and
> > > > above
> > > > license.
> > > > and write
> > > > > > data to UD
> > > > > > 'ugly').
> > > > napisaĹ(a):
> > > > appropriate
> > > > > > table ud field
> > > > process.
> > > > Value from
> > > > > > Pre-Processing to
> > > > > > > Post-Processing To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > > > > > Pre-Processing to
> > > > new
> > > > > > customer is created
> > > > CustNum =
> > > > > > 0.
> > > > to
> > > > > > > Post-Processing.
> > > > > > is the reason
> > > > Pre-Processing to
> > > > > > Post-Processing.
> > > > VARIABLE,
> > > > > > but it doesn't
> > > > I
> > > > removed]
> > > > Board are: (
> > > > > > Note: You
> > > > to a yahoo
> > > > > > id to enable
> > > > our
> > > > > > Yahoo!Group for
> > > > http://groups.yahoo.com/group/vantage/files/. <http://groups.yahoo.com/group/vantage/files/>
> > <http://groups.yahoo.com/group/vantage/files/. <http://groups.yahoo.com/group/vantage/files/> > (2) To
> > > > > > search through
> > > > > > > old msg's goto:
> > > > (3) To
> > > > services
> > > > > > goto:
> > > > > > Groups Links
> > > > > > > vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe%40yahoogroups.com> <mailto:vantage-
