Hi
I have the following piece of code,
var FTPN = Db.UD109
.Where(x => x.Company == callContextClient.CurrentCompany &&
x.Key1 == ds.PODetail[0].PartNum)
.Select(y => y.Character01)
.ToList();
// Store the list as a comma-separated string or "NOT FOUND" if no matches
this.FamilyToolList = FTPN.Any()
? string.Join(", ", FTPN)
: "NOT FOUND";
If the code works as I expect. I am looking up the part number that is entered into the PODetail and returning any matching results from the UD109 table.
This may be one row or multiple rows, which is why I am returning the data as a list and converting it to a string and then store this in a variable FamilyToolList.
When I run this BPM on the PO.ChangeDetailPartNum I get the following error,
BPM runtime caught an unexpected exception of âNotSupportedExceptionâ type.
See more info in the Inner Exception section of Exception Details.
Business Layer Exception
Error Detail
Correlation ID: c09d0bd8-fede-41ea-9d25-ff1367c43a57
Description: BPM runtime caught an unexpected exception of âNotSupportedExceptionâ type.
Program: EntityFramework.dll
Method: Translate
Table: undefined
Field: undefined
Is there a way of finding our more about this error? Or does anyone know what is causing the error?
