BPM not firing on a user defined field - Vantage 8.03
Yes, it was introduced somewhere between 9.05.602 and 607A.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Mike Abell
Sent: Thursday, January 30, 2014 10:04 AM
Subject: RE: [Vantage] RE: BPM not firing on a user defined field - Vantage 8.03
I’m on Vantage 8.03, not sure what “Update Master” is (I’m guessing it’s a E9 thing)…
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Joe Englert
Sent: Thursday, January 30, 2014 9:02 AM
Not sure what version you’re on but, maybe UpdateMaster has taken Update’s place for that BO.
Sent: Thursday, January 30, 2014 9:59 AM
Joe, no.  I simply assumed that since my user defined field I’m using (ShortChar01) is located in the GLAcct table and that particular table is the ONLY one that I’m updating with my customization, the GLAcct BO “should” have been the right BO to work with.   There aren’t really any more when I look through the list of BO’s I would think it should be.  Nonetheless, as I said, it certainly isn’t firing at all.  I’m at a loss…..
Sent: Thursday, January 30, 2014 8:52 AM
Have you done a trace to make sure you’re looking at the right bo/method?
Sent: Thursday, January 30, 2014 9:48 AM
This is strange.  It won’t even fire with a conditionless BPM.  Not sure what I am doing wrong.  I’m simply creating a BPM on the Update method directive of the the GLAcct Business Object.  I then go into the Chart of Accounts dialog box, pull up an account, and change a description and save but this doesn’t fire on either the PRE or POST processing messages I have setup.  I KNOW the GLAcct table is the correct table I need but it acts like the BPM thinks it should be something else.  Any ideas?????
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of jckinneman@...
Sent: Wednesday, January 29, 2014 6:17 PM
Subject: [Vantage] RE: BPM not firing on a user defined field - Vantage 8.03
Can you get a message to come up on the method wihtout trapping the UD field?  For example a condition-less BPM that only has an action which is an informational message.  If you can get that slowly work up to trapping the change on the UD field. Start by building a condition based on just the Rowmod, then add the condition on the UD field.
If things stop working post your condition code so we can take a look at it.
Jim Kinneman
Encompass Solutions, Inc
I’ve added a ComboBox customization to the Chart of Accounts setup dialog that is just a dropdown list that I want a mandatory selection made from when entering or updating a GL Acct.  I assigned the CobmBox data to the ShortChar01 field in the GLAcct table.  I then went to create a BPM on the update method of GLAcct that basically looks for a “” character in GlAcct.ShortChar01 (meaning no selection was made) and it SHOULD throw a message saying a selection needs to be made before the record can be updated.  For some reason, no matter what I use in the BPM that references this GlAcct.ShortChar01 field, the BPM either isn’t working or doesn’t fire and always allows the record to be updated/saved.  I’ve done similar BPM’s before using stock Vantage fields in different tables but never using a “user defined” variable and also never used GLAcct until now.  Anyone know what my problem might be???
Mike Abell
Information Technology Manager
Flexial - BOA Group - Cookeville, Tennessee
Office:   931.432.8408
Mobile:  615.418.3055
email:  MAbell@...
Try using extended properties maintenance required and see if that helps
On Jan 28, 2014 6:04 PM, "Mike Abell" <mabell@...> wrote:
<div>
  <p>
Mike Abell
email:  MAbell@…
</div>
<div style="color:#fff;min-height:0;"></div>
Jose, where exactly is this selection?  I see no “Extended Properties Maintenance” required.
Mike Abell
email:  MAbell@...
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jose Gomez
Sent: Wednesday, January 29, 2014 5:33 AM
To: Vantage
Subject: Re: [Vantage] BPM not firing on a user defined field - Vantage 8.03
Mike Abell
email:  MAbell@...
Oh shoot didn't see you were on 8.x not available there sorry :(
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
On Wed, Jan 29, 2014 at 5:07 PM, Mike Abell <mabell@...> wrote:
<div>
  <p>
Mike Abell
email:  MAbell@...
To: Vantage
Mike Abell
email:  MAbell@...
</div>
Jim Kinneman
Jim Kinneman
Jim Kinneman
Jim Kinneman
Jim Kinneman
Jim Kinneman
