Anybody successfully able to create a BPM(s) that works in both Mass Receipt vs Receipt Line.
I am trying to update a Part_UD field with OurQty from the receipt.
If I use GetDtlQtyInfo it works correctly and updates for each new receipt line, but if it is a mass receipt it updates all parts with the last quantity changed.
Now the Mass Receipt after calling GetDtlQtyInfo then calls CommitRcvDtl.
If I put my BPM on that Method it works correctly for the Mass Receipt, but obviously not when each line is received as it is not called then.
For simplicity and testing I was just updating the NetWeight field. Below is on CommitRcvDtl. The only difference for the GetDtlQtyInfo is that netWeight = ttRcvDtlRow.OurQty since it is 0 on the mass receipt until committed.
Erp.Tables.Part Part;
foreach(var ttRcvDtl_Row in ttRcvDtl)
using (var txscope = IceDataContext.CreateDefaultTransactionScope())
var ttRcvDtlRow = ttRcvDtl_Row;
Part = (from Part_Row in Db.Part.With(LockHint.UpdLock) where string.Compare(Part_Row.PartNum, ttRcvDtlRow.PartNum,true) == 0 select Part_Row).FirstOrDefault();
Part.NetWeight = inputOurQty;
Db.Validate();
txscope.Complete();
