BPM Jumping Off Point for Setting a Default Shipping Comment in Customer Shipment Entry
Hello - I am trying to set a default shipping comment upon save when a pack line is entered during customer shipment entry. The shipping comment would be saved in a ShipTo UD field. Because the ShipTo table isn’t included in the BO.CustShip.UpdateMaster method directive, does this mean I am going to need to figure out how to do this with a custom code widget? I’d like to be able to avoid that, as I am still kind of green when it comes to C# and would feel better if there is an out of the box solution using Epicor’s widgets.
I’m not looking for step by step guidance, I’m just wondering if what I am attempting to do would be possible with the widgets in the workflow designer or if the only way to accomplish this would be using some C#. Is it possible to somehow set a variable for an unrelated table?
My end goal is more or less this when a pack line is saved:
UPDATE ShipDtl sd
JOIN ShipTo st on sd.MFShipToNum = st.ShipToNum and sd.CustNum = st.CustNum
SET sd.ShipComment = st.CustomField
WHERE sd.ShipToNum = whatever shipto number the associated pack slip is for (I can assign a variable no problem)
Invoke BO method to pull the shipto data in?
Update field by Query?
If that is the case, I assume I will need to pass some parameters?
Apologies, I am scatterbrained today and misread your post, and edited my original reply like twice until it dawned on me. Have you tried an update table by query widget? I believe that’s the canned tool for this kind of thing.
No worries, I appreciate you taking the time to read this. I will look into the update by query widget, thanks!
