Does anyone have a BPM that will prevent a quote from being saved when a line on the quote has a zero quantity?
Any help will be greatly appreciated.
Adrian.
Adrian.
You can write a BPM on Business object Quote , -> Method - Update - > new processing - > Your BPM Name…
Create two different condition for added / updated quote line where unit price should be > 0 means 1 or above.
Chek below screenshots…
1-
2-
Good luck
That’s perfect, just what I was after. Thanks Prakash.
Regards
Adrian.
The only problem is that when I enter a part configurator on the line I get
the message before I get a chance to configure the item. Should I move it
to post-processing instead?
Regards
Adrian
yes sure… u can give a try…
