BPM - Generate BAQReport via Execute Custom Code
When I attempt to select my BAQReport report style within the “Auto Print” option, it says that this is not supported. We are still running an older version of E10 so perhaps this has been added in newer versions. However, i’m stuck at the moment.
Does anyone have code that they could share that would generate a BAQ Report via the “Execute Custom Code” option within the BPM Workflow Designer? With some help from others in this forum, I’ve been able to accomplish this within a dashboard. However, the options with the “Execute Custom Code” do not seem to be as user friendly as when using the normal script editor.
Josh
