BPM for quoting
So far I haven't. Though I am going to the .400 level later this year and I
will see if that forces me to re-do this.
Scott Litzau, MCP
Olympus Flag & Banner
Information Systems Manager
scott.litzau@...
P: 414-365-9732
F: 414-355-1931
Dale R. Kalsow
Sent: Wednesday, July 02, 2008 9:58 AM
Subject: RE: [Vantage] BPM for quoting
Scott,
When you do updates do you have to redo your customization?
Of Scott Litzau
I set mine up using VB in customization. I copied this from some Epicor
documentation somewhere.
Private Sub OrderDtl_BeforeFieldChange(ByVal sender As object, ByVal
args As
DataColumnChangeEventArgs) Handles OrderDtl_Column.ColumnChanging
'// ** Argument Properties and Uses **
'// args.Row("[FieldName]")
'// args.Column, args.ProposedValue, args.Row
'Add Event Handler Code
Select Case args.Column.ColumnName
Case "PartNum"
Dim val As String = args.ProposedValue
Dim whereClause as String = "PartNum = '" + val + "'"
Dim recSelected As Boolean
Dim dsSearch as DataSet
If (val <> String.Empty) Then dsSearch =
Epicor.Mfg.UI.FormFunctions.SearchFunctions.listLookup(OTrans,"PartAdapt
er",
recSelected,False,whereClause)
If (recSelected = False) Then
MessageBox.Show("Part does not exist")
Throw new UIException()
End If
Case Else
End Select
End Sub
Scott
Behalf Of
Dale R. Kalsow
Sent: Wednesday, July 02, 2008 9:30 AM
I see it lost my print screens. Let's see if I can send it this way.
Behalf
Of Dale R. Kalsow
Sent: Wednesday, July 02, 2008 9:28 AM
Thanks that's a big help. I am working on getting your example two work
and have to issues I was wondering if you could help me on:
1) I get the error message when it finds the part in the part
master not the other way around.
2) I am not getting the part field to clear.
Have are some print screens of what I currently have.
Thanks!
Behalf
Of Daniel Laidig
Sent: Wednesday, July 02, 2008 9:10 AM
Yeah, we did this exact same thing using BPM for Sales Orders. I haven't
gotten around to doing that to the quotes.
1. The method we used was preprocessing SalesOrder.ChangePartNum.
2. I had a condition with a query that checked the database for the part
they entered:
for each ttOrderDtl where (ttOrderdtl.RowMod <> '') no-lock , each Part
where (ttOrderDtl.Company = Part.Company and ttOrderDtl.PartNum =
Part.PartNum) no-lock
3. My action then was to show an informational message that said an
invalid
part was entered and I also set the changed partnumber field to be "".
Hope this helps.
Daniel
_____
Behalf Of
Dale R. Kalsow
Sent: Wednesday, July 02, 2008 9:46 AM
Subject: [Vantage] BPM for quoting
I need a BPM that when a quote is created the system will validate if
the part is in the part master and if it is not the user cannot
continue. Has anyone done anything like this? Is there a better way of
accomplishing this?
Thanks for everyone's help J
Dale
have
and
Does anyone know how to customize one of the MES buttons to print a
custom Crystal report?
Kersten
accomplishing this?
Dale
Yes, as long as the report is a BAQ Report. You need to hang that BAQ
report off the menu somewhere in the main UI. Then you'll have its menu
ID.
It's not easy, by any means, however.
You'll need to add this code to a button-click event and modify it.
Only add the line that starts with "ProcessCaller"....
Try this:
Private Sub btnInspProcCust_Click(ByVal Sender As Object, ByVal Args As
System.EventArgs) Handles btnInspProcCust.Click
'// ** Place Event Handling Code Here **
ProcessCaller.LaunchForm(MESMenu,"MENUID")
End Sub
All you have to do is make sure that you add your BAQ report to a menu
and then call that menu and custom function out.
Vic Drecchio
ERP Administrator
TIMCO Aviation Services
Greensboro, NC
Email: vic.drecchio@...
Office: 336.668.4410 x3091
Mobile: 704.530.3092
Of kam4085
Sent: Wednesday, July 02, 2008 9:42 AM
Subject: [Vantage] MES Button Customization
Kersten
and what if it isn't a BAQ report..is that not possible?
Kersten MacLennan
IT/ERP Analyst
Semrock, Inc.
3625 Buffalo Rd.,
Suite 6
Rochester, NY 14624
585-594-7009
585-594-7095 fax
kmaclennan@...
The Standard in Optical Filters for Biotech & Analytical Instrumentation
Hundreds of Thousands of Ion Beam Sputtered filters delivered -
extensive inventory now!
The information contained in this message and any attachments may be
privileged, confidential, and protected from disclosure. If the reader
of this message is not the intended recipient, or any agent responsible
for delivering this message to the intended recipient, you are hereby
notified that any dissemination, distribution, or copying of this
communication may be unlawful and therefore strictly prohibited. If you
received this message in error, please reply to the message and delete
it. Thank you
Of Vic Drecchio
Sent: Wednesday, July 02, 2008 9:56 AM
Subject: RE: [Vantage] MES Button Customization
ID.
Try this:
End Sub
Vic Drecchio
ERP Administrator
Greensboro, NC
Email: vic.drecchio@... <mailto:vic.drecchio%40timco.aero>
Behalf
Of kam4085
Kersten
they entered:
3. My action then was to show an informational message that said an invalid
Hope this helps.
Daniel
_____
Dale R. Kalsow
accomplishing this?
Dale
I think you should be able to create it as a SubProcess Menu item instead of
actually making a menu on the Vantage screen. Then call it same way with
code.
_____
Kersten MacLennan
Sent: Wednesday, July 02, 2008 10:03 AM
Kersten MacLennan
IT/ERP Analyst
Semrock, Inc.
3625 Buffalo Rd.,
Suite 6
Rochester, NY 14624
585-594-7009
585-594-7095 fax
kmaclennan@semrock. <mailto:kmaclennan%40semrock.com> com
it. Thank you
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf
Of Vic Drecchio
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
ID.
Try this:
End Sub
Vic Drecchio
ERP Administrator
Greensboro, NC
Email: vic.drecchio@ <mailto:vic.drecchio%40timco.aero> timco.aero
Behalf
Of kam4085
Kersten
Thanks!
Of Daniel Laidig
they entered:
invalid
Hope this helps.
Daniel
_____
Behalf Of
Dale R. Kalsow
accomplishing this?
Dale
Of Dale R. Kalsow
Thanks!
Behalf
Of Daniel Laidig
they entered:
invalid
Hope this helps.
Daniel
_____
Behalf Of
Dale R. Kalsow
accomplishing this?
Dale
Private Sub OrderDtl_BeforeFieldChange(ByVal sender As object, ByVal args As
Case "PartNum"
Epicor.Mfg.UI.FormFunctions.SearchFunctions.listLookup(OTrans,"PartAdapter",
End If
Case Else
End Select
End Sub
Scott
Dale R. Kalsow
Of Dale R. Kalsow
Thanks!
Behalf
Of Daniel Laidig
they entered:
invalid
Hope this helps.
Daniel
_____
Behalf Of
Dale R. Kalsow
accomplishing this?
Dale
Scott,
Of Scott Litzau
args As
Case "PartNum"
er",
End If
Case Else
End Select
End Sub
Scott
Behalf Of
Dale R. Kalsow
Behalf
Of Dale R. Kalsow
Thanks!
Behalf
Of Daniel Laidig
they entered:
invalid
Hope this helps.
Daniel
_____
Behalf Of
Dale R. Kalsow
accomplishing this?
Dale
have
and
