Ramsey,
SetExtendedProperties should be sufficiently 'upgrade-resistant' as it is dealing with the properties of a specific native application dataview column (displayed in a UI control field).
If (or should I say when?) Epicor fundamentally changes a dataview, there is always risk that the dataview.field you are manipulating may have been changed.
However, it is LESS sensitive than direct manipulation of UI control properties as the native controls tend to have much more frequent changes made to the BO/methods tied to them.
Use of VB net before/after BO method event triggers (and, even worse, EpiDateViewNotifications based on record changes) are easily broken - so when ever possible, this 'trigger type' of application behavior modification is better done on the server withs BPMs. (Not always practical unfortunately.)
In the days that have passed, I've kind of lost the thread of what you are doing (but I seem to recall it was a copy/paste issue from a grid control displaying SupplierPriceList data in Purchasing Advisor... Yes?)
I haven't tested, but try this:
In the application module's InitializeCustomCode() Sub, add a call to a SetExtendedProps() Sub as shown below:
Sub InitializeCustomCode()
'// ** Wizard Insert Location - Do not delete 'Begin/End Wizard Added Variable Intialization' lines **
'// Begin Wizard Added Variable Intialization
'// End Wizard Added Variable Intialization
'// Begin Custom Method Calls
'// End Custom Method Calls
SetExtendedProps()
End Sub
Now create the Sub being called - something like this:
Private Sub SetExtendedProps()
Dim edvSupPrcLst As EpiDataView = CType(oTrans.EpiDataViews("SupplierPriceList"), EpiDataView)
If edvSupPrcLst.dataView.Table.Columns.Contains("VendorID") Then
edvSupPrcLst.dataView.Table.Columns("VendorID").ExtendedProperties("ReadOnly") = False
edvSupPrcLst.dataView.Table.Columns("VenPartNum").ExtendedProperties("ReadOnly") = False
End If
End Sub
That code should set the VendorID & VenPartNum fields to readonly=false as long as you haven't over-ridden it at the db or BO/method level using user role security.
Give it a go in your test db. As long as the app's controls (or BO/methods) don't get too much in the way, it should work.
If it doesn't work (and sometimes it doesn't - because of those pesky controls), you may have to set up a Sub that is triggered by the event of specific data.column changes in readonly properties. (Custom Object Explorer gives decent basic code examples.)
You can also attempt to use (really - trick) the row rules wizard to get the desired behavior. (Too messy for an email without knowing specifically what you are trying to do.)
The last resort is to manipulate the grid control itself with hand written code - making sure it can be selected by user (CanSelect = true), IsEnabled, etc.,.
...Much messier (if required to 'defeat' the native application behavior)... Try forcing readonly=false 1st - and keep your fingers crossed for luck that it works! (;o
Rob
--- On Thu, 3/12/09, alldoneprojects <ramsey@...> wrote:
Subject: [Vantage] Re: Vantage Revision Control In 8.03.305K
Date: Thursday, March 12, 2009, 8:04 PM
Hi Rob,
Those are some good ideas and I'm into making it slick but for this part my scope is to keep it as vanilla as possible.
Would you say the SetExtendedProperti es would be the most upgrade-resistant method? If so an example would be greatly appreciated!
Cheers,
-Ramsey
--- In vantage@yahoogroups .com, Robert Brown <robertb_versa@ ...> wrote:
> No qty breaks is good!
> Weird about the no copy/paste.. . Never ran into that (even with read only columns). Must be something they did to that specific grid control. (It sounds like they made the column you want to copy from inactive - not just readonly.)
> I've never tried it on a grid, but you can create a SetExtendedProperti es Sub that (on every other type of control) has never failed to allow me to force a normally readonly or inactive control to be editable.
> If you have the programming user guide (well worth it if you don't), it explains the syntax pretty well. Not connected to work right now or I could give you a quick example. (Let me know if you need it... Be glad to do so tomorrow.)
> Instead of Purchasing advisor (really just a Tracker), maybe you should set up right click menu access (if not already there natively) to Supplier-Part Price list. It would definitely be copyable from there.
> If you really want to get slick about it, see what assemblies & business objects are used in supplier-part price list (and data views) & add them to PO Entry. Dateviews can be brought in as foreign key views or using searchbyID VB code... FKVs easier to maintain if you can create a clear path to the right table - often takes several table connections to get to the one you really want (which end up being subtable views from the FKV(s)) - but worth it as then you don't have to worry about code breaking when you upgrade.
> Doing this would allow you to make the selection right in PO entry w/ no copy/paste & extra windows open.
> (All depends if that is really a time saver in the long haul as nearly all customizations are doomed to break eventually after enough upgrades... Same with BPMs.)
> Rob
> --- On Wed, 3/11/09, alldoneprojects <ramsey@...> wrote:
> From: alldoneprojects <ramsey@...>
> To: vantage@yahoogroups .com
> Date: Wednesday, March 11, 2009, 6:58 PM
> Thankfully we don't rely on the price breaks as we in one way or another wind up getting a quote from the supplier for each PO.
> So, being able to access the supplier price list from Purchase Advisor should suffice for now...BUT, in yet another example of what seems to be attacks aimed directly at me by the developers, you can't copy the Supplier Part Number field from Purchase Advisor! I've gone so far as to cusotmize it visible and not read-only in the grid list (not there at all by default), but you can't copy it from the grid or the detail under it (value shows but it's greyed out) any ideas?
> Why the field I need behaves this way yet hundereds of others you can copy??
> -Ramsey
> > Hi Ramsey,
> > The rev control problem is as Nick said: Only really a manual process solution where when an ECN goes out (bumping a Rev), buyers must be on copy so they can review open POs and do a change notice if it is a critical change (or if the supplier can absorb a non-critical change without creating cost-waste for you or them to absorb).
> > Same with the Purchase Advisor: No real systemic way to select a supplier part record and then have it update a new PO suggestion in the process of being converted to an approved PO.
> > It becomes manual. Convert the suggestion to a PO, then change vendor & insert the appropriate vendor p/n (along with the correct price).
> > Note: If you are using qty price breaks in supplier price list this WILL NOT work as the PO Entry business object methods will endlessly recalculate the unit price (and repopulate the vendor p/n) every time you edit the PO - and it takes an alphanumeric ascending record sort approach for 'deciding' which supplier price list to use for a vendor-part when two are active. (I don't recal if this osrt is based on effective date or simply the price list record creation date - but it is a pain in the neck.)
> > If you DO have this situation, it get's messy if you really want to do everything IN Vantage. Your (only) option is to modify the effective & discontinue dates of the multiple supplier price lists so they match the specific PO Header Entry date for the price list you want to use.
> > It is more trouble than it is worth (for us) & we found it to much non-value added work for buyers to reliaby manage - so we only use qty price break tables on a very small subset of parts where it HELPS us instead of hurts our planning efficiency.
> > Perhaps Epicor will hire someone in development who has actually USED these systems and add an option at the PO line to Lock Price.
> > Until then, with the frequency PO Entry seems to get rewritten, it is almost impossible to keep any customizations or BPMs to add that capability working.
> > We tried: 305 to 404 broke them but we recovered, 404 to 405 broke them and the BO's are now so screwed up we couldn't recover so gave up on it. I have no doubt 406 & 407 would reveal even further changes as PO Entry seems very much a work in progress.
> > The data tables reveal lots of 'automated housekeeping' fields - 'housekeeping' in the sense that they auto change manually set prices, etc., - that were unused in early versions & incrementally were implemented for use with each release change. On 405a there are still 'unused' fields that no doubt will eventually be implemented (or have been on 406 or 407) and some underlying BO had to be changed to make it happen.
> > I'd keep it simple and assess if the feature is worth using (qty price breaks) in your environment and use offline tools (like a simple Word doc) where it is more trouble than it's worth.
> > Rob
> > --- On Wed, 3/11/09, alldoneprojects <ramsey@> wrote:
> > From: alldoneprojects <ramsey@>
> > Date: Wednesday, March 11, 2009, 9:58 AM
> > Hi Rob,
> > Now I see that I indeed can have the same part multiple times in the Supplier Price List. I tried it before but just wound up modifiying the existing, but guess I flubbed it somehow.
> > My only question now is how to pull in the alternate part number from the Purchase Advisor? I suppose I could customize the grid view and copy/paste from advisor to PO-Lines?
> > We're still going to have issues about revisions same as Nick, but at this makes it at least this gets me past one hump.
> > Thanks to you both,
> > -Ramsey
> > > Ramsey,
> > > No reason you can't have multiple price list records for the same supplier and part. (The system doesn't prohibit it.) They can also both be active (no discontinue date and effective dates within 'today's range).
> > > That would allow you to set up supplier A for your partX as both their p/n 'aaa' & 'bbb' (2 records - both active) & for supplier B set up a price list for 'bbb' and 'ccc' (2 more active records).
> > > Generate PO suggestions will choose the primary vendor (if you've set one) and the price list with the earliest effective date - But that is what the purchasing assistant app is for: The Buyer can over-ride what generate PO suggestions suggested when they actually create the PO.
> > > Pass on a good word to Nick for me. (Hope that knee is mending well.)
> > > Hope that helps
> > > Rob
> > > Date: Tuesday, March 10, 2009, 8:41 PM
> > > Hi All,
> > > I'm faced with a similar situation to Nick so his final solution or other ideas are appreciated.
> > > For the electronics being manufactured here engineering will pick a component that is manufactured by several places. These components can then in turn be purchased from any number of suppliers that have one or more of the acceptable components. Thus we have a component with in-house p/n of 123 supplier 'A' may stock 'aaa' and 'bbb' which are both acceptable. Supplier 'B' may stock 'bbb' and 'ccc' which are acceptable (of course the supplier p/n that references these parts can be totally random). Depending on lead time and cost at the moment, the purchaser may want to buy from A or B at any given time.
> > > So it seems I can:
> > > -create multiple price lists for a vendor, but I don't really see how to do this without creating a different vendor record (Vendor 123-a, Vendor 123-b). The advantage is that I only have one part number/rev in my part record and BOM.
> > > -create a part revision for each acceptable part (123 rev A,B,C etc.) And I suppose through some fancy footwork this can be put into the vendor price list/Purchase order (somehow)?
> > > -Engineering enters the possible parts in the purchasing comments field and the purchaser has to manually change the supplier part number if the primary (p/n stored in price list) isn't available.
> > > I can think of many other ways I'd like it to work, but these seem to be the options closest to what is available. My dream is a supplier price list that is more like a matrix with Manufacturer P/N, Supplier and Supplier P/N which may be doable but it seems pretty far off from what's offered in the program. This is version 407.
> > > Cheers,
> > > -Ramsey
> > > --- In vantage@yahoogroups .com, "nmtaylor1969" <n.taylor@ .> wrote:
> > > > Rob, don't you ever sleep...!?
> > > > Thanks for the advice, I think this is going to be an area where we
> > > > really need to challenge what we are doing, and perhaps take a step
> > > > back and look at the process again in more detail.
> > > > I will go through your reply in detail shortly...
> > > > Do you happen to know if the "use part rev" setting in the MPF is
> > > > actually of any use...?!
> > > > Also, if you recall my post about the production planner workbench.
> > > > Epicor are now looking at this, as the rubbish that this form was
> > > > showing is down to a bug... At least I am not going mad! ;o)
> > > > As always, many thanks...
> > > > Nick
> > > > --- In vantage@yahoogroups .com, Robert Brown <robertb_versa@ >
> > > > wrote:
> > > > > I think you are over-thinking it and making it more complicated
> > > > than it needs to be.
> > > > > Yes: Your internal Part Rev may be bumped up (and you might have
> > > > overlapping approved revs).
> > > > > You can also have overlapping active Vendor-Part prices lists (each
> > > > referencing a vendor p/n and rev if this is needed for your process).
> > > > The Buyer would then have to intervene and make sure they are
> > > > utilizing the right price list (even if the prices for the different
> > > > revs don't differ) just to insure the correct vendor part number/rev
> > > > is pulled into the PO Line record.
> > > > > If that proves unwieldy (or unreliable as people make mistakes) -
> > > > consider using a UD field in the vendor price list table to reference
> > > > the rev - and then add code to enforce search/selection of the price
> > > > list so that price list ud Rev matches your PO Line Part Rev.
> > > > > If overlapping effective dates of multiple revs is a rare but
> > > > necessary evil (and buyers won't necessarily always be purchasing the
> > > > latest rev when creating a new PO), you probably need some other more
> > > > overt warning mechanism (or the buyer won't even be aware that
> > > > multiple approved revs exist - and they need to make a choice).
> > > > > That overt warning mechanism might be sufficient to simply trigger
> > > > a human (trained) process where the vendor p/n is appended by the
> > > > buyer to indicate the correct rev (assuming this enables you to stick
> > > > with one price-list as the price is no different for either rev).
> > > > > The 'best' method all depends upon the scope of conditions your
> > > > buyers will have to contend with (and how frequently - as if it is
> > > > infrequent - they will forget overly complex procedures and goof it
> > > > up). That same scope/frequency array should guide you as you decide
> > > > on whether a customization is worth the effort (as it will have to be
> > > > maintained forever).
> > > > > Rob Brown
> > > > > --- On Thu, 7/31/08, nmtaylor1969 <n.taylor@> wrote:
> > > > > From: nmtaylor1969 <n.taylor@>
> > > > > Subject: [Vantage] Vantage Revision Control In 8.03.305K
> > > > > Date: Thursday, July 31, 2008, 2:45 AM
> > > > > Can anybody tell me how I effectively control purchased parts which
> > > > > are revision controlled. I am unclear about how the supplier price
> > > > > list accurately reflects the revision of a part.
> > > > > Imagine the following scenario:-
> > > > > We purchase a bespoke, made to drawing part from a vendor, let's
> > > > its
> > > > > drawing number is "1234/A". As we are a contract manufacturer and
> > > > we
> > > > > therefore make other peoples products, its likely that our MPF part
> > > > > number and the drawing number for the purchase part will be very
> > > > > different numbers. Therefore our internal MPF part number might
> > > > > be "XYZ:"
> > > > > Obviously the revision is critical, and it goes without saying that
> > > > > the correct drawing number must appear on any purchase order etc.
> > > > We
> > > > > must also preserve the revision history and we must ensure that
> > > > > should we have a need to make a previous revision ( or indeed two
> > > > > revisions at once ), we can handle this effectively within Vantage.
> > > > > We create part "XYZ:" and revision within the MPF, however as
> > > > > this is a purchased part, there is no real MOM required. Initially
> > > > we
> > > > > create the "A" revision part and approve this. We create an entry
> > > > in
> > > > > the supplier price list to reflect the drawing number of the part,
> > > > > and therefore we set the supplier part number to "1234/A".
> > > > > We run a number of jobs through the system, and all appears fine.
> > > > > However as nothing in life is ever simple, the drawing is modified
> > > > > and we now require to produce part "1234/B", and just to make
> > > > matters
> > > > > more complicated, there will be an overlap period where "A" and "B"
> > > > > are both being purchased at the same time.
> > > > > It is easy to create a new revision or the part in the MPF, however
> > > > > the supplier price list data cannot be associated directly with a
> > > > > part revision. So, I can change the supplier part number
> > > > > from "1234/A" to "1234/B" but in doing so, I am unable to order
> > > > > the "A" revision again as the supplier price list entry has been
> > > > > permanently changed. This is dangerous as the "A" revision part
> > > > will
> > > > > call up the same supplier data as the "B" revision part.
> > > > > So, If I need the supplier price data to be revision specific how
> > > > do
> > > > > I do it...? The only way I can see is to actually have different
> > > > > parts in the MPF for the different revisions! This can't be right
> > > > can
> > > > > it...?
> > > > > Any help would be gratefully received...
> > > > > Thanks,
> > > > > Nick
