BPM Emails Blank Title 72252
No.
I have a startup schedule, but not sure how to tie the bpm to it..
Rob Bucek
Sent: Thursday, April 21, 2011 10:21 AM
Subject: RE: [Vantage] BPM Emails
Did you create a startup schedule in your system agent and tie the bpm
asynch process to it?
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-0590
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Behalf
Of bebright@... <mailto:bebright%40mgsmail.com>
Sent: Thursday, April 21, 2011 8:28 AM
Subject: [Vantage] BPM Emails
I am trying to set up an email when there is a new purchase part
created. I've tried the following and it doesnt send out an email.
Started with the Part BO and Update Method. I chose a pre-processing
with the condition of "the Part.TypeCode field of the added row is equal
to the "P" expression" and the action of "send e-mail asynchronously
based on the PurchasePartEmail template". I believe i have the email
setup right in the company setup. It is the same setup that we are using
in Vantage 8 for our emails and it works. Now that we are
piloting/testing in 9.05, i can't seem to get this to work. Is there
anywhere i can check to see if it's trying to send the emails or if the
BPM just isnt running? Sorta lost with this and cant find where to start
to find out the problem. Thanks for the help!
I have just started creating my first BPM's and haven't been successful in getting emails sent out to the recipients. I can get global alerts to send out emails but I have to believe for BPMs, there's another layer of complexity. (It's always something). Can someone give me the elements that make this work. I have already installed the Message Queuing components called "Common" and "Active Directory Integration". I have also started the BPM Action process as a startup task and restarted the appservers for that. Any other incantations? Spells? Charms? (Log file to say what went wrong?)
Â
Thanks, -Karl
v803.406 Progress
Make sure that your post process action says email synchronously
Kersten MacLennan
IT/ERP Analyst
Semrock
A Unit of IDEX Corporation
3625 Buffalo Road, Suite 6
Rochester, New York 14624
585-594-7009
585-594-7095 fax
kmaclennan@...
The Standard in Optical Filters for Biotech & Analytical Instrumentation
Hundreds of Thousands of Ion Beam Sputtered filters delivered -
extensive inventory now!
The information contained in this message and any attachments may be
privileged, confidential, and protected from disclosure. If the reader
of this message is not the intended recipient, or any agent responsible
for delivering this message to the intended recipient, you are hereby
notified that any dissemination, distribution, or copying of this
communication may be unlawful and therefore strictly prohibited. If you
received this message in error, please reply to the message and delete
it. Thank you
Of Karl Dash
Sent: Friday, December 19, 2008 10:43 AM
To: Vantage Group
Thanks, -Karl
v803.406 Progress
Kersten, I just picked up on your post and you said "post process". This can't be a pre process action? BTW why not asynchronously?
Thanks -Karl
Date: Friday, December 19, 2008, 9:34 AM
Kersten MacLennan
IT/ERP Analyst
Semrock
585-594-7009
585-594-7095 fax
kmaclennan@semrock. com
it. Thank you
____________ _________ _________ __
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of Karl Dash
To: Vantage Group
components called "Common" and "Active Directory Integration" . I have
Thanks, -Karl
v803.406 Progress
Karl,
I sent you off line the class notes from the Epicor class I took on
BPMs. The way it works is that you define the conditions in the pre-
process and then send the email as a post process. I don't know why
the asynchronous doesn't work but I've never been able to get it to
do so.
Here is an example of what I have set up
pre process condition:
the ttPart.OnHold field has been changed from false to true
pre process action:
enable dependant post process directives
post process condition:
<Refresh the main form to get up to date conditions>
post process action:
send e-mail synchronously based on the PartOnHold template
This process send the following
CGEN-0029 has been placed on hold due to SPECT
Hold Description
Possible customer issue with design
when a part is placed on hold
Kersten MacLennan
IT/ERP Analyst
Semrock
585-594-7009
585-594-7095 fax
> Thanks -Karl
> From: Kersten MacLennan <kmaclennan@...>
> Kersten MacLennan
> IT/ERP Analyst
> Semrock
> 585-594-7009
> 585-594-7095 fax
Instrumentation
reader
responsible
hereby
you
delete
> it. Thank you
Behalf
> Of Karl Dash
> To: Vantage Group
successful
alerts to
layer of
elements
have
the
file
> Thanks, -Karl
> v803.406 Progress
I am trying to set up an email when there is a new purchase part created. I've tried the following and it doesnt send out an email. Started with the Part BO and Update Method. I chose a pre-processing with the condition of "the Part.TypeCode field of the added row is equal to the "P" expression" and the action of "send e-mail asynchronously based on the PurchasePartEmail template". I believe i have the email setup right in the company setup. It is the same setup that we are using in Vantage 8 for our emails and it works. Now that we are piloting/testing in 9.05, i can't seem to get this to work. Is there anywhere i can check to see if it's trying to send the emails or if the BPM just isnt running? Sorta lost with this and cant find where to start to find out the problem. Thanks for the help!
Rob Bucek
FAX: (715)284-4084
Of bebright@...
