Having a lot of trouble creating a simple code block to create a RFQ Sugg. Not a RFQ PO Sugg. It won’t save to the database. I looked at the contract xml file to see if I’m missing any requirements. I’ve tried in post and pre proc.
try
using (var rfqSuggService = Ice.Assemblies.ServiceRenderer.GetService<Erp.Contracts.RFQSuggSvcContract>(Db))
Erp.Tablesets.RFQSuggTableset rfqSuggTableset = new Erp.Tablesets.RFQSuggTableset();
rfqSuggService.GetNewRFQSugg(ref rfqSuggTableset);
rfqSuggTableset.RFQSugg[0].Company = "TEST";
rfqSuggTableset.RFQSugg[0].PartNum = "113028";
rfqSuggService.Update(ref rfqSuggTableset);
// rfqSuggTableset.RFQSugg[0].SugNum = 10;
// rfqSuggTableset.RFQSugg[0].BuyerID = "JDP";
//rfqSuggTableset.RFQSugg[0].RowMod = "A";
//rfqSuggTableset.RFQSugg[0].LineDesc = "HI";
rfqSuggTableset.RFQSugg[0].IUM = "LB";
rfqSuggTableset.RFQSugg[0].QuoteNum = 0;
rfqSuggTableset.RFQSugg[0].QuoteLine = 0;
rfqSuggTableset.RFQSugg[0].RFQVendQuotes = 1;
rfqSuggTableset.RFQSugg[0].ProcessRFQ = false;
rfqSuggTableset.RFQSugg[0].RcvInspectionReq = false;
// Set other values...
// Submit the changes to the server
Db.Validate();
Console.WriteLine("Update successful");
catch (Exception ex)
Console.WriteLine($"Error: {ex.Message}");
OR
var SUGG = Ice.Assemblies.ServiceRenderer.GetService<Erp.Proxy.BO.RFQSuggImpl>(Db);
Erp.BO.RFQSuggDataSet SUGGTs = new Erp.BO.RFQSuggDataSet();
SUGG.GetNewRFQSugg(SUGGTs);
SUGGTs.RFQSugg[0].PartNum = "113028";
SUGGTs.RFQSugg[0].LineDesc = "GH1234";
SUGGTs.RFQSugg[0].IUM = "LB";
SUGG.Update(SUGGTs);
End Goal would be to loop through BAQ results prior to code block and create a new RFQ Sugg entry for each one. Im not necessarily looking to create an actual RFQ num. Just a Sugg Num.
string PartNum = string.Empty;
string LineDesc = string.Empty;
string IUM = string.Empty;
string RevisionNum = string.Empty;
try
if (BAQ.Tables[0] != null)
using (var boSuggService = Ice.Assemblies.ServiceRenderer.GetService<Erp.Proxy.BO.RFQSuggImpl>(Db))
Erp.BO.RFQSuggDataSet SUGG = new Erp.BO.RFQSuggDataSet();
foreach (DataRow baqRow in BAQ.Tables[0].Rows)
// Get a new RFQHead for each row
boSuggService.GetNewRFQSugg(SUGG);
// Set common values for all items in RFQHead
//SUGG.RFQSugg[0].SugNum = 100;
SUGG.RFQSugg[0].BuyerID = "JDP";
SUGG.RFQSugg[0].RowMod = "A";
SUGG.RFQSugg[0].Company = "TEST";
SUGG.RFQSugg[0].ReqNum = 0;
SUGG.RFQSugg[0].ReqLine = 0;
SUGG.RFQSugg[0].GlbQuoteQuoted = false;
SUGG.RFQSugg[0].GlbJobProdQty = 0;
SUGG.RFQSugg[0].RequiredQty = 1;
SUGG.RFQSugg[0].RcvInspectionReq = false;
SUGG.RFQSugg[0].GlbSuggestion = false;
SUGG.RFQSugg[0].QtyList = "1.00";
SUGG.RFQSugg[0].ProcessRFQ = false;
SUGG.RFQSugg[0].RFQVendQuotes = 4;
// Use the outer scope PartNum and LineDesc
PartNum = baqRow["VendPart_PartNum"].ToString();
LineDesc = baqRow["Part_PartDescription"].ToString();
IUM = baqRow["Part_IUM"].ToString();
RevisionNum = baqRow["PartRev_RevisionNum"].ToString();
// Set values specific to each RFQHead using variables from BAQ
SUGG.RFQSugg[0].CommentText = LineDesc;
SUGG.RFQSugg[0].IUM = PartNum;
SUGG.RFQSugg[0].PartNum = PartNum;
// Submit the changes to the server for each row
boSuggService.Update(SUGG);
Console.WriteLine("Update Response: Update successful");
Console.WriteLine("Error: " + ex.Message);
