Im working on a BOM Query using a recursive CTE, and im close to getting what I want. only issue I have is I cannot do a outer join to get the query to look exactly how I would like it. What we would like to see, is in the parent part column, Id like to see all of the material parts below the parent part by level. this is working as long as the part has a material underneath it, but if the part has no material, it wont give me a blank material or null material slot. it just skips the part altogether.
Typically id fix this issue with a outer join, but apparently i cannot use a outer join in a CTE. so how can i get this null value that im looking for in the material column?
with [MaterialCTE] as
(select
[BOM].[PartMtl_PartNum] as [PartMtl_PartNum],
[BOM].[PartMtl_RevisionNum] as [PartMtl_RevisionNum],
[BOM].[Part_PartDescription] as [Part_PartDescription],
[BOM].[PartMtl_MtlPartNum] as [PartMtl_MtlPartNum],
[BOM].[PartMtl_MtlSeq] as [PartMtl_MtlSeq],
[BOM].[Calculated_Level] as [Calculated_Level],
[BOM].[Calculated_Path] as [Calculated_Path],
[BOM].[Calculated_LSeq] as [Calculated_LSeq],
[BOM].[PartMtl_QtyPer] as [PartMtl_QtyPer],
[BOM].[Calculated_TLQty] as [Calculated_TLQty],
[BOM].[Part_ClassID] as [Part_ClassID]
from (select
[PartMtl].[PartNum] as [PartMtl_PartNum],
[PartMtl].[RevisionNum] as [PartMtl_RevisionNum],
[Part].[PartDescription] as [Part_PartDescription],
[PartMtl].[MtlSeq] as [PartMtl_MtlSeq],
[PartMtl].[MtlPartNum] as [PartMtl_MtlPartNum],
(0) as [Calculated_Level],
(cast('' as nvarchar(255))) as [Calculated_Path],
(cast( convert(varchar,PartMtl.PartNum) + '\' + convert(varchar,(RIGHT('' + CAST(PartMtl.MtlSeq AS NVARCHAR(5)), 5 ))) as nvarchar(255))) as [Calculated_LSeq],
[PartMtl].[QtyPer] as [PartMtl_QtyPer],
(cast(1 as decimal(10,1))) as [Calculated_TLQty],
[Part].[ClassID] as [Part_ClassID]
from Erp.PartMtl as PartMtl
inner join Erp.Part as Part on
PartMtl.Company = Part.Company
and PartMtl.PartNum = Part.PartNum
and ( Part.PartNum = '1001174277P029' )) as BOM
left outer join (select
[Part2].[Company] as [Part2_Company],
[Part2].[PartNum] as [Part2_PartNum]
from Erp.Part as Part2
inner join (select
[PartRev].[PartNum] as [PartRev_PartNum],
[PartRev].[RevisionNum] as [PartRev_RevisionNum],
(max(PartRev.EffectiveDate)) as [Calculated_LastEffDate]
from Erp.PartRev as PartRev
inner join (select
[PartRevLAST].[PartNum] as [PartRevLAST_PartNum],
(max(PartRevLAST.EffectiveDate)) as [Calculated_MaxEffDate]
from Erp.PartRev as PartRevLAST
where (PartRevLAST.Approved = True)
group by [PartRevLAST].[PartNum]) as LastEffDate on
PartRev.PartNum = LastEffDate.PartRevLAST_PartNum
group by [PartRev].[PartNum],
[PartRev].[RevisionNum]) as MtlRevision1 on
Part2.PartNum = MtlRevision1.PartRev_PartNum) as Parts on
BOM.PartMtl_MtlPartNum = Parts.Part2_PartNum
union all
select
[ChildPartMtl].[PartNum] as [ChildPartMtl_PartNum],
[ChildPartMtl].[RevisionNum] as [ChildPartMtl_RevisionNum],
[MaterialCTE1].[Part_PartDescription] as [Part_PartDescription],
[ChildPartMtl].[MtlPartNum] as [ChildPartMtl_MtlPartNum],
[ChildPartMtl].[MtlSeq] as [ChildPartMtl_MtlSeq],
(MaterialCTE1.Calculated_Level + 1) as [Calculated_Level2],
(Cast(MaterialCTE1.Calculated_Path + '.' as nvarchar(255))) as [Calculated_Path2],
(cast(MaterialCTE1.Calculated_LSeq + '\' + convert(varchar,ChildPartMtl.PartNum) + '\' + (RIGHT('' + CAST(ChildPartMtl.MtlSeq AS NVARCHAR(5)), 5 )) as nvarchar(255))) as [Calculated_LevSeq2],
[MaterialCTE1].[PartMtl_QtyPer] as [PartMtl_QtyPer],
(cast(ChildPartMtl.QtyPer as decimal(10,1))) as [Calculated_MLQty],
[MaterialCTE1].[Part_ClassID] as [Part_ClassID]
from Erp.PartMtl as ChildPartMtl
inner join MaterialCTE as MaterialCTE1 on
ChildPartMtl.PartNum = MaterialCTE1.PartMtl_MtlPartNum
where (ChildPartMtl.PartNum is not null))
select
[MaterialCTE].[PartMtl_PartNum] as [PartMtl_PartNum],
[MaterialCTE].[PartMtl_RevisionNum] as [PartMtl_RevisionNum],
[MaterialCTE].[Part_PartDescription] as [Part_PartDescription],
[MaterialCTE].[PartMtl_MtlPartNum] as [PartMtl_MtlPartNum],
[PartMain].[PartDescription] as [PartMain_PartDescription],
[MaterialCTE].[PartMtl_MtlSeq] as [PartMtl_MtlSeq],
[MaterialCTE].[Calculated_Level] as [Calculated_Level],
[MaterialCTE].[Calculated_Path] as [Calculated_Path],
[MaterialCTE].[Calculated_LSeq] as [Calculated_LSeq],
[MaterialCTE].[Calculated_TLQty] as [Calculated_TLQty],
[MaterialCTE].[PartMtl_QtyPer] as [PartMtl_QtyPer],
(MaterialCTE.Calculated_TLQty * MaterialCTE.PartMtl_QtyPer) as [Calculated_ReqQty],
[MaterialCTE].[Part_ClassID] as [Part_ClassID]
from MaterialCTE as MaterialCTE
inner join Erp.Part as PartMain on
MaterialCTE.PartMtl_MtlPartNum = PartMain.PartNum
group by [MaterialCTE].[PartMtl_PartNum],
[MaterialCTE].[PartMtl_RevisionNum],
[MaterialCTE].[Part_PartDescription],
[MaterialCTE].[PartMtl_MtlPartNum],
[PartMain].[PartDescription],
[MaterialCTE].[PartMtl_MtlSeq],
[MaterialCTE].[Calculated_Level],
[MaterialCTE].[Calculated_Path],
[MaterialCTE].[Calculated_LSeq],
[MaterialCTE].[Calculated_TLQty],
[MaterialCTE].[PartMtl_QtyPer],
(MaterialCTE.Calculated_TLQty * MaterialCTE.PartMtl_QtyPer),
order by MaterialCTE.Calculated_LSeq, MaterialCTE.Calculated_Level
This is how i would like it to look in the end. Is this at all possible?
