BOM Export Blank Title 93355
Write a BAQ & export it (or a SQL query).
If you don't want access to those tools to be that widespread, use the BAQ as the basis of a dashboard (where you can then add some input filters) & they can copy the returned results (sans column headers) from the list/grid into excel (perhaps a template file w/ headers already in place).
A good (widespread use) technique is to write an HTML app that does the SQL query based on user criteria & displays results in a table.
Done right, that can become a data source directly into excel (for many needs).
Rob
--- Original Message ---
Sent:Thu 9/9/10 12:48 pm
To:<vantage@yahoogroups.com>
Subj:[Vantage] BOM Export
We are on Version 8.03.408B, and one of our employee asked if there was
a way to EXPORT a BOM out to say WORD or EXCEL? Does anyone know of a
way to do this?
Paul E. Pachniak
Accounting Manager
Ace Precision Machining Corporation
W146 N5714 Enterprise Avenue
Menomonee Falls, WI 53051
Phone: 262-252-4003 Ext. 3114
Fax: 262-252-4974
Email: paul.pachniak@...
<mailto:paul.pachniak@...>
WWW: http://www.aceprecision.com <http://www.aceprecision.com>
NOTICE: THIS MESSAGE CONTAINS THE PROPRIETARY AND CONFIDENTIAL INFORMATION OF ACE PRECISION MACHINING CORP. If you are an unintended recipient, immediately (1) delete all copies of this message and any attachments, and (2) contact the sender. If you are an intended recipient, you are prohibited from deleting or obstructing this or any other Ace Precision Machining Corp. proprietary or confidentiality designation that appears on this message or any attachments. All recipients are prohibited from reproducing, publishing or disclosing the contents of this message and any attachments to others, unless you first request and receive written permission from Ace Precision Machining Corp.
way to do this?
Paul E. Pachniak
Accounting Manager
Fax: 262-252-4974
