BOM Costing problem
I found the problem. It looks like there was another revision that had the same effective date for the top level part. The BOM has the same material so I don't know why it caused that type of problem.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Stan Chmura
Sent: Thursday, July 24, 2008 10:17 AM
Subject: RE: [Vantage] BOM Costing problem
Staring with the basics: but is the sub assy part marked as standard cost;
manufactured part and is there an approved methods master with valid costs
for the components?
_____
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
Jasper Recto
Sent: Thursday, July 24, 2008 10:15 AM
To: Vantage Groups (vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>)
Subject: [Vantage] BOM Costing problem
I have a top level part that has a subAssembly component. This subAssembly
is setup as view as assembly only, not pull as assembly.
When I run a BOM Cost report, the cost show up as zero for everything and it
makes the top level part cost incorrect.
Any ideas why this is happening?
Jasper
I have a top level part that has a subAssembly component. This subAssembly is setup as view as assembly only, not pull as assembly.
When I run a BOM Cost report, the cost show up as zero for everything and it makes the top level part cost incorrect.
Jasper
for the components?
_____
Jasper Recto
To: Vantage Groups (vantage@yahoogroups.com)
Jasper
Is the sub-assembly flagged as Purchased rather than Manufactured......
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of
Stan Chmura
Sent: 24 July 2008 15:17
for the components?
_____
Of
Jasper Recto
it
Jasper
