Price Inquiry BO does not work for this as it has no date parameter to be passed. Is there another BO I can use to get a price passing in Date, Qty, UOM, PartNum, CustID and/or a ShipToID? Our Customers have multiple pricelist groups attached based on effective dates. Any direction on the correct BO to use would be greatly appreciated.
Can you just use a LINQ expression to query the DB directly?
Sounds like a good a plan as I’ve had. Working on the Query needed now. Thank you for the confirmation
I took a peek at the tables you’ll need, and be forewarned that it looks a bit tricky. At least 3 tables are probably needed. And choosing which QtyBreak price (as they are in columns not rows) will take some thought.
I’d tackle it by trying to make a BAQ that returns the one record you want, and then implementing that as LINQ code.
Ya working it in SQL first I was thinking something like this as we don’t use price breaks for configured product and the discounts can be factored in afterwards:
SELECT TOP (1) * FROM (
SELECT C2.Company AS Company
, C2.CustNum as CustNum
, C2.CustID as CustID
, CPL.ListCode as [ListCode]
, PL2.[StartDate] AS [StartDate]
, PL2.[EndDate] AS [EndDate]
FROM [Erp].[CustomerPriceLst] CPL
LEFT JOIN [Erp].[Customer] C2 ON CPL.Company=C2.Company AND CPL.CustNum=C2.CustNum
LEFT JOIN [Erp].[PriceLst] PL2 ON PL2.Company=CPL.Company AND PL2.ListCode=CPL.ListCode
UNION ALL
SELECT C1.Company AS Company
, C1.CustNum as CustNum
, C1.CustID as CustID
, CPG.[ListCode] as [ListCode]
, PL1.[StartDate] AS [StartDate]
, PL1.[EndDate] AS [EndDate]
FROM [Erp].[CustGrupPriceLst] CPG
LEFT JOIN [Erp].[Customer] C1 ON CPG.Company=C1.Company AND CPG.GroupCode=C1.GroupCode
LEFT JOIN [Erp].[PriceLst] PL1 ON PL1.Company=CPG.Company AND PL1.ListCode=CPG.ListCode
) AS UA
WHERE UA.Company='XYZ' AND UA.CustID='MyCustID' AND ((UA.StartDate<=@PricingDate) AND (UA.[EndDate]>=@PricingDate))
@ckrusen Also, not using ShipTo ID’s at this time so this simpler version gets me the list at a given date.
Do you see any room for improvements as I am still learning the LINQ queries?
Here is my simplified version of Priice List Lookup in LINQ (Developed in LINQpad5):
List<string> ListCodes = (((from cust in Customers
where cust.CustID == CustID && cust.Company == Company
join cpl in CustomerPriceLsts on cust.CustNum equals cpl.CustNum into cpls
from cpl in cpls
join pls in PriceLsts on cpl.ListCode equals pls.ListCode
where pls.StartDate <= PricingDate && pls.EndDate >= PricingDate
select new
rListCode = cpl.ListCode,
}).ToList()).Concat(
join cpg in CustGrupPriceLsts on cust.GroupCode equals cpg.GroupCode into cpgs
from cpl in cpgs
select new
}).ToList()).Select(r => r.rListCode)).ToList();
var partRecords = (from pl in PriceLstParts
where pl.PartNum==PartNum && ListCodes.Contains(pl.ListCode)
select new { Price = pl.BasePrice, ListCode=pl.ListCode, PartNum = pl.PartNum }).ToList().OrderBy(pr=>ListCodes.IndexOf(pr.ListCode)).ToList();
decimal dPrice = partRecords.Select(r => r.Price).ToList().DefaultIfEmpty(0m).FirstOrDefault();
string sListCode = partRecords.Select(r => r.ListCode).ToList().DefaultIfEmpty("").FirstOrDefault();
ListCodes.Dump();
partRecords.Dump();
Console.WriteLine("Date: " + PricingDate.ToString() + "\nCustomer ID:" + CustID + "\nPartNum: " + PartNum + "\nListCode: " + sListCode + "\nPrice: " + dPrice.ToString());```
