BMP Delete Row Blank Title 82761
We don't have the SDK, but I think all you have to do is install the Progress license that comes with it and you will be in buisness.
Sent: Tuesday, September 15, 2009 11:12:11 AM
Subject: [Vantage] Re: BMP Delete Row
Â
We do have the SDK. Have never used it since we have been able to do almost everything with script and BPMs. Guess it is time to learn. I know Epicor wants to charge a hefty fee for training, I wonder how far the manuals will get me?
--- In vantage@yahoogroups .com, Steven Gotschall <sgotschall@ ...> wrote:
> Unless you have a full Progress license or the SDK then you can not directly add, update, or delete records from code (well service connect can using the business objects, but I wouldn't call it a direct approach). With the Updatetablebuffer. p you can update a record, but I don't think it can add or delete a record. Here is some code I got a while back on deleteing data in a dataset. Its a VB customization so I don't know if it will meet your needs.
> This is for UD20, but just change to whatever table you need
> call the sub and pass it the dataset or incorporate into a button click
> or whatever - this is merely for concept :o)
> Private Sub deleteUD20Records( dsUD20 As DataSet)
> Dim adUD20 As UD20Adapter = New UD20Adapter( UD20Form)
> adUD20.BOConnect( )
> For Each dr As DataRow In dsUD20..Tables( 0).Rows
> Dim deleted As Boolean = adUD20.DeleteByID( dr("Key1" ),dr
> ("Key2"),dr( "Key3"),dr( "Key4"),dr( "Key5"))
> Next
> adUD20.Dispose( )
> End Sub
> Â
> MORE CODE:
> Private Sub cedEpiCustom1_ DoubleClick( ByVal Sender As Object, ByVal Args As System.EventArgs) Handles cedEpiCustom1. DoubleClick
> Â Â '// ** Place Event Handling Code Here **
> Â
> Â Â Dim edvOrderDtl As EpiDataView = CType(oTrans. EpiDataViews( "OrderDtl" ), EpiDataView)
> Â Â Â Â Dim I as Int32
> Â Â Â Â Dim TempRow as Int32
> Â Â If edvOrderDtl. Hasrow Then
> Â Â Â Â Â Â Â Â Â Â Â if 6 = msgbox("Would you like to update the Winco Price for all items on this Sales Order?",36," Update Winco Calculated Pricing")
> Â Â Â Â Â Â Â Â Â TempRow = edvOrderDtl. row
> Â Â Â Â Â Â Â Â Â Â Â Â for I = 0 to edvOrderDtl. DataView. Count - 1
> Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â edvOrderDtl. Row = I
> Â Â Â Â Â Â Â Â Â Â edvOrderDtl. dataView( edvOrderDtl. Row)("SellingQua ntity") = edvOrderDtl. dataView( edvOrderDtl. Row)("SellingQua ntity")
> Â Â Â Â Â Â Â Â Â Â Â Â Next I
> Â Â Â Â Â Â Â Â edvOrderDtl. row = TempRow
> Â Â Â Â Â Â Â Â Â Â Â End If
> Â Â End If
> Â
> Â End Sub
> ____________ _________ _________ __
> From: mmcwilliams22 <mmcwilliams22@ ...>
> To: vantage@yahoogroups .com
> Sent: Tuesday, September 15, 2009 9:53:05 AM
> Â
> I guess I must do it throught the updatetablebuffer somehow. I am getting this error using your method.
> The following application error was encountered:
> You may not compile programs that update the database in this version (490)
> ** Could not understand line 11. (196)
> --- In vantage@yahoogroups .com, Dimitris Kavvouras <d.kavvouras@ ....> wrote:
> > Hi Williams ,
> > Do you mean something like that? you don't need to specify any parameters, just fetch the record you wish to delete and delete it.
> > i.e. just as an example, delete all records from JobEntry where company is the CUR-COMP (Current selected company) and field "Somehting" equals no.
> > FOR EACH ttJobEntry where ttJobEntry.Company = CUR-COMP:
> > if ttJobEntry.somethin g= false then
> > delete ttJobEntry.
> > end.
> > From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On Behalf Of mmcwilliams22
> > Sent: Tuesday, September 15, 2009 4:05 PM
> > Subject: [Vantage] BMP Delete Row
> > How can I delete a row using a BPM I know it is DELETE but I am not sure of parameters etc.
Hi Williams ,
if ttJobEntry.something= false then
delete ttJobEntry.
end.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of mmcwilliams22
--- In vantage@yahoogroups.com, Dimitris Kavvouras <d.kavvouras@...> wrote:
> Hi Williams ,
> delete ttJobEntry.
> end.
Unless you have a full Progress license or the SDK then you can not directly add, update, or delete records from code (well service connect can using the business objects, but I wouldn't call it a direct approach). With the Updatetablebuffer.p you can update a record, but I don't think it can add or delete a record. Here is some code I got a while back on deleteing data in a dataset. Its a VB customization so I don't know if it will meet your needs.
adUD20.BOConnect( )
Next
adUD20.Dispose( )
End Sub
Â
MORE CODE:
Private Sub cedEpiCustom1_DoubleClick(ByVal Sender As Object, ByVal Args As System.EventArgs) Handles cedEpiCustom1.DoubleClick
Â
  Dim edvOrderDtl As EpiDataView = CType(oTrans.EpiDataViews("OrderDtl"), EpiDataView)
    Dim I as Int32
  If edvOrderDtl.Hasrow Then
           if 6 = msgbox("Would you like to update the Winco Price for all items on this Sales Order?",36,"Update Winco Calculated Pricing")
         TempRow = edvOrderDtl.row
            for I = 0 to edvOrderDtl.DataView.Count - 1
                   edvOrderDtl.Row = I
          edvOrderDtl.dataView(edvOrderDtl.Row)("SellingQuantity") = edvOrderDtl.dataView(edvOrderDtl.Row)("SellingQuantity")
            Next I
        edvOrderDtl.row = TempRow
           End If
  End If
Â
 End Sub
Â
> Hi Williams ,
> delete ttJobEntry.
> end.
> From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of mmcwilliams22
> adUD20.BOConnect( )
> Next
> adUD20.Dispose( )
> End Sub
> Â
> MORE CODE:
> Â
> Â Â Dim edvOrderDtl As EpiDataView = CType(oTrans.EpiDataViews("OrderDtl"), EpiDataView)
> Â Â If edvOrderDtl.Hasrow Then
> Â Â Â Â Â Â Â Â Â Â Â if 6 = msgbox("Would you like to update the Winco Price for all items on this Sales Order?",36,"Update Winco Calculated Pricing")
> Â Â Â Â Â Â Â Â Â TempRow = edvOrderDtl.row
> Â Â Â Â Â Â Â Â Â Â Â Â for I = 0 to edvOrderDtl.DataView.Count - 1
> Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â edvOrderDtl.Row = I
> Â Â Â Â Â Â Â Â Â Â edvOrderDtl.dataView(edvOrderDtl.Row)("SellingQuantity") = edvOrderDtl.dataView(edvOrderDtl.Row)("SellingQuantity")
> Â Â Â Â Â Â Â Â edvOrderDtl.row = TempRow
> Â Â End If
> Â
> Â End Sub
> From: mmcwilliams22 <mmcwilliams22@...>
> Â
> > Hi Williams ,
> > delete ttJobEntry.
> > end.
