Blank Title 45565
You can also set up the Veritas backup job to run the batch file
before commencing the backup. In version 8.5 it is in the Advanced
tab, Commands, Execute before Backup.
This way you be assured that the Progress Backup batch file has run
just before the backup commences.
--- In vantage@yahoogroups.com, John Sage <list@j...> wrote:
> Ben,
> You can't backup the live database using Veritas. In your job
setup,
> exclude all the \db folders.
> Then, using the Windows Task Scheduler, schedule an online
Progress
> backup. See the BACKMFG.BAT and MFGBKUP.BAT files in your \MFGSYS
> folder, modify to suit.
> I use the above batch files to dump a copy of the database several
times
> per day out to a folder on one of our file servers. I then use
Veritas
> to backup that folder.
> have a great weekend,
> john
> Ben Belzer wrote:
> > We use Veritas to backup our servers. It seems that it skips
many
> > Vantage files including the database...
We use Veritas to backup our servers. It seems that it skips many
Has anyone found a good way to backup the database using veritas or
something similar?
Ben Belzer
IT Manager
TCI Precision Metals
800.234.5613.W
310.323.1255.F
bbelzer@... <mailto:bbelzer@...>
www.tciprecision.com <http://www.tciprecision.com/>
Ben,
You can't backup the live database using Veritas. In your job setup,
Then, using the Windows Task Scheduler, schedule an online Progress
I use the above batch files to dump a copy of the database several times
per day out to a folder on one of our file servers. I then use Veritas
john
