Blank Title 27264
Thanks Edward I think that's what I will do.
Fredy Venczel
Sent: June 20, 2003 12:34
Subject: RE: [Vantage]
I assumed you had created a part in Vantage with the same part
number. To
keep the trail going, I might change the part number on the job to
the new
Vantage part number and document this in the comments on the
material in the
job. Then do a negative issue and issue to the new job.
Edward F. Fox, Jr., CPA
Controller
Maxson Automatic Machinery Company
Phone: 401-596-0162 x110
Fax: 401-596-1050
www.maxsonautomatic.com
Sent: Friday, June 20, 2003 12:33 PM
To: 'vantage@yahoogroups.com'
Edward I was thinking of going into the job and change the
non-existing part
number to the new part number and then doing the negative issue. I
just
wasn't sure if that was the way to go.
Fredy Venczel
Sent: June 20, 2003 12:21
Fredy,
Have you tried to do a "negative" Issue to Manufacturing and
then
issue it
to the new job?
Controller
Fax: 401-596-1050
Sent: Friday, June 20, 2003 12:19 PM
Edward it is just material on the job not a complete assembly.
It
was
purchased for an R & D job because they weren't sure it was
going to
work so
we didn't bother creating the part in Vantage. Now it works
and they
want to
use it on another job.
Fredy Venczel
[SMTP:efox@...]
Sent: June 20, 2003 12:06
Have you tried to do a "Receipt from Manufacturing" in
Inventory
Management?
It allows you to specify a job and assembly to put it
to.
Controller
Fax: 401-596-1050
Sent: Friday, June 20, 2003 12:00 PM
Subject: [Vantage]
I have a non stock part (doesn't exist in Vantage part
master)
on an
R & D
job and now I want to take it off that job and put it on
another
job. A part
has been created in the part master now. I'm not sure
how to
handle
this.
I'm on version 5.0.
Fredy Venczel
