We had this same issue to deal with. I believe our solution was to establish 'permanent' warehouse bins by setting them up as zero qty stock transfer kan-bans. The part/warehouse/bin relationship is then retained even if O/H goes to zero and the data is accessible via PartBinInfo.
Rob Brown
Rob Brown
--- On Mon, 6/30/08, John Atwood <John.Atwood@...> wrote:
Subject: [Vantage] Re: Bin Location on Job Traveler
Date: Monday, June 30, 2008, 9:26 PM
A possible source of your problem may be if the part in question has
an on hand qty. The PartBin table only has records for parts on hand.
If the part in question doesn't have any on hand, the resulting
records may be null, possibly causing your problem.
I had a similar situation for a job pick list and used the PartPlant
table to find the PrimWhse for the part and then the PlantWhse table
to determine the PrimBin for that warehouse. In our environment, each
part is assigned to a discrete primary bin. I actually ended up using
MS Access and ODBC to write the pick list report, I couldn't figure
it out with Vantage/Crystal and it also is pulling data from outside
Vantage.
John Atwood
Stellar Micro
--- In vantage@yahoogroups .com, "Thomas Delicati"
<thomas.delicati@ ...> wrote:
> I would like the primary bin location to show up on my Job Traveler
> report for the Part being produced. I've tried to update my Job
> Traveler form to include the PartBin table, but every time I add the
> BinNum to the report - it doesn't matter what report section I add
it to
> - the entire report goes blank and all I get are the outlines of
each
> section. It's as if the table is not joined properly or something
along
> those lines. Has anyone had any luck with adding the primary bin
> location to the crystal report job traveler form in Vantage
8.03.400?
> Thomas Delicati
> Information Systems Manager
> Ottenweller Company
> 3011 Congressional Parkway
> Fort Wayne, IN 46808
> Phone: ext. 258
> Fax:
> Website: http://www.ottenwel ler.com <http://www.ottenwel ler.com/>
