Lynn,part of the reason is that you may choose a different bin naming convention than what epicor may decide on as a default. So here is what we did, it was tedious but a one time deal- in MS Excel generate your Bin#s and naming conventions (The drag to fill feature works quite well)-We created 3 warehouses (Main, Inspection, Transfer) and generated all possible bin#s for the MAIN warehouse only eg: starting with Bin# A0101-Description- Rack A, Row 01, Bin 01 through Bin# Z0101. Then copy and paste this into BIN SETUP form in List view. It takes less than an hour to finish the paste -you can paste and leave it running. You are done. You can choose or select as you need to from Bins as you need to.
In our Inspection Warehouse, we set up only 5 various bins based on our dispositioning process after inspection. Anyway, these are simply suggestions. If you would like the Excel file to perhaps use or modify, let me know and you can always do a find, replace or copy etc. as you wish. You may contact me offline
RSN
ritasn@...
Never miss a thing. Make Yahoo your homepage.
RSN
ritasn@...
