Bill of Lading
We decided to start using Bills of Lading generated by Vantage. Since we
never used Bills of Lading before, there are dozens of thousands of
available Packing Slips in our database. As the result, it takes the system
up to twenty minutes and up to 100% of CPU usage to create the list, which
makes the whole task of creating Bills of Lading absolutely impractical.
Do you have any suggestion how to deal with this situation?
Vladimir Tigay
WLS Stamping Co.
216-271-5100 x3020
We decided to take advantage of the bug in 4.0 where the generate function does not see the release shipment address. We highlighted all 10,500 + packing slips, and in about 5 minutes, Vantage created only 168 BOL's all with the ship date of 11/10/00. We now filter these BOL's from our reports.
Now when we use the generate function, the list is only 450 lines long. All items dated before 11/10/00 are invalid packing slips that have no details (we intend to delete these through customer shipment entry). The other lines are current unlinked packing slips, which our shipping manager reads like watchdog report.
----- Original Message -----
To: OneList
Sent: Monday, November 27, 2000 8:03 AM
Subject: [Vantage] Bill of Lading
Vladimir Tigay
WLS Stamping Co.
216-271-5100 x3020
eGroups Sponsor
We no longer allow attachments to files. To access/share Report Files, please go to the following link: http://www.egroups.com/files/vantage/
(Note: If this link does not work for you the first time you try it, go to www.egroups.com, login and be sure to save your password, choose My Groups, choose Vantage, then choose Files. If you save the password, the link above will work the next time you try it.)
Hi,
Bill of Ladings in my opinion is very hard to use as it is. Not all
shipments get a bill of lading, so there needs to be a check box to say it
needs to generate a bill of lading on the packing slip. Or at least the
ability to delete suggestions. This has caused us to not use the bill of
ladings at all.
Judy Stauduhar
Taber Bushnell
Date: Mon, 27 Nov 2000 09:48:37 -0500
Subject: Re: Bill of Lading
watchdog report
Message: 1
Date: Mon, 27 Nov 2000 08:03:15 -0500
Subject: Bill of Lading
Vladimir Tigay
WLS Stamping Co.
216-271-5100 x3020
I can't even find the physical database relationship between the packing
slips and the BOL's. Anyone figure this out? If so a simple maint. program
could be written to clean up the suggestion browser.
Sent: Tuesday, November 28, 2000 7:36 AM
To: vantage@egroups.com
Hi,
ladings at all.
Judy Stauduhar
Taber Bushnell
watchdog report
Message: 1
Vladimir Tigay
WLS Stamping Co.
216-271-5100 x3020
Greg Fuller wrote:
> We are currently using a 4 part tractor feed form on an old dot matrix
> printer for our LTL freight Bill of Lading.
> We would like to quit using the expensive pre-printed forms and start using
> plain paper printed from a laser printer.
> Questions: 1. Do we need all that legal mumbo jumbo that's on the pre
> printed form?
I would say so.
> 2. Does anyone have a template or other type of file that we
> could simply modify a little (I.E. put our logo and address on) and use.
> Thanks,
> Greg
There's one in the files section.
Is anyone using Vantage bill of lading, and how are you handling the
multiple copies/signature issue. Is everyone using the Vantage Forms or did
you develop your own? Any help would be appreciated.
Kim Wood
IT Manager
Electro Chemical Finishing
We use the bill of lading for truck shipments, but not for other types of
shipments, I created my own B.O.L. form. As to multiple copies and
signatures, copy machine, and pen. When our shipping mgr starts using
things correctly, maybe I'll try to simplify it for him.
Shirley
Sent: Tuesday, June 18, 2002 2:47 PM
To: 'vantage@yahoogroups.com'
did
Kim Wood
IT Manager
Kim,
We have our own forms printed on three part carbonless paper. Sets are not
glued but each page is a different color. Some laser printers will destroy
the carbonless properties of the paper if you put the paper in a regular
tray (the path through the printer is too long and the heat kills the
carbonless properties). We use HP LaserJet 4000 series printers and run the
BOL from the manual feed paper tray and everything works just fine!
Steve Sanders
Delta Centrifugal Corp
Sent: Tuesday, June 18, 2002 1:47 PM
did
Kim Wood
IT Manager
Steve, can you email a sample of you BOL for us to review, if you don't
mind. I would like to see what you have done from practical experience.
You can email me offline at kwood@... <mailto:kwood@...> .
Kim wood
Sent: Tuesday, June 18, 2002 3:52 PM
Subject: RE: [Vantage] Bill of Lading
Kim,
Steve Sanders
did
Kim Wood
IT Manager
On the Bill of Lading in Vantage there is a link to the packing slip number.
Where can I find that in Report Builder? It is not in BOLHead or BOLDetail
table.
Fredy Venczel
The packing slip number appears in the reference field in the BOLHead table. There is no actual field in the BOL tables for the linked packing slip.
Rick Lane
Intelligent Systems Integration, Inc.
661B Weber Drive
Wadsworth, OH 44281
PH: 330-335-5291
FX: 330-335-7275
Â
"Helping Businesses Make Intelligent Use of Technology"
Sent: Tuesday, August 26, 2003 1:23 PM
table.
Fredy Venczel
You can link the BOL Number to the LOG field in the Shipping Header Table
with Crystal reports. When a packing slip is added to a BOL the Log field
is populated. You can also add a Packing Slip to a BOL that already exists
by entering the BOL number in the LOG field manually in the Shipping Header.
This is in version 5.0.
Michael
> From: Rick Lane [mailto:rickl@...]
> Sent: Tuesday, August 26, 2003 1:20 PM
> Rick Lane
> 661B Weber Drive
> Wadsworth, OH 44281
> PH: 330-335-5291
> FX: 330-335-7275
> Â
> From: Fredy Venczel [mailto:fvenczel@...]
> slip number.
> table.
> Fredy Venczel
> enable access. )
We haven't been using the BOL from Vantage but our shipping department wants
to start. They've been testing it and noticed not all packing slips are
available when they click on the "generate" button. I have no clue why they
aren't showing up. Any ideas? I'm on Vantage 5.0
Fredy Venczel
I suspect that the issue is incomplete data entry in the packing slip.
Make sure all fields are complete and correct in the packing slip.
Shirley
Sent: Monday, February 09, 2004 8:50 AM
wants
they
Fredy Venczel
_____
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
<http://docs.yahoo.com/info/terms/> Service.
Tracking #: 62B347700CF5974CBCEEE2303869CF4DB35E49B2
Thanks Shirley but that's not it. Vantage warns you that the data is
incomplete but it still lets you create the BOL.
Fredy Venczel
Sent: Monday, February 09, 2004 9:32 AM
slip.
Shirley
department
wants
are
why
they
Fredy Venczel
We're on 5.0 as well, and found after much testing that 5.0 is not ready for
BOL functions. I don't remember what is was that we weren't able to do, but
when we called support, they said the function was not ready for that
version.
That's when we started testing 6.0, and soon we will be there.
Rhonda
Sent: Monday, February 09, 2004 9:55 AM
Fredy Venczel
slip.
Shirley
department
wants
are
why
they
Fredy Venczel
_____
Yahoo! Groups Links
<http://groups.yahoo.com/group/vantage/>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
Rhonda we are on 6.1 and the BOL is still not very good. It still needs a
lot of work, I am told maybe in 7.0 it will be better.
Judd
Sent: Monday, February 09, 2004 10:12 AM
version.
Rhonda
Fredy Venczel
slip.
Shirley
department
wants
are
why
they
Fredy Venczel
<http://groups.yahoo.com/group/vantage/files/.> >
<http://groups.yahoo.com/group/vantage/messages> >
<http://groups.yahoo.com/group/vantage/links> >
_____
Yahoo! Groups Links
<http://groups.yahoo.com/group/vantage/> >
<http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > .
_____
Yahoo! Groups Links
Great (sounding disappointed) Thanks for the advance notice. At least I
won't be as disappointed when we make the move to upgrade. We wanted to
print them from Vantage, to avoid buying them.
Rhonda
Sent: Monday, February 09, 2004 2:01 PM
Judd
version.
Rhonda
Fredy Venczel
slip.
Shirley
department
wants
are
why
they
Fredy Venczel
<http://groups.yahoo.com/group/vantage/files/.> > >
<http://groups.yahoo.com/group/vantage/messages> > >
<http://groups.yahoo.com/group/vantage/links> > >
_____
Yahoo! Groups Links
<http://groups.yahoo.com/group/vantage/> > >
<http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > > .
_____
Yahoo! Groups Links
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/SIG=12clv8orb/M=243273.4510124.5685162.1261774/D=egroup
web/S=1705007183:HM/EXP=1076439687/A=1750744/R=0/*http://servedby.advertisin
g.com/click/site=552006/bnum=1076353287018923> Click to learn more...
<http://us.adserver.yahoo.com/l?M=243273.4510124.5685162.1261774/D=egroupweb
/S=:HM/A=1750744/rand=390998877>
_____
Yahoo! Groups Links
Rhonda if you would like you may have my BOL form. It is not the best in the
world but you are welcome to have it. I am still working on it. It is able
to total weight from the packing list you link to it. I have a couple of VB
info on it you may strip out.
Judd
Custom Hoists, Inc.
Ph: (419) 368-4721 EXT. 246
Sent: Monday, February 09, 2004 2:13 PM
Rhonda
Judd
version.
Rhonda
Fredy Venczel
slip.
Shirley
department
wants
are
why
they
Fredy Venczel
<http://groups.yahoo.com/group/vantage/files/.> > > >
<http://groups.yahoo.com/group/vantage/messages> > > >
<http://groups.yahoo.com/group/vantage/links> > > >
_____
Yahoo! Groups Links
<http://groups.yahoo.com/group/vantage/> > > >
<http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > > >
_____
Yahoo! Groups Links
ADVERTISEMENT
<http://servedby.advertisin>
_____
Yahoo! Groups Links
_____
Yahoo! Groups Links
I am supposed to change Vantage default Bill of Lading to include Part numbers / Part Descriptions / and Quantity. I can't see in Data Dictionary how the BOL tables are linked to the Ship Tables. In BOL you use the packing slip #'s to populate the BOL. Does anyone know how to get what is on the Packing Slip on the BOL?
Any hints would be helpful.
Juliet Martin
