Best Practices for Moving Method Directives from Pilot to Prod
Is there any tools or anything that we can use to move a method directive from Pilot to Prod or is are only option to recreate it manually in each environment?
There are at least a few ways you can use:
Solution Workbench, add all the ones you want to a solution, built it, then import
I prefer using directive groups, (if needed I will change the directive group to something like MOVE), then you can use Directive Export\Directive Import by group.
I mainly use groups also, but in groups or solution workbench you need to make sure to override the existing group or bpm or you will end up with duplicates. :frowning:
This is my preferred method. Group associated BPM’s from an entire project into a group and treat it basically a single module/library that’s swapped in as a whole unit.
Another entry in “Things I Found Out The Hard Way”
