My goal is to add a shipment count to the sales order pick list by adding a sub report that displays a count on distinct ShipDtl Order Numbers. We are on the cloud. Here is what I’ve done:
- Modified the RDD to include the ShipDtl table
- Spun off a copy of the SOPick report, then deleted everything except the Data Source so I have something to build my subreport from (is there a better way to point to the cloud data source on a from-scratch sub report?)
- Created a data set for the subreport that looks like this:
=“SELECT T2.OrderNum
FROM OrderHed_” + Parameters!TableGuid.Value + " T1
LEFT OUTER JOIN ShipDtl_" + Parameters!TableGuid.Value + " T2
ON T1.Company = T2.Company AND T1.OrderNum = T2.OrderNum" - Added a parameter to the subreport data set for OrderNum.
- Added a parameter to the subreport for OrderNum.
- Added this as a subreport to the main report, using just the report name (not the full file path) and OrderNum as the subreport parameter.
- Uploaded my modified report and it says the reports/subreports loaded successfully.
The report runs, but says “Error: Subreport could not be shown.”
I then tried running my subreport as the main report for SOPick and get an error that the report cannot be found.
Can anyone tell me where I’m going wrong? I have yet to be successful adding a subreport while on the cloud. Thanks!
