I'm sure theres an easy fix to this but I'm just not seeing it. I have the following procedure which is intended to pull back some UD values from a customised version of the CustXPrt table when an order line is saved.
It works OK when theres a matching customer part record, however there will be times when there is no match and at the moment when that happens its throwing a Record Not Found exception.
Can this code be adapted to ignore such instances and if so how ?
WM
Private Sub oTrans_ordAdapter_BeforeAdapterMethod(ByVal sender As object, ByVal args As BeforeAdapterMethodArgs) Handles oTrans_ordAdapter.BeforeAdapterMethod
'// ** Argument Properties and Uses **
'// args.MethodName, args.Cancel
'Add Event Handler Code
'MessageBox.Show(args.MethodName) ' use this to find method
dim myCustPart as String
dim myCustID as String
dim agreementAmount as string
dim expiry as string
Dim partDtl As EpiDataView = CType(oTrans.EpiDataViews("OrderDtl"), EpiDataView)
Dim ordHed as EpiDataView = CType(oTrans.EpiDataViews("OrderHed"),EpiDataView)
myCustPartAd = new CustXPrtAdapter(SalesOrderForm)
Select Case args.MethodName
Case "Update"
myCustPartAd = New CustXPrtAdapter(SalesORderForm)
_myPartNum = partDtl.dataView(PartDtl.Row)("PartNum")
myCustID = ordHed.dataView(ordHed.Row)("CustNum")
myCustPart = partDtl.dataView(PartDtl.Row)("xPartNum")
Try
myCustPartAd.BOConnect()
Dim exists As Boolean = myCustPartAd.GetByID(myCustID,_myPartNum,myCustPart)
If exists then
agreementAmount = (myCustPartAd.CustXPrtData.CustXPrt.Rows(0)("Number01")).toString()
expiry = (myCustPartAd.CustXPrtData.CustXPrt.Rows(0)("Date01")).toString
edvOrdDtl.dataView(edvOrdDtl.row)("ShortChar04") = agreementAmount
edvOrdDtl.dataView(edvOrdDtl.row)("ShortChar05") = expiry
edvOrdDtl.dataView(edvOrdDtl.row)("Checkbox01") = true
else
oTrans.pushStatusText("No stock agreement",True)
End if
Catch ex as exception
messagebox.show(ex.message,"Exception Thrown By Customer Part Adapter")
End try
Case Else
End Select
End Sub
WM
Case "Update"
Try
If exists then
else
End if
End try
Case Else
End Select
End Sub
