Hello Guys,
I am stuck badly in one situation to generate the MAP file with the use of BAQ instead of standard RDD ?
I tried
- created a BAQ.
- Pulled it in the newly created RDD and Saved.
- Created new report style in Job traveler report and attached the NEW RDD(with BAQ).
- And when I generate it from generate button it says Value Cannot be null.
has Anyone came across this issue and has the solution to it ?
Thanks in Advance.
klincecum
(Kevin Lincecum)
2
You ran the BAQ to test beforehand I assume.
Hi Kevin,
Yes I ran the BAQ in the BAQ i am having only one JobHead table.
JasonMcD
(Jason McDermott)
4
Nope. We discussed this before here. No one was successful.
[Edit from here on]
OK, now that I refreshed myself on this…
I still think it’s a no, if you are trying to replace the job-traveler RDD with your own BAQ.
Like, forget BarTender - can you even accomplish that task with an SSRS report?! If so, I’ve always wanted to know how to do that.
Now, you can take any existing system report and BarTender-ize it, as we discuss in that thread.
