We’re using Bartender to auto print a label when a part is received from a PO. A lot of times the parts are in multiples boxes or on multiple reels. Ideally, when receiving the part, we would get a prompt for number of parts per box/container and then the label would print automatically.
If anyone can provide a few pointers to get me started, I would be eternally grateful. I don’t know anything about code, so I really hope there is a moderately simple option…
You can use what Utah said and set the Dynamic Field there… or if it will always be the same and you are using the built-in Epicor BPM Directive there is a Number of Labels hard-code value In the BPM Widget if I recall.
The difference is that the Field Utah showcases is read from the row and the BPM Widget creates 2 rows in the .csv (identical ones, so if you do Serialization you have to be careful).
But what got me is that it almost seems like @WendyB wants to use the part tags not the part labels maybe, like she wants different quantities on each label maybe?
