Bartender Printers - Change printer
In the bartender process, where are the printers set up? It currently is auto printing to a printer and we would like to change it to a different printer. I am not sure if they are using Commander or if it is coded into the BPM directive. How does bartender printers get set up?
There are a lot of places to set the printer. You can hard set it in the commander, you can pass in a header with the printer info, or you can use the saved printer from the template file.
Where do we look in the “header” or Template file?
How do we know if Commander is set up or is Commander required? I did not see it on the server or where Commander is installed.
Looks like it is auto printed from a BAM?
