Preamble
I just upgraded to BarTender 2022. FYI with regards to version 2022 there is a problem with R5 Through R7 (Latest Release) when using the GenXXX RDD files in Epicor. Those RDD files add “/DBTEXTHEADER” parameter. For some reason the latest 3 releases on Bartender do not like that. You have to downgrade to R4 to resolve it, or find a way to remove the parameter from the file (or be in a different Release of Epicor maybe). I don’t see how that is possible with the GenXXX unless you intercept it with PowerShell and strip it out. But I digress…
We have Mobile Warehouse on 10.2.500.19. We are migrating a company using SyteLine CSI and I believe Factory Track. They have a mobile app as well. From what I gather they have a bunch of print options throughout that are on-demand. For example, they key in a part, Serial Number and QTY and a label gets printed.
Historically I believe that Bartender print options were basically limited to the GenXXX where the Command Script was provided via the Report Style. 2022 offers REST API calls as well as a mobile app. From what I hear the Biscit Mobile Warehouse is not really customizable as Epicor itself. I only have limited expose to it but I have a feeling that only way I would be printing from it is with BPM/DD triggering a print job to a GenXXX RDD. Are there any other options? I think they are going to expect random Print Buttons throughout the App that are not triggered through logic…just manual prints. I have a feeling I will have to install the Bartender App on the device and recreate their BT Reports in the Bartender Print portal. Then have Bartender query SQL to reproduce what they have. Unless there is a way to make some API calls?
