I am looking into barcoding and I was hoping to make it populate data from the work order into MES. I’ve tried most everything I’ve seen on here and hoping someone may be able to help.
Running Crystal Report 2013 version 14.1.1.1036
Epicor 9.05.702A
Dataworks Code 39 font
My query is for 568482, 0, 50 for the fields, respectively.
when I scan the barcode the Job Num box in MES simply reads: 568482$I0$I50. It’s just printing out the TAB statements rather than executing them. Thoughts?
I finally found the barcode for it in the reference guide with no such luck. I’ve tried all combinations of Function Key Mapping, Enable Code 39 Full ASCII Conversion. I’m trying in Word, Notepad, and Epicor.
