Bartender is an app that integrates with Vantage.
www.seagullscientific.com <http://www.seagullscientific.com/>
It's installed along with APM and auto-prints labels. It has the
ability to print many styles of barcodes.
Of effgroups@...
Sent: Tuesday, June 22, 2010 1:53 PM
Subject: Re: [Vantage] Barcode in Crystal Report
Hi Vic
What's bartender and how is it used
Ephraim
Ephraim Feldman
<mailto:vic.drecchio%40timco.aero> >
Sender: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
Date: Fri, 18 Jun 2010 17:02:00
To: <vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> >
Reply-To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
Subject: RE: [Vantage] Barcode in Crystal Report
Crystal Reports and Code39 in general is easy to create.
Code 128 requires checksum digits and can be done in Crystal Reports
with a plug-in I've seen.
Other barcode formats you will be forced to use Bartender.
Behalf
Of effgroups@... <mailto:effgroups%40gmail.com>
Sent: Friday, June 18, 2010 3:57 PM
That's right and I have this barcode already and I use it.
But since this barcode is a linear barcode so the longer my number is
the barcode uses more space.
Now I want to barcode my Part # that could be more that 20 characters so
I want to use 2D barcode called Datamatrix that is very compact even for
long strings but this is not a font so it has to tie in crystal's
barcode system.
And there is the issue how?
Ephraim Feldman
<mailto:dale.schuerman%40ramsys.com>
<mailto:dale.schuerman%40ramsys.com> >
Date: Fri, 18 Jun 2010 14:36:04
Epicor comes with a Dataworks 3 of 9 font.
Copy client\dwbar39.ttf to your windows\fonts directory and reboot your
computer.
The 3 of 9 font will then be available to Crystal reports.
I have never used any other barcodes but I assume all you need is the
correct font installed.
Hope this helps.
Dale E. Schuerman
Senior Consultant
RAM Software Systems, Inc.
1701 North Collins Suite 200
Richardson, Texas 75080
972-669-0763 x233 (voice)
972-669-9603 (fax)
mailto:dale.schuerman@... <mailto:dale.schuerman%40ramsys.com>
<BLOCKED::blocked::mailto:dale.schuerman@...
<mailto:dale.schuerman%40ramsys.com> > (email)
http://www.ramsys.com <blocked::blocked::http://www.ramsys.com/>
(website)
Behalf
Of efyf_1999
Sent: Friday, June 18, 2010 1:54 PM
Subject: [Vantage] Barcode in Crystal Report
Hi
Im looking to start printing Barcodes on some forms in crystal from
Epicor 9.
Ideally i would like to print 2D DataMatrix barcodes.
I have no experience with barcodes in crystal, i saw that you can select
change to barcode and it gives you the option "Change to Barcode" but
there are no barcodes there to select.
Any help would be appreciated
Ephraim
Attention:
This email message is privileged and confidential. If you are not the
intended recipient please delete the message and notify the sender.
Any views or opinions presented are solely those of the author.
This email message has been scanned for Viruses and Content and cleared
by MailMarshal SMTP
For more information go to http://www.ramsys.com
Of effgroups@...
Hi Vic
Ephraim
Ephraim Feldman
Behalf
barcode system.
Ephraim Feldman
computer.
Hope this helps.
Dale E. Schuerman
Senior Consultant
972-669-9603 (fax)
(website)
Behalf
Of efyf_1999
Hi
Epicor 9.
Ephraim
Attention:
by MailMarshal SMTP
