P.S I know it’s a PDF problem because the bar codes do come through on Microsoft Word. Which is not ideal since Word adds an extra page between pages and the alignment is off.
Does the font you’re using have Human Readable text too? Any possibility that the field size on the report is clipping the barcode, and you only see the Human Readable part?
Nope, I reduced it to Font 12 and still no luck. We don’t have DataWorks, but I can try it. I’m not sure it will make a difference. None of the other Bar Codes fonts work in PDF.
And FWIW the screen shot above was taken on a Client that does NOT have the DataWorks font installed (but does have 9 different variants of Code39Azalea installed)
So to circle back around … Viewing the Report in SSRS builder (in Run mode), and the barcodes appear. But previewing in a PDF they don’t.
I know the SSRS Builder allows you to export a report after it has been run. Is PDF one of the export options? If so, export it then view that PDF on several different machines.
