Barcode and MES - 8.03.4xx
We do it by using one barcode with Tabs - not sure where Epicor are coming from
there. At the end of the day a barcode is literally like typing into the box,
tabbing, typing again, tabbing etc.
Sent: Wed, 29 September, 2010 17:07:54
Subject: [Vantage] Re: Barcode and MES - 8.03.4xx
Â
Here is the response from Epicor:
9/29/2010 9:15:28 AM JNALLS Email to Jeremey
Hi Jeremey,
The functionality to combine multiple bar codes for entering data into the Job,
Assembly and Operation fields is no longer available in Vantage 8.00 and higher
versions. There were validations added to program which prevents this. There are
no plans to add this back into Vantage or Epicor 9. Please let me know if you
have any other questions on this issue.
--- In vantage@yahoogroups.com, Chris Thompson <chriselectrix@...> wrote:
> Here are a couple of things that may help ... I cant remember which fixed it
>for
> me but they may be worth a try ...
> In the userSettings section of their specialmes.mfgsys file, set the value for
> SelectTextOnEnter node to true. This will select the entire data contents of a
> control when focus transfers to the control via a Tab or programmatic
>set-focus.
> I believe that we do not select the entire data if a mouse event initiates
> focus.
> <SelectTextOnEnter value="True" bool="" /> "
> ÂÂ
> ÂÂ
> Another option ...
> ÂÂ
> ÂÂ
> Try setting the AutoEdit property to false (if not available in
> designer propeties, it will have to be done in code)
> here is a description of the property:
> public bool AutoEdit { set; get; }
> Member of Infragistics. Win.UltraWinGrid .UltraCombo
> Summary:
> Determines if the combo will support automatic value completion.
> (Default is true).
> Remarks:
> Setting the AutoEdit property to True will enable automatic edit
> value completion for the text area of the combo, based on the values
> in the value list. When AutoEdit is True and the user types a
> character in the combo's text box, the control will search the
> contents of the
> Infragistics. Win.UltraWinGrid .UltraDropDownBa se.DisplayMember column
> to see if it contains a value that begins with the same character. If
> it does, this value will appear in the text box, with all of its
> characters highlighted except the one that the user typed. If the
> user types a second character, the control will check to see if it is
> the next highlighted character is in the value that appeared. If it
> is, the value stays and the character typed becomes deselected. If
> the second character does not appear in the value, the control
> searches the list again for a value that begins with the first two
> characters that were typed. If one exists, it appears in the text
> box; otherwise the selected text is removed and no more searching
> takes place. This process continues until the user shifts the input
> focus away from the control. If the UltraCombo's
> Infragistics. Win.UltraWinGrid .UltraCombo. DropDownStyle has been set
> to DropDownList, then setting the AutoEdit to true will enable multi-
> character auto-edit functionality for the drop down list style. In
> multi-character auto-edit mode, the control will select the item
> whose text starts with characters typed so far. After 500
> milliseconds of time span since last keystroke, a new auto-edit
> session begins where the previously typed characters are discarded
> and new characters are used for multi-character matching.
> ÂÂ
> ÂÂ
> ÂÂ
> Just out of interest, the barcode forumla I use is as follows ...
> "*"&ToText({JobHead.JobNum})&"$I"&"*" ÂÂ
> <<< this is a simplified version, you then add the additional fields you want
>to
> tab through. I think you also need to allo Full ASCII on your barcoder to read
> the $I < (letter i).
> $I equates to a tab so you would add the next field after the least & sign ...
> ToText ({JobAsmbl.AssemblySeq},0)
> From: Chris Thompson <chriselectrix@...>
> Sent: Wed, 29 September, 2010 14:41:48
> Subject: Re: [Vantage] Barcode and MES - 8.03.4xx
> ÂÂ
> Let me dig around because there is a fix which when used with the correct
> barcode which uses a tab between jobno, asm no etc. it works fine.
> From: Brian W. Spolarich <bspolarich@...>
> Sent: Wed, 29 September, 2010 14:14:48
> Subject: RE: [Vantage] Barcode and MES - 8.03.4xx
> ÂÂ
> I've noticed that the small two-digit barcodes (i.e. op 10) don't scan
> consistently on our test scanners (say on the Job Traveler report). We
> haven't started using barcoding yet but want to get there soon.
> -bws
> -----Original Message-----
> Of jeremeyhavrilla
> Sent: Wednesday, September 29, 2010 8:33 AM
> Subject: [Vantage] Barcode and MES - 8.03.4xx
> Has anyone in the group had issues with using a single barcode in MES
> that reads (JobNum, AsySeq, Op)? Specifically, when scanning the
> barcode in MES it stops on JobNum and will not continue to Asy and Op.
> It seems that this is caused by the lookup that happens on Jobnum. I
> can make it work by using two barcodes (one for JobNum, and second for
> Asy, and Op) without issue. Note: Works perfect in Notepad.
> I've read all the posts on the group in regards to setting up keystroke
> delays and intra-keystroke delays on the scanner but these have no
> effect. Any insight would be much appreciated. Thanks!
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder
> and Crystal Reports and other 'goodies', please goto:
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> Let me dig around
Has anyone in the group had issues with using a single barcode in MES that reads (JobNum, AsySeq, Op)? Specifically, when scanning the barcode in MES it stops on JobNum and will not continue to Asy and Op. It seems that this is caused by the lookup that happens on Jobnum. I can make it work by using two barcodes (one for JobNum, and second for Asy, and Op) without issue. Note: Works perfect in Notepad.
I've read all the posts on the group in regards to setting up keystroke delays and intra-keystroke delays on the scanner but these have no effect. Any insight would be much appreciated. Thanks!
-bws
Of jeremeyhavrilla
Â
-bws
Of jeremeyhavrilla
Let me dig around
Yeah, actually, if you dig on this forum you should find it. Aimee
Grebe posted a solution a few months ago.
Of Chris Thompson
Sent: Wednesday, September 29, 2010 9:42 AM
correct
<mailto:bspolarich%40advancedphotonix.com> >
-bws
Behalf
Of jeremeyhavrilla
Let me dig around
We have it working, but I can't remember what the fix was.
Sent: Wed, 29 September, 2010 13:32:53
Â
Notepad.
Here are a couple of things that may help ... I cant remember which fixed it for
control when focus transfers to the control via a Tab or programmatic set-focus.
focus.
Â
Â
Another option ...
Â
Â
Summary:
(Default is true).
Remarks:
contents of the
Â
Â
Â
"*"&ToText({JobHead.JobNum})&"$I"&"*"Â Â
<<< this is a simplified version, you then add the additional fields you want to
the $IÂ < (letter i).
Â
Â
-bws
Of jeremeyhavrilla
Let me dig around
Hi Jeremey,
The functionality to combine multiple bar codes for entering data into the Job, Assembly and Operation fields is no longer available in Vantage 8.00 and higher versions. There were validations added to program which prevents this. There are no plans to add this back into Vantage or Epicor 9. Please let me know if you have any other questions on this issue.
> focus.
> ÂÂ
> ÂÂ
> Another option ...
> ÂÂ
> ÂÂ
> Summary:
> (Default is true).
> Remarks:
> contents of the
> ÂÂ
> ÂÂ
> ÂÂ
> ÂÂ
> ÂÂ
> -bws
> Of jeremeyhavrilla
> Let me dig around
Though Epicor says this functionality is no longer supported I was able to get it working and several others have as well by following a specific configuration set on the barcode scanner. This may vary by scanner model but it works for Symbol LS2208 scanners. I think there was one particular parameter that made it work but I cannot remember which one it was. You also need to make sure the correct formula is on your Crystal Report. I used
"*"+{JobAsmbl.JobNum}+"$I"+trim(totext({JobAsmbl.AssemblySeq},0))+"$I"+trim(totext({JobOper.OprSeq},0))+"$I"+""+"$I"+""+"$I"+""+"$I"+""+"$I"+"*"
All the tabs at the end are to get through the Resource fields and get the focus on the OK button.
I have uploaded the configuration to the Files section of the group.
Hope this helps!
Aimee
> Hi Jeremey,
> > focus.
> > ÂÂ
> > ÂÂ
> > Another option ...
> > ÂÂ
> > ÂÂ
> > Summary:
> > (Default is true).
> > Remarks:
> > contents of the
> > ÂÂ
> > ÂÂ
> > ÂÂ
> > From: Chris Thompson <chriselectrix@>
> > ÂÂ
> > From: Brian W. Spolarich <bspolarich@>
> > ÂÂ
> > -bws
> > Of jeremeyhavrilla
> > Let me dig around
SHHHHH! Don't let my login stations hear that. They are working great on Vantange 8.00.
Here is my Crystal formula:
"*" + Trim({JobHead.JobNum}) + "$I" +
trim(totext({JobAsmbl.AssemblySeq},0)) + "$I" + trim(totext({JobOper.OprSeq},0))
+ "$I" + "*"
I'm using the Symbol scanners. Through a lot of trial and error, I have a list of setup scans to set parameters starting with the default settings. I'm not sure which ones are the critical parameters but got tired of playing with it. It takes maybe two minutes if that to setup and it doesn't happen that often. I'm not going to pretend I have the slightest idea of what any of these parameters are for but nevertheless, it works for me. YMMV
You can download the manual with the setup barcodes from the Symbol website. Here is my list:
SET DEFAULTS
Com Options
Standard Interfaces Wedge
Terminal Type: AT
Country Code: North American
Keystroke Delay: 0 ms
Ignore Unknown Chars: Enable
Caps Lock: Disable
Inter Scan Code Delay: Disable
Enable Alt Numeric Keypad: Enable
Caps Lock Override: Disable
Function Key Mapping: Enable
FN1 Substitution: Disable
Send Make and Break: Send Make and Break
Convert Wedge Data: Convert Wedge Data to Upper Case
Single RS232C
Baud Rate: 9600 Baud
Parity: None
Hardware Handshaking: None
Software Handshaking: None
Stop Bits: 1 Bit
Data Bits: 8 Bits
RTS State: Low
Serial Response Timeout: 2 sec
Retail Format Type: Standard Host (None)
Intercharacter Delay: 0 ms
Beep on Bel: Disable
Check Receive Errors: Enable
Nixdorf Beep/LED Options: Normal Operation
USB Configuration
USB Type: Hardware Default
SNAPI Status Handshake (if supported): Enable
Emulate Keypad: Enable
Simulated Cap Lock: Disable
Convert Case: Convert all to Upper Case
IBM 46xx
Port Address: None Selected
Convert Unknown Code Types to Code 39: Enable
Wand Emulation
Terminal Type: Symbol
Leading Margin: 80 ms
Wand Bar Out: High
Convert to Code 39: Enable
Full ASCII Conversion: Enable
Symbologies
Linear Barcodes
Code 39: Enable
Code 39 Full Ascii: Enable
Trioptic Code 39: Disable
I 2 of 5: Disable
> Hi Jeremey,
