Bar codes in V10
Agreed. I wasn’t quite following where version enters into the mix unless you wanted to do it in crystal. Then version of Epicor would matter. Going from 8 to 10 you will have to redo some column names and stuff maybe, but the time to do that is minimal.
Joshua Giese
CIO
Direct:     920.593.8299
IT Dept:   920.437.6400 Ext. 337
Site ID:    27450-E905702A-SQL64
Wisconsin Converting, Inc.
Sent: Wednesday, November 5, 2014 11:03 AM
Subject: RE: [Vantage] Re: Bar codes in V10
If you purchase Bar Tender from Epicor with a BAM this is fairly simple to resolve on Vantage and in E10 you would want to also use bartender.
Regards,
Sent: 05 November 2014 17:00
Subject: Re: [Vantage] Re: Bar codes in V10
Thanks.  Unfortunately, we can't wait.  Its only for creating pallet labels for one customer who requires the information to be labeled using GS1-128 (formerly UCC-128) barcode standard.
Steven G.
On Wednesday, November 5, 2014 10:56 AM, "sergio prieto s_a_prieto@... [vantage]" <vantage@yahoogroups.com> wrote:
if you can wait till getting to E10 I would definitely suggest to do so, thinking on the time and cost you will put in to implement on Vantage, and the fact you will have to reinvest that for e10 I honestly don't think its a good idea cost wise, unless there is no way for you to wait till e10.
but that's just a thought,
they may tell you that you can do that upgrade really easily and that no cost would be involve but i would be really careful about it. Specially since you are coming all the way from vantage.
On Wednesday, November 5, 2014 7:36 AM, "Steven Gotschall sgotschall@... [vantage]" <vantage@yahoogroups.com> wrote:
Progress.  But of course we will have to switch to SQL when we go to V10.
Steven G.
On Wednesday, November 5, 2014 10:25 AM, "sergio prieto s_a_prieto@... [vantage]" <vantage@yahoogroups.com> wrote:
are you a sql or progress DB user?
Stephen Edginton (Beng) | Solutions & Technical Director
Mobile:
 +44 7734 858415
DDI:
 +44 121 314 1179
Main:
 +44 (0) 121 314 1170
Web:
 www.dotnetit.co.uk
Dot Net IT Limited, One St Kenelm Court, Steel Park Road, Halesowen, B62 8HD, United Kingdom.
DotNetIT
Epicor Platinum Partner
Epicor Alliance Partner
We are currently on 8.03 and need to purchase something like Bartender for some new bar code requirements we have.  Since we are looking at upgrading to version 10, will Bartender still work in version 10?
Steven G.
Yes and it’s amazing. Bartender accepts a wide variety of data formats. The one that Epicor utilizes is essentially a CSV. Even if Epicor stopped supporting it, which I doubt will happen. Creating CSV data for bartender to pick up from C# is a cake walk.
Joshua Giese
CIO
Sent: Wednesday, November 5, 2014 8:35 AM
Subject: [Vantage] Bar codes in V10
Steven G.
Steven G.
<div id="ygrps-yiv-82787132yiv6572224145ygrp-text">
  <div></div><div style="color:#000;background-color:#fff;font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;"><div>are you a sql or progress DB user?</div></div>
</div>
<div id="ygrps-yiv-840368703yiv8705196124ygrp-text">
  <div style="color:rgb(0, 0, 0);font-family:HelveticaNeue, 'Helvetica Neue', Helvetica, Arial, 'Lucida Grande', sans-serif;font-size:12px;background-color:rgb(255, 255, 255);"><div dir="ltr" id="ygrps-yiv-840368703yiv8705196124yui_3_16_0_1_1415197818798_81969"><span id="ygrps-yiv-840368703yiv8705196124yui_3_16_0_1_1415197818798_81968">Progress. &nbsp;But of course we will have to switch to SQL when we go to V10.</span></div><div dir="ltr" id="ygrps-yiv-840368703yiv8705196124yui_3_16_0_1_1415197818798_81967"><span><br clear="none"></span></div><div dir="ltr" id="ygrps-yiv-840368703yiv8705196124yui_3_16_0_1_1415197818798_81964"><span>Steven G.</span></div> <div class="ygrps-yiv-840368703yiv8705196124qtdSeparateBR"><br clear="none"><br clear="none"></div><div class="ygrps-yiv-840368703yiv8705196124yqt0529887010" id="ygrps-yiv-840368703yiv8705196124yqt30837"><div class="ygrps-yiv-840368703yiv8705196124yahoo_quoted" style="display:block;"> <div style="font-family:HelveticaNeue, 'Helvetica Neue', Helvetica, Arial, 'Lucida Grande', sans-serif;font-size:12px;"> <div style="
font-family:HelveticaNeue, ‘Helvetica Neue’, Helvetica, Arial, ‘Lucida Grande’, sans-serif;font-size:16px;">
On Wednesday, November 5, 2014 10:25 AM, "sergio prieto s_a_prieto@… [vantage]" <vantage@yahoogroups.com> wrote:
  <div></div><div style="color:rgb(0, 0, 0);font-family:HelveticaNeue, 'Helvetica Neue', Helvetica, Arial, 'Lucida Grande', sans-serif;font-size:16px;background-color:rgb(255, 255, 255);"><div>are you a sql or progress DB user?</div></div>
</div>
</div>
<div class="ygrps-yiv-840368703yiv8705196124yqt0529887010" id="ygrps-yiv-840368703yiv8705196124yqt80644"><div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124 -- #ygrps-yiv-840368703yiv8705196124ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124ygrp-mkp #ygrps-yiv-840368703yiv8705196124hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124ygrp-mkp #ygrps-yiv-840368703yiv8705196124ads {
margin-bottom:10px;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124ygrp-mkp .ygrps-yiv-840368703yiv8705196124ad {
padding:0 0;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124ygrp-mkp .ygrps-yiv-840368703yiv8705196124ad p {
margin:0;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124ygrp-mkp .ygrps-yiv-840368703yiv8705196124ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124ygrp-sponsor #ygrps-yiv-840368703yiv8705196124ygrp-lc {
font-family:Arial;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124ygrp-sponsor #ygrps-yiv-840368703yiv8705196124ygrp-lc #ygrps-yiv-840368703yiv8705196124hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124ygrp-sponsor #ygrps-yiv-840368703yiv8705196124ygrp-lc .ygrps-yiv-840368703yiv8705196124ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124activity span {
font-weight:700;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124activity span span {
color:#ff7900;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124activity span .ygrps-yiv-840368703yiv8705196124underline {
text-decoration:underline;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 .ygrps-yiv-840368703yiv8705196124attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 .ygrps-yiv-840368703yiv8705196124attach div a {
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 .ygrps-yiv-840368703yiv8705196124attach img {
border:none;padding-right:5px;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 .ygrps-yiv-840368703yiv8705196124attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 .ygrps-yiv-840368703yiv8705196124attach label a {
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 .ygrps-yiv-840368703yiv8705196124bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 .ygrps-yiv-840368703yiv8705196124bold a {
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 dd.ygrps-yiv-840368703yiv8705196124last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 dd.ygrps-yiv-840368703yiv8705196124last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 dd.ygrps-yiv-840368703yiv8705196124last p span.ygrps-yiv-840368703yiv8705196124yshortcuts {
margin-right:0;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 div.ygrps-yiv-840368703yiv8705196124attach-table div div a {
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 div.ygrps-yiv-840368703yiv8705196124attach-table {
width:400px;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 div.ygrps-yiv-840368703yiv8705196124file-title a, #ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 div.ygrps-yiv-840368703yiv8705196124file-title a:active, #ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 div.ygrps-yiv-840368703yiv8705196124file-title a:hover, #ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 div.ygrps-yiv-840368703yiv8705196124file-title a:visited {
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 div.ygrps-yiv-840368703yiv8705196124photo-title a, #ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 div.ygrps-yiv-840368703yiv8705196124photo-title a:active, #ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 div.ygrps-yiv-840368703yiv8705196124photo-title a:hover, #ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 div.ygrps-yiv-840368703yiv8705196124photo-title a:visited {
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 div#ygrps-yiv-840368703yiv8705196124ygrp-mlmsg #ygrps-yiv-840368703yiv8705196124ygrp-msg p a span.ygrps-yiv-840368703yiv8705196124yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 .ygrps-yiv-840368703yiv8705196124green {
color:#628c2a;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 .ygrps-yiv-840368703yiv8705196124MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 o {
font-size:0;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124photos div {
float:left;width:72px;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124reco-category {
font-size:77%;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124reco-desc {
font-size:77%;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 .ygrps-yiv-840368703yiv8705196124replbq {
margin:4px;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124ygrp-mlmsg select, #ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 input, #ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124ygrp-mlmsg pre, #ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 code {
font:115% monospace;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124ygrp-mlmsg #ygrps-yiv-840368703yiv8705196124logo {
padding-bottom:10px;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124ygrp-msg p#ygrps-yiv-840368703yiv8705196124attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124ygrp-reco #ygrps-yiv-840368703yiv8705196124reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124ygrp-sponsor #ygrps-yiv-840368703yiv8705196124ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124ygrp-sponsor #ygrps-yiv-840368703yiv8705196124ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124ygrp-sponsor #ygrps-yiv-840368703yiv8705196124ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124ygrp-text {
font-family:Georgia;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124ygrp-text tt {
font-size:120%;}
#ygrps-yiv-840368703 #ygrps-yiv-840368703yiv8705196124 #ygrps-yiv-840368703yiv8705196124ygrp-vital ul li:last-child {
border-right:none !important;}
Steven G.
<div id="ygrps-yiv-296469798yiv9706685249ygrp-text">
  <div></div><div style="color:#000;background-color:#fff;font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;"><div><span>if you can wait till getting to E10 I would definitely suggest to do so, thinking on the time and cost you will put in to implement on Vantage, and the fact you will have to reinvest that for e10 I honestly don&#39;t think its a good idea cost wise, unless there is no way for you to wait till e10.</span></div><div style="color:rgb(0, 0, 0);font-size:16px;font-family:HelveticaNeue, 'Helvetica Neue', Helvetica, Arial, 'Lucida Grande', sans-serif;font-style:normal;background-color:transparent;"><span><br clear="none"></span></div><div style="color:rgb(0, 0, 0);font-size:16px;font-family:HelveticaNeue, 'Helvetica Neue', Helvetica, Arial, 'Lucida Grande', sans-serif;font-style:normal;background-color:transparent;"><span>but that&#39;s just a thought,&nbsp;</span></div><div style="color:rgb(0, 0, 0);font-size:16px;font-family:HelveticaNeue, 'Helvetica Neue', Helvetica, Arial, 'Lucida Grande', sans-serif;font-style:normal;background-color:transparent;"><span><br clear="none"></span></div><div style="color:rgb(0, 0, 0);font-size:16px;font-family:HelveticaNeue, 'Helvetica Neue', Helvetica, Arial, 'Lucida Grande', sans-serif;font-style:normal;background-color:transparent;"><span>they may tell you that you can do that upgrade really easily and that no cost would be involve but i would be really careful about it. Specially since you are coming all the way from vantage.</span></div> <div class="ygrps-yiv-296469798yiv9706685249qtdSeparateBR"><br clear="none"><br clear="none"></div><div class="ygrps-yiv-296469798yiv9706685249yqt6859369458" id="ygrps-yiv-296469798yiv9706685249yqt39855"><div class="ygrps-yiv-296469798yiv9706685249yahoo_quoted" style="display:block;"> <div style="font-family:HelveticaNeue, 'Helvetica Neue', Helvetica, Arial, 'Lucida Grande', sans-serif;font-size:16px;"> <div style="font-family:HelveticaNeue, 'Helvetica Neue', Helvetica, Arial, 'Lucida Grande', sans-serif;font-size:16px;"> <div dir="ltr"> <font size="2" face="Arial"> On Wednesday, November 5, 2014 7:36 AM, &quot;Steven Gotschall sgotschall@... [vantage]&quot; &lt;vantage@yahoogroups.com&gt; wrote:<br clear="none"> </font> </div>  <br clear="none"><br clear="none"> <div class="ygrps-yiv-296469798yiv9706685249y_msg_container"><div id="ygrps-yiv-296469798yiv9706685249"><div>
  <div style="color:rgb(0, 0, 0);font-family:HelveticaNeue, 'Helvetica Neue', Helvetica, Arial, 'Lucida Grande', sans-serif;font-size:12px;background-color:rgb(255, 255, 255);"><div dir="ltr" id="ygrps-yiv-296469798yiv9706685249yui_3_16_0_1_1415197818798_81969"><span id="ygrps-yiv-296469798yiv9706685249yui_3_16_0_1_1415197818798_81968">Progress. &nbsp;But of course we will have to switch to SQL when we go to V10.</span></div><div dir="ltr" id="ygrps-yiv-296469798yiv9706685249yui_3_16_0_1_1415197818798_81967"><span><br clear="none"></span></div><div dir="ltr" id="ygrps-yiv-296469798yiv9706685249yui_3_16_0_1_1415197818798_81964"><span>Steven G.</span></div> <div class="ygrps-yiv-296469798yiv9706685249qtdSeparateBR"><br clear="none"><br clear="none"></div><div class="ygrps-yiv-296469798yiv9706685249yqt0529887010" id="ygrps-yiv-296469798yiv9706685249yqt30837"><div class="ygrps-yiv-296469798yiv9706685249yahoo_quoted"> <div style="font-family:HelveticaNeue, 'Helvetica Neue', Helvetica, Arial, 'Lucida Grande', sans-serif;font-size:12px;"> <div style="font-family:HelveticaNeue, 'Helvetica Neue', Helvetica, Arial, 'Lucida Grande', sans-serif;font-size:16px;"> <div dir="ltr"> <font size="2" face="Arial"> On Wednesday, November 5, 2014 10:25 AM, &quot;sergio prieto s_a_prieto@... [vantage]&quot; &lt;vantage@yahoogroups.com&gt; wrote:<br clear="none"> </font> </div>  <br clear="none"><br clear="none"> <div class="ygrps-yiv-296469798yiv9706685249y_msg_container"><div id="ygrps-yiv-296469798yiv9706685249">
</div>
</div>
<div class="ygrps-yiv-296469798yiv9706685249yqt0529887010" id="ygrps-yiv-296469798yiv9706685249yqt80644"><div style="color:#fff;height:0;"></div></div>
</div>
<div class="ygrps-yiv-296469798yiv9706685249yqt6859369458" id="ygrps-yiv-296469798yiv9706685249yqt32518"><div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 -- #ygrps-yiv-296469798yiv9706685249ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249ygrp-mkp hr {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249ygrp-mkp #ygrps-yiv-296469798yiv9706685249hd {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249ygrp-mkp #ygrps-yiv-296469798yiv9706685249ads {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249ygrp-mkp .ygrps-yiv-296469798yiv9706685249ad {
padding:0 0;}
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249ygrp-mkp .ygrps-yiv-296469798yiv9706685249ad p {
margin:0;}
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249ygrp-mkp .ygrps-yiv-296469798yiv9706685249ad a {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249ygrp-sponsor #ygrps-yiv-296469798yiv9706685249ygrp-lc {
font-family:Arial;}
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249ygrp-sponsor #ygrps-yiv-296469798yiv9706685249ygrp-lc #ygrps-yiv-296469798yiv9706685249hd {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249ygrp-sponsor #ygrps-yiv-296469798yiv9706685249ygrp-lc .ygrps-yiv-296469798yiv9706685249ad {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249actions {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249activity {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249activity span {
font-weight:700;}
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249activity span:first-child {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249activity span a {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249activity span span {
color:#ff7900;}
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249activity span .ygrps-yiv-296469798yiv9706685249underline {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 .ygrps-yiv-296469798yiv9706685249attach {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 .ygrps-yiv-296469798yiv9706685249attach div a {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 .ygrps-yiv-296469798yiv9706685249attach img {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 .ygrps-yiv-296469798yiv9706685249attach label {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 .ygrps-yiv-296469798yiv9706685249attach label a {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 .ygrps-yiv-296469798yiv9706685249bold {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 .ygrps-yiv-296469798yiv9706685249bold a {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 dd.ygrps-yiv-296469798yiv9706685249last p a {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 dd.ygrps-yiv-296469798yiv9706685249last p span {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 dd.ygrps-yiv-296469798yiv9706685249last p span.ygrps-yiv-296469798yiv9706685249yshortcuts {
margin-right:0;}
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 div.ygrps-yiv-296469798yiv9706685249attach-table div div a {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 div.ygrps-yiv-296469798yiv9706685249attach-table {
width:400px;}
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 div.ygrps-yiv-296469798yiv9706685249file-title a, #ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 div.ygrps-yiv-296469798yiv9706685249file-title a:active, #ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 div.ygrps-yiv-296469798yiv9706685249file-title a:hover, #ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 div.ygrps-yiv-296469798yiv9706685249file-title a:visited {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 div.ygrps-yiv-296469798yiv9706685249photo-title a, #ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 div.ygrps-yiv-296469798yiv9706685249photo-title a:active, #ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 div.ygrps-yiv-296469798yiv9706685249photo-title a:hover, #ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 div.ygrps-yiv-296469798yiv9706685249photo-title a:visited {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 div#ygrps-yiv-296469798yiv9706685249ygrp-mlmsg #ygrps-yiv-296469798yiv9706685249ygrp-msg p a span.ygrps-yiv-296469798yiv9706685249yshortcuts {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 .ygrps-yiv-296469798yiv9706685249green {
color:#628c2a;}
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 .ygrps-yiv-296469798yiv9706685249MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 o {
font-size:0;}
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249photos div {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249photos div div {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249photos div label {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249reco-category {
font-size:77%;}
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249reco-desc {
font-size:77%;}
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 .ygrps-yiv-296469798yiv9706685249replbq {
margin:4px;}
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249ygrp-actbar div a:first-child {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249ygrp-mlmsg {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249ygrp-mlmsg table {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249ygrp-mlmsg select, #ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 input, #ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 textarea {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249ygrp-mlmsg pre, #ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 code {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249ygrp-mlmsg * {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249ygrp-mlmsg #ygrps-yiv-296469798yiv9706685249logo {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249ygrp-msg p a {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249ygrp-msg p#ygrps-yiv-296469798yiv9706685249attach-count span {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249ygrp-reco #ygrps-yiv-296469798yiv9706685249reco-head {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249ygrp-reco {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249ygrp-sponsor #ygrps-yiv-296469798yiv9706685249ov li a {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249ygrp-sponsor #ygrps-yiv-296469798yiv9706685249ov li {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249ygrp-sponsor #ygrps-yiv-296469798yiv9706685249ov ul {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249ygrp-text {
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249ygrp-text tt {
font-size:120%;}
#ygrps-yiv-296469798 #ygrps-yiv-296469798yiv9706685249 #ygrps-yiv-296469798yiv9706685249ygrp-vital ul li:last-child {
#ygrps-yiv-1816132678 P.ygrps-yiv-1816132678d308bcc0-9c18-4ece-87ae-614b71f65790 { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-1816132678 LI.ygrps-yiv-1816132678d308bcc0-9c18-4ece-87ae-614b71f65790 { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-1816132678 DIV.ygrps-yiv-1816132678d308bcc0-9c18-4ece-87ae-614b71f65790 { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-1816132678 TABLE.ygrps-yiv-1816132678d308bcc0-9c18-4ece-87ae-614b71f65790Table { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-1816132678 DIV.ygrps-yiv-1816132678Section1 { }
Regards,
Steven G.
Steven G.
Mobile:  +44 7734 858415
DDI:  +44 121 314 1179
Main:  +44 (0) 121 314 1170
Web:  www.dotnetit.co.uk
DotNetIT
